Old 05-16-2013, 11:29 PM   #1
Voz OP
Voz's Avatar
Oddometer: 61
GSW Tire Pressure Monitor how to change from Bar to PSI?
I'll bet my left testicle that this is a dealer mod only.
Anyone know?
Sydney, Australia
2013 R1200 GS WC
Voz is offline   Reply With Quote
Old 05-17-2013, 03:31 AM   #2
jt55
Oddometer: 6
Bar to PSI
Yep sure is a dealer mod. My dealer said that they we advised not to do it at this stage as it has been known to play havoc with the display. Software issue they say. Will be able to do it when they get a software update. Was told the same with my K1600
jt55 is offline   Reply With Quote
Old 05-17-2013, 05:59 AM   #3
Voz OP
Voz's Avatar
Oddometer: 61
I gotta go into the dealers tommorrow so will ask. I am defs not diggin on bar.
Sydney, Australia
2013 R1200 GS WC
Old 05-17-2013, 09:28 AM   #4
def
I have little to say
def's Avatar
Oddometer: 6,304
Send a message via Skype™ to def
Just multiply bar x 14.5 for PSI...easy.
def is offline   Reply With Quote
Old 05-17-2013, 09:32 AM   #5
LaurelPerryOnLand
Oddometer: 2,425
As in everything in life...
There's an APP for that:
https://itunes.apple.com/us/app/pres...374474772?mt=8
LaurelPerryOnLand is online now   Reply With Quote
Old 05-17-2013, 09:38 AM   #6
def
def's Avatar
Oddometer: 6,304
Originally Posted by LaurelPerryOnLand View Post
Or, one could just carry a slide rule???
Old 05-17-2013, 10:14 AM   #7
LaurelPerryOnLand
Oddometer: 2,425
A what?
Did you vote for LINCOLN?
Old 05-17-2013, 02:38 PM   #8
RichBMW
RichBMW's Avatar
Oddometer: 499
It's not possible apparently. I asked for the change at the first service, and was told that it's not an option.
2013 BMW R1200GS LC TE
2010 BMW HP2 MEGAMOTO
RichBMW is offline   Reply With Quote
Old 05-17-2013, 07:43 PM   #9
paco fernandez
Mexico
paco fernandez's Avatar
Oddometer: 28
Send a message via MSN to paco fernandez Send a message via Skype™ to paco fernandez
AT your dealer they can do it so easy, I have did it more than 5 times on my bikes, I also ask to modify fuel consumption to km/lt. And reduce the time that delays to auto shoot of tour turn signals. At Mexico almost every one does it at first service.
Enviado desde mi iPad con Tapatalk HD
paco fernandez is offline   Reply With Quote
Old 05-17-2013, 07:57 PM   #10
paco fernandez
Mexico
Oddometer: 28
The answer is YES it can be changed and not only this but all data in the display can be changed to accommodate individual usage and personalize it.
The procedure has a duration of 30 minutes and is given below:
In case the dealer equipment is the BMW ISTA its very similar only the menu is different.
For the BMW GT ONE diagnostics and programming equipment:
connect diagnosis cable
insert data
Choose code instrumentation and CIP programming
Model selection
select continue
select program selection
select software
control unit selection
select no
select change
select CKM
select BAR or KPS or PSI
confirm
SET
that's it.
And as you understand only the dealer can perform it.
Old 05-18-2013, 02:39 AM   #11
Voz OP
Voz's Avatar
Oddometer: 61
insert data
Model selection
select continue
select software
select no
select change
select CKM
confirm
SET
that's it.
Nice info! Thanks.
Sydney, Australia
2013 R1200 GS WC
Times are GMT -7.   It's 09:21 AM.
