Old 08-23-2009, 09:51 AM   #16
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,924
Originally Posted by Grad
i have always used compressed air to remove and install grips. can you use it with the 12GS? if the OEM grips are not "stuck" on to the wires, then it should make removing them very easy.
Agreed. But on my 05, a lot of glue was used and the air nozzle didn't work. It was a labor intensive process.
Turns out I like the rain, easier to Spin, Skid and Slide.
Log Riding 101
NWBoarder is offline   Reply With Quote
Old 08-23-2009, 11:34 AM   #17
philofax OP
lifetime noob on wheels
philofax's Avatar
Oddometer: 424
Originally Posted by Emoto
Nice write-up!
Two comments:
Grips can be easily removed if you have an air compressor and a trigger activated air nozzle.
no way ... they are glued on and the heating wires were melting it all
together. u have no chance for compressed air at the 1200gs with
heated grips. the standard version w/o heating .. yes, there it can
maybe a good choice of waepon.
The other point is that you only need to spray your adhesive (clear spraypaint works well, too, and is not water soluble like hair spray) into the grip cavity. When you spray it on the handlebar, it gets pushed in front of the grip as you slide it on and does little good.
hairspray is not slippery when wet .. as far as i know .. but i will see and i
will tell if something happend.
RideReports - mostly Europe
The Grossglockner HighAlpine Street / Austria RideReport // 2009
How Nightmarion became an ADVRider a RR from Slovenia, Croatia and Italy 2009
Sardinia, the Italian beauty in fall 2009
A country a day keeps the boredom away, Ride Report / Slovenia, Croatia, Italy, Austria, Germany Aug 2010
philofax is offline   Reply With Quote
Old 08-23-2009, 03:01 PM   #18
Nightmarion
Nightmarion's Avatar
Oddometer: 178
Originally Posted by pavement pounder
+1 on hair spray, or French manicure nail polish of course! Now we know where he got the hair spay!
No, wasn't mine. I threw away the can I bought two years ago (to install new grips) about a month ago.
Hi! I'm a signature virus. Copy me to your .sig to help me spread.
Nightmarion is offline   Reply With Quote
Old 08-23-2009, 06:36 PM   #19
leafman60
Oddometer: 1,843
Ive found that the blow nozzel method doesnt work too well with the stock 1200 grips. The heating coils make a rough surface that tends to grab the rubber. Also, there will be factory glue that must be carefully cut through.
The best way that Ive found to remove the old rubbers is to simply cut them and carefully roll the pieces off. You dont need to preserve them.
leafman60 screwed with this post 08-28-2009 at 05:21 AM
leafman60 is offline   Reply With Quote
Old 08-25-2009, 09:22 PM   #20
SLOspeed
Oddometer: 122
Why use two right side grips? What's the difference between the left and right grips? I checked, left and right do have different part #'s.
-Steve
SLOspeed is offline   Reply With Quote
Old 08-25-2009, 10:54 PM   #21
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,924
-Steve
The throttle side on most bikes has a larger diameter, due to the throttle barrel. The R12GS is large in diameter on BOTH sides due to the heated grips.That's why when you buy normal grips off the shelf, the inner diameter (ID) of one is larger.
Log Riding 101
Old 08-28-2009, 05:23 AM   #22
leafman60
Oddometer: 1,843
Yeah, you need the right-side grip rubbers with the bigger holes to go over the heating elements.
Again, I use a little bit of glue on my replacements. Never had any problems.
Old 08-28-2009, 06:20 AM   #23
Disco Dean
Disco Dean's Avatar
Oddometer: 1,282
Hairspray has worked for me for years - but it is essential to get the cheapest kind you can - dollar store stuff - as it is basically a mild glue. With no conditioners and fragrance.. unless you like that kind of thing.
Works best if you spray both parts and wait until it starts to become tacky. It is a bit of a trick to get it perfect - to slide on and still get tacky. But it works a charm.
My race bike builder just put on a new set of grips and used the spray on alcohol method and it worked awesomely as well - but both parts must be very clean and smooth - which is why I think you need a bit more stick on the not so smooth surface of the heated coils.
Careful if you wire your grips with the heated elements as it can compress the elements and crack them. I wire all my grips BUT my BMW heated jobs.
Just some thoughts,
Disco Dean is offline   Reply With Quote
Old 08-28-2009, 06:42 AM   #24
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,840
I've also replaced grip rubber on BMW heated grips several times over the years. I agree that the compressed air method is great on other bikes, but the glue and heating elements required careful removal by carefully slitting lengthwise with a razor blade and carefully peeling the rubber like a banana peel. Did I say that you need to be careful and not damage the heating element wires?
Going back on with rubbing alcohol (always some around the house, I'm too cheap to go buy a can of hairspray) on the heating elements and inside the grips and then allowing to dry has always served me well.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 08-29-2009, 07:52 AM   #25
Mr. G
Normal Dude
Mr. G's Avatar
Oddometer: 1,778
Originally Posted by Poolside
Nice mirrors, which brand are they? The mirror surface looks like two 'flats', instead of that wide angle curved glass stuff.
+1 On the mirrors
Are they wider than stock. I'd like to be able to see around my fat ass and wide shoulders
LATER...........Gregg
"If we can manage to convince the Chinese that Jihadists' testicles are aphrodisiacs, within ten years they'll have disappeared..."
Mr. G is offline   Reply With Quote
Old 08-29-2009, 02:39 PM   #26
motorcyclemark
motorcyclemark's Avatar
Oddometer: 164
Wunderlich mirrors
I've seen those mirrors in the Wunderlich catalog, have no idea if they make them or not.
motorcyclemark is offline   Reply With Quote
Old 08-29-2009, 03:55 PM   #27
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
[hijack] Thanks for the lead. They are made by Master View, http://www.mfw-wolf.de/en/products/m...rs/master-view
Wunderlich and Twisted Throttle sell them http://www.twistedthrottle.com/trade/productview/5056 [/hijack]
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 08-30-2009, 02:50 PM   #28
philofax OP
philofax's Avatar
Oddometer: 424
[/hijack]
yes, these are mine. i've choosen the middle arm length and all black. the view
is better, wider and the vibration starts just at 140 km/h, the originals were
unviewable at 100 km/h. YMMV.
i have had them on the 650 gs and then on both of my 1200gs. just another
screw and spacer needed (which was included).
Old 09-03-2009, 02:29 AM   #29
Chris_GS
I like a big pair...
Chris_GS's Avatar
Oddometer: 452
Thanks for the thread, aside from the hairspray discussion, I was going to do this exact thing.
ta!
Chris Coote
VFR800 (VFR# 7)
Chris_GS is offline   Reply With Quote
Old 09-03-2009, 04:07 AM   #30
NVTS
stupid hipster dufus
Oddometer: 669
I can't stand the thin nature of the 1200 GS grips. So I'm going this route as mine aren't worn out yet. NVTS
http://www.excelcyclewerkes.com/inde...s/Page1179.htm
NVTS is offline   Reply With Quote
Times are GMT -7.   It's 01:05 AM.
