Old 05-18-2013, 03:07 AM   #91
tommyvdv
tommyvdv's Avatar
Oddometer: 420
replacing the wiring on the grip. anyone have an idea of the amps going through the wire from control unit plug to heating wire?
aftermarket heating pads.
have a slight feeling this depends on the heating element but just to be sure.
thicker wire wears out after a while due to rubbing.
tommyvdv is offline   Reply With Quote
Old 06-04-2013, 05:02 AM   #92
Fredrik
Oddometer: 81
Wicked
I did the operation yesterday evening.
The left side came of easy but the right side was a PITA.
Fredrik is offline   Reply With Quote
Old 04-08-2014, 08:10 PM   #93
n1tr0
Dual Sport rider
n1tr0's Avatar
Oddometer: 130
Originally Posted by VEGASGSA View Post
Small update..slightly un-seen consequence.
The flange of the new grips..and I would venture to say most aftermarket grips, is, no where near as stiff as the inner flange of the OEM grips. I ride with my thumbs fairly hard against the inner..so the grip flange "gives" towards the controls area and rubs it..no big deal at all..except it slows the throttle action significantly..for me, it may make the OURY's a deal breaker..
I'm thinking possibly ATV style grips would be an improvement since they don't have the inner flange like a motorcycle grip.
If you don't hug the inside of the grip like I do, you may never notice this.
I know it's an old post, but which Oury grips were you using? I usually use
The road grips and pair them with MX style grip donuts. The road grips have a bit thicker waffle pattern and a shorter & thicker inner flange.
Curious as well if they would have fit better with 2 right grips. I've got 1 new set waiting for when my new GS arrives, but they're only $10pt a pair...
n1tr0 is offline   Reply With Quote
Times are GMT -7.   It's 02:54 AM.
