Old 08-31-2009, 11:22 AM   #151
sieg
sieg's Avatar
Oddometer: 2,855
Here's a trick I've used for years on off road and dual sport bikes with good results. Drill and tap the hub for a grease zirk. If the hub has outer grease seals put them in backwards, (they now will keep dirt/water out instead of grease in) then install unsealed bearings. If there are no seals, but sealed bearings then remove the inner seal on the bearing. Now put the wheel on the bike and pump the hub full of grease while rotating the wheel to insure the hub is full of grease, but not pressurized. Some may come out of the seals and make a mess, ride the bike or spin the wheel till it is warmed up and all excess grease should be pushed through the seals by now. Don't over grease it! One shot each time I replace a tire is what I do. The trick is not greasing the bearing as it needs very little grease but the fact that now the hub and bearings are full of grease and there is no void for dirt/water to get in and that is what ruins the bearing.(think of bearing buddies on a boat trailer) After the initial warn up there is no grease mess coming out it you don't regrease it, and you used high quality grease.
sieg is offline   Reply With Quote
Old 08-31-2009, 12:53 PM   #152
Bucko
In a parallel world
Bucko's Avatar
Oddometer: 817
Thumb
Originally Posted by goodtimes
Unless there is something special about the bearings used by BMW (and considering the loads and speeds involved, there probably isn't...), a 6204 is a 6204 is a 6204.
A SKF sealed 6204 is the same (dimensionally) as a NTN 6204, and a FAG 6204, and a Consolidated 6204, and a . . .
Stop by your local bearing house (Applied Industrial, Kaman, or one of the regional/local shops and tell them you need a sealed 6204 (or other size).
Thanks, I understand a little more about bearings and sizes now.
I did what you said and my local industrial supply house is setting me up. This little change should give me as much piece of mind as swapping out the doohickey on my KLR.
Bucko is offline   Reply With Quote
Old 08-31-2009, 01:01 PM   #153
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Originally Posted by upweekis
I sure hope you guys are having these bearings replaced under warranty. That's about the only way to get a company's attention.
+1. Replacing the bearings--while potentially providing some extra margin over the stock bearings (but mostly just providing peace of mind)--is, IMHO, counterproductive to BMW coming up with a proper resolution, not to mention counterproductive to determining the root cause of the problem. The supposition that the bearing quality is suspect is just that...and even if the rating of the OEM bearing is lower than that of an aftermarket one, there's still no guarantee the aftermarket bearing won't fail. It really depends on how much (if at all) some designer at BMW underestimated the loading on the left side bearing. Its quite plausible that *no* 6204 can handle the loads. Furthermore, unless you get specific authorization from The Man, a non OEM bearing may very well give you warranty grief should you have a future catastrophic failure that destroys the wheel. Stupider stances have been taken.
FWIW, my bearing failure was not catastrophic. I rode on it for a good 1000 miles (made a clicking/clunking sound off throttle at low speeds) before taking it into the dealer. Didn't get any better or worse once I noticed it. YMMV, of course.
Those who have not yet removed your wheels, if you have the time, please do so and report the condition of your bearings. Specifically, the rotor side bearing.
bxr140 is offline   Reply With Quote
Old 08-31-2009, 01:35 PM   #154
tmex OP
tmex's Avatar
Oddometer: 2,039
I agree with you conceptually, but many of our bikes are not anywhere near a dealer. My bike is more than 150 miles from a dealer and your suggestion would involve an overnight stay to replace a $15 part. The logistics just do not work out for many of us. Plus that, I want to maximize reliability in the field. It took me two days to get my bike back to my garage - I was not having any fun doing it either. As a practical matter there is no other solution I can imagine other than an upgraded bearing in any case. BMW is certainly not going to redesign the hub.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 08-31-2009, 01:42 PM   #155
Cumminsman76
befuddled
Cumminsman76's Avatar
Oddometer: 8,605
Originally Posted by ROYAL COACHMAN
I have a new 2010 F8 with only 500 miles on it and already thinking about a bearing swap............ I think I need my head examined!
I think you have first hand experience that would make me change bearing if I was in your riding boots.
STURGIS ride report.
2009 R1200 Gelände/Straße Abenteuer
A GS is like chlamydia, it grows on you whether you want it to or not. WhiteManFlail
Save $5 on Smugmug "1alkVgTNLEuyQ"
Cumminsman76 is offline   Reply With Quote
Old 08-31-2009, 03:40 PM   #156
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Don't get me wrong--I see what you're saying. And peace of mind goes a long way when it comes to reliability.
But...your 'only' solution assumes that both A) the quality of the bearing is directly related to the failure of the bearing, B) the quality of a bearing that you source is higher than that of the OEM bearing, and C) a "better" bearing will not fail in the same way as a lesser one.
Unfortunately, thus far, no concrete evidence exists to support any of those assumtions. They belong on the fishbone, for sure, but they're not the only bones.
If you search the parts fiches, that exact bearing part number is used on a *huge* list of BMW motorcycles dating back for years (141 bikes, according to bike bandit), including late model LTs and 1150GSes...bikes that certainly see their fair share of miles and abuse. Not that I keep up on all failures on all BMW models, but to my knowledge there's no systemic problem with wheel bearings. Only the rear bearings on F800GSes have shown an issue. And specifically the two outer bearings. Someone earlier said their sprocket carrier bearing was 'gritty'. When I pulled off my wheel last week, my findings were similar: the sprocket bearing was not loose, but was 'gritty'. The hub bearing on the sprocket side was spot on and, as noted already, the rotor side bearing was very loose.
While I'm not about to rule anything out just yet (it could certainly be as cut and dry as a bad run of bearings), I'm of the opinion that the cause (and therefore the solution) is more likely to be dimensional. We all know that some front axles are dimensionally incorrect--who's to say the the wheel spacers (any of them) don't exhibit a similar condition? Pressing in a $100 ceramic bearing won't do squat when it comes to surviving your adventures through BFE if you're treating your wheel bearing like a thrust bearing.
What about a manufacturing error pressing the bearings into their seats? Insufficient (or excessive) depth...or what about a missed radius in the hub/carrier design, etc?
There's more to this story, methinks.
Old 08-31-2009, 03:51 PM   #157
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Since web searches are fun.
http://www.vxb.com/page/bearings/PROD/Kit7548
Old 08-31-2009, 03:55 PM   #158
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,681
Don't know enough about ceramic bearings, but my first reaction is that they'd be rather brittle for use on a motorcycle.
Old 08-31-2009, 03:58 PM   #159
Cumminsman76
befuddled
Oddometer: 8,605
That's probably because it's the same size bearing. If its a cheap bearing that is becuase they can save $.10 a bearing by going with that supplier.
Old 08-31-2009, 04:02 PM   #160
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,685
6204 silicon Carbide bearing only 169$ each
http://www.vxb.com/page/bearings/PROD/Kit7719
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 08-31-2009, 04:18 PM   #161
tmex OP
tmex's Avatar
Oddometer: 2,039
True, but that has never stopped me before. What I am quite certain of is that BMW will not come to my rescue any time soon. In the meantime I have to do what I can do - assuming I can even get a replacement hub in the next 4-6 weeks maybe.
tmex screwed with this post 08-31-2009 at 04:36 PM
Old 08-31-2009, 05:31 PM   #162
Law Dawg (ret)
Law Dawg (ret)'s Avatar
Oddometer: 820
If memory serves T, you took your wheel to the dealer (two of them wasn't it?) and were told not a warranty item. Is that right? If so the dealer(s) have been put on notice...wonder if the mothership has?
Will someone do some checks on the upgrade bearings please?
Firefly; the way it will actually be...rednecks in space, dealing with the mess made by urban progressives while being hounded by them and all without any goofy alien stuff. Shiney!
Law Dawg (ret) is offline   Reply With Quote
Old 08-31-2009, 05:32 PM   #163
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Not probably, it is the same size bearing. But the point is that if you ordered one for a 2002 1150GS (or whatever bike is on that list), you'd get the same exact part as if you ordered one for a 2009 F800GS. The guy at the warehouse would literally go to the same bin on the same shelf.
But even that doesn't necessarily mean that the part on your F800GS now is the same part (or is even from the same vendor) that you'd get if you ordered a F800GS bearing from your dealer tomorrow.
Operative word being "if". And who's to say the less expensive part is a lower performing part? And...who's to say they even go with the lowest bidder? Its not like the guys in procurement never did a few favors for their favorite vendors...
Old 08-31-2009, 05:50 PM   #164
ROYAL COACHMAN
ROYAL COACHMAN's Avatar
Oddometer: 934
For those of us who need new wheel hubs, why can't BMW simply pull from the assembly line to take care their paying customers who have a legitimate warranty claim
By the way Dennis I agree that one should probably replace their bearings with after market replacements just for the sake of expediency
Glen
2009 KLR 685
ROYAL COACHMAN is offline   Reply With Quote
Old 08-31-2009, 05:51 PM   #165
Cumminsman76
befuddled
Oddometer: 8,605
As far as the first part, I've seen different part numbers that bring up the same part.
For the last part doing favors doesnt allow you to go to the reveiw board with the "I saved the company $X this year. I worked in the R+D department after they went to China for metal parts. Boy the money that saved.
Times are GMT -7.   It's 05:19 AM.
