Old 10-21-2009, 05:03 PM   #661
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,561
Originally Posted by YetiGS
I assume you mean just the new wheel, not the whole damn bike. You and I both have far to many "upgrades" to our bikes to trade them in at this point.
You got that right !
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 10-21-2009, 07:37 PM   #662
classyfun
Oddometer: 34
Question Bearing Size
I asked this on Woody's Thread but never heard back. Would it be possible to spec a new bearing with a smaller circumference? It seams logical to do this and would be easier than honing a wheel hub.
I do not have a lot of expertise to research it but if someone has the required specs I would sure try.
Thanks everyone for your attention to this matter. I am not affected yet but soon will be from all the reports.
Originally Posted by LaPorte
I read somewhere that all five wheel bearings (two in the front wheel and three in the rear wheel) are 6204's. Is this true. If it is, I was woundering what the bore size is on the front wheel hub? Front bearings don't seem to be having any trouble. Last time i looked, the front wheel does the same miles as the rear wheel?
classyfun is offline   Reply With Quote
Old 10-21-2009, 07:46 PM   #663
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,423
One potential problem I see is that people who have changed their bearings report that they go in fine halfway and then get tight. This suggests to me that the hub is tapered, i.e the bearing seats are not parallel. If that's the case, using a smaller bearing won't help.
Speaking of which, I wonder if Woody measured the diameter of the hub at the top, middle and bottom of the hole? Anyone know?
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 10-21-2009, 08:43 PM   #664
LaPorte
LaPorte's Avatar
Oddometer: 498
Bearing drops in
Yetigs
On one of the posted pictures showing the disc side of the hub without the bearing, I think it was the one Woody posted, it shows about half way down the bore you can see a very small lip, a slight differnt in diameter of the hub (smaller) this is where the bearing stops when it's droped in. You can see the lip, the bearing stops at the lip, then needs to be pressed/tapped in passed this point to the bearing seat. The larger bore allows the bearing to be droped into the bore and not be cocked. I think the first part of the bore is 47mm because that's the OD of the seal. The smaller part of the bore is the part in question. What should it be? Woody gave some mesurements that he got when he measure the hub. I don't know what the correct bore should be.
http://www.advrider.com/forums/showp...1&postcount=15
LP
If you don't know where your going don't lead!
LaPorte screwed with this post 10-21-2009 at 08:55 PM
LaPorte is offline   Reply With Quote
Old 10-22-2009, 09:20 AM   #665
LaPorte
LaPorte's Avatar
Oddometer: 498
Ball Bering Clearence chart
Radial Internal Clearance for Ball Bearings
Radial internal clearance provides for thermal expansion and slight misalignment of the inner and outer rings. Internal clearances for ball bearing units are typically greater than those of the same size of radial ball bearings. Proper internal clearance is important for optimal bearing life. Below are the most common clearance classifications for cylindrical bore insert bearings.
RADIAL INTERNAL CLEARANCE FOR CYLINDRICAL BORE BEARINGS
Bore Diameter
d
C2 -
Less than standard
C0 -
Standard
C3 -
Greater than Standard
C4 -
Greater than
C3
MillimeterInchesC L E A R A N C E INCHES
OverInc.OverInc.LowHighLowHighLowHighLowHigh
2.5
0.984
.00024.0001.0004.0004.0007
2.5100.984.3937
.00028.0001.0005.0003.0009.0006.0011
1018.3937.7087
.00035.0001.0007.0004.0010.0007.0013
1824.7087.9449
.00039.0002.0008.0005.0011.0008.0014
2430.94491.1811
.00043.0002.0008.0005.0011.0009.0016
30401.18111.5748
.00043.0002.0008.0006.0013.0011.0018
40501.57481.9685
.00043.00025.0009.0007.0014.0012.0020
50651.96852.5591
.00059.00035.0011.0009.0017.0015.0024
65802.55913.1496
.00059.0004.0012.0010.0020.0018.0028
801003.14963.9370
.00071.00045.0014.0012.0023.0021.0033
1001203.93704.7244
.00079.0006.0016.0014.0026.0024.0038
1201404.72445.5118
.00091.0007.0019.0016.0032.0028.0045
1401605.51186.2992
.00091.0007.0021.0018.0036.0032.0051
1601806.29927.0866
.00098.0008.0024.0021.0040.0036.0058
1802007.08667.8740
.00118.0010.0028.0025.0046.0042.0064
Old 10-22-2009, 11:38 AM   #666
wscollay
Oddometer: 39
C3
My replacement SKF 6204 bearings are C3. Could one then use a CO or C2 that are smaller.
wscollay screwed with this post 10-22-2009 at 11:52 AM
wscollay is offline   Reply With Quote
Old 10-22-2009, 12:10 PM   #667
LaPorte
LaPorte's Avatar
Oddometer: 498
6204-2RS-C3 bearings
wscollay
I don't want to put out bad news, but. The SKF bearing engineer I spoke with, told me, that if the bore is 46.44mm, as indicated by Woody's post when he measured a f 800 GS rear wheel hub, it would still be to tight for even a C5 class bearing. The difference in free space between C3 and C4 class bearings is 20 to 30 microns as it is between a C4 and a C5 bearing.
Look at the chart and do some math and you will see what Woody said is right on the money.
Lst's hope that the powers to be will recognize this as a problem and correct it soon if thay already haven't done so.
LP
Old 10-22-2009, 12:45 PM   #668
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 3,890
Now that we've been through this route of discovery of possible reasons for premature bearing failure on these bikes, you could only assume the hub designer/manufacturer should have to know about all of this, right? This is what they are paid to do. This is their living. So, who designed, and who makes those rear wheel hubs?
Lion
wscollay
LP
Lion BR is offline   Reply With Quote
Old 10-22-2009, 02:19 PM   #669
RedHawk47
RedHawk47's Avatar
Oddometer: 431
C0 and C2 bearings have the same OD as C3 and C4.
The difference is the internal clearances (between the balls, inner race and outer race. The reason to consider C3 or C4 is that a smaller than standard hub bore will compress the bearing outer race and reduce the internal clearance.
Dan
It's never too late to have a happy childhood. -- Tom Robbins
13 Moto Guzzi Stelvio NTX
09 BMW F800GS
99 KLR 650 A13
RedHawk47 is offline   Reply With Quote
Old 10-22-2009, 02:29 PM   #670
RedHawk47
RedHawk47's Avatar
Oddometer: 431
wscollay
LP
I think Woody had a "typo" because the results of the math - the measured interferance - was as if he had measured the bore at 46.94mm. Looking at the photo of his micrometer I read 46.94.
46.44 >> 0.56mm is .022" - you would be able to get the bearing into a bore that much smaller.
Dan
09 BMW F800GS
99 KLR 650 A13
Old 10-22-2009, 04:33 PM   #671
Lion BR
Lion BR's Avatar
Oddometer: 3,890
Did you mean:
46.44 >> 0.56mm is .022" - you would NOT be able to get the bearing into a bore that much smaller.
Old 10-22-2009, 06:28 PM   #672
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,706
Originally Posted by wxwax
Yes, but everything you've ever posted in the basement indicates that you're certifiably crazy, so you don't count.
"Another road remains, but it provides no more. It can only take us away"
]I)Money is offline   Reply With Quote
Old 10-22-2009, 10:52 PM   #673
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 267
Complaint Filed
I filed a complaint with NHTSA. We will see what happens.
mapuda is offline   Reply With Quote
Old 10-22-2009, 10:57 PM   #674
mapuda
Crash Tested
mapuda's Avatar
Oddometer: 267
Pissed Shoot proof read better!
The bearing does not run the wheel turns. And "for which" Arggh
Old 10-22-2009, 11:23 PM   #675
RobStar
Still On Training Wheels
Oddometer: 435
My warranty repair was delayed by a day due to shipping but I've got my bike back and a fresh new TKC80 on the rear to start wearing down.
I'll probably pull the wheel and check the new bearing in a few thousand miles and again when it's time for new tires.
Forget the math... get'ur dun and go ride your bikes!
RobStar
Robert
Las Vegas
2015 1200GS Adventure
RobStar is offline   Reply With Quote
Times are GMT -7.   It's 06:33 AM.
