Old 08-26-2009, 08:40 AM   #61
]I)Money
D NOT I
]I)Money's Avatar
Oddometer: 3,701
Originally Posted by guzzimike
LilGS would you by chance have the part no's (not the bmw part No, the bearing code No) for those bearings and seals?
Something that has bothered me is the wheel spacers, they bear on a seal at the inner end, how is this lubed? One of the seals on my bike appears to be falling apart already.
I'm with you on the quality thing, if they didn't have BMW written on them you'd reckon they were a cheap peice of junk.
For instance the headlight support that on the boxers is steel tubing, on the F8 it's plastic, have a look at it, it is complex and no doubt hugely expensive, but it is as weak as piss, I know, I've busted mine in a low speed off, I fixed it with a bit of sheet steel and pop rivets, but it sure doesn't smack of quality.
$150.00ish USD.
LILGS, thanks for the bearing measurements. I'm going to go ahead and change mine, I think.
Originally Posted by wxwax
Yes, but everything you've ever posted in the basement indicates that you're certifiably crazy, so you don't count.
"Another road remains, but it provides no more. It can only take us away"
]I)Money is offline   Reply With Quote
Old 08-26-2009, 09:12 AM   #62
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
Originally Posted by garandman
Citation? I did a search here for DL650 vavle guides and V-Strom valve guides and only got a couple of results.
It was Feeflow's wife's bike.
This guy got it right...
Originally Posted by v8toilet
Search again...
http://www.advrider.com/forums/showt...=160731&page=5
The entire thread is about the failure but you don't get to the cause until page five.
It's the only case I've ever heard of, some kind of luck.
Boon Booni is online now   Reply With Quote
Old 08-26-2009, 09:36 AM   #63
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,552
My good friend from Idaho just emails me regarding this issue, I had to post it:
"Jeez, why did we waste all those bombs and lives on German bearing factories in WWII."
Too funny !
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 08-26-2009, 10:15 AM   #64
DockingPilot
Oddometer: 9,552
LilGS,
Help my feeble mind if you would mate. What #'s are for the rears and what are for the front ?
3 rear and 2 front, is that right ?
5 x 6204 high speed bearings - sealed Use a good quality bearing that you can source.
3 x 30 x 47 x 7 - 30mm ID x 47mm OD x 7mm wide- seals 2 in the rear and one for front.
1 (do you mean 2?) x 25 x 47 x 7 -25mm ID c 47mm OD x 7mm wide- seals
Front seal, front shaft fits into this seal on the RHS
Thanks,
Frank
I just cannot believe I am doing this at 4k miles.......
Frank Reinbold
DockingPilot screwed with this post 08-26-2009 at 10:45 AM
Old 08-26-2009, 10:52 AM   #65
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,420
Annnnnnd, anyone have a US source for the bearings?
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 08-26-2009, 12:01 PM   #66
tmex OP
tmex's Avatar
Oddometer: 2,039
...and so it goes.
Well, got the wheel into San Jose BMW this morning. Sure enough, the hub is trashed. Tech had to use a torch to get the rotor side outer race out of the buggered hub. Good guys there went ahead and jammed in a replacement bearing in so I can at least roll the bike onto a trailer to bring her home. They did not have to do that, and I appreciate it. Obviously the concern would be that if the bike were ridden it would self-destruct in short order. We shall see what happens next. When I get a replacement wheel or hub I'm just sending both wheels to Woody's to lace on proper rims and strong spokes. I will also install quality sealed bearings. As long as the scooter (assuming some bubbas have not already stolen it) will be down for awhile, I may as well do things right.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 08-26-2009, 01:09 PM   #67
DockingPilot
Oddometer: 9,552
T,
you mean your 800 is where you left it ? Man, I want to move there! In NJ, it'd be gone in a flash !! Good luck, you motivated me to pre emptivly replace mine before my 2k mile trek in 3 weeks.
Frank Reinbold
Old 08-26-2009, 01:48 PM   #68
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,420
Where are folks in the US getting their bearings from?
Semper Fi
Old 08-26-2009, 01:55 PM   #69
Cumminsman76
befuddled
Cumminsman76's Avatar
Oddometer: 8,587
I think Timken has an online store on thier site.
STURGIS ride report.
2009 R1200 Gelände/Straße Abenteuer
A GS is like chlamydia, it grows on you whether you want it to or not. WhiteManFlail
Save $5 on Smugmug "1alkVgTNLEuyQ"
Cumminsman76 is offline   Reply With Quote
Old 08-26-2009, 04:51 PM   #70
LILGS
LILGS's Avatar
Oddometer: 192
Originally Posted by DockingPilot
LilGS,
No worries..
the bearings are exaclty the same for both front and rear. the only difference is in the seals.
the rear hub uses a bearing either side and the cush drive uses a bearing as well as it is a seperate piece. so 3 x bearings on the rear hub and 2 x 30 x 47 x7 seals. there isnt a part number on the seals as your bearing stockist should keep them in stock they are a standard seal and can get them anywhere.
the front hub uses the same 6204 bearing and 1 x 30 x 47 x7 seal on the left side and 1 x 25 x 47 x7 on the right side. this seal has thr front axle shaft run through the seal instead of a spacer. thats why it requires a 25mm id seal.
5 x bearings. 3 for rear and 3 for front
3 30mm id seals for rear and one for l/h/f
1 25mm id seal for r/h/f
i hope this helps..
LILGS is offline   Reply With Quote
Old 08-26-2009, 05:05 PM   #71
LILGS
LILGS's Avatar
Oddometer: 192
Im pretty sure thats only for the distributors to use.
As long as you use a good bearing thats all that matters. I was just lucky mine didnt destroy my hub at the time so i was lucky.. i was pretty mad to say the least, i've had trail bikes to 20k klm in dirt sand mud and crap and have survived that treatment..
replace them even if it is at your expense it may save your life!
this doesnt mean the new ones wont be an issue on the future it just means that it should prevent failure at least with a better quality bearing. you dont need a ceramic or some expensive bearing because mud will get in there and they will in time need replacing again but just use a good bearing.
Cheers
Old 08-26-2009, 05:13 PM   #72
LILGS
LILGS's Avatar
Oddometer: 192
That was my exact approach. all except the part where you had BMW touch your bike again .. not a chance!
do it right and you shouldn't have an issue, perhaps you should complete your little wheel project and send BMwankers the bill?..
everything to do with the wheels are puss!
I now run an excel S7 high tensile Double Sig rims, 8 guage SS HD spokes and nipples and quality bearings/seals.. woody couldnt come up with a combo quick enough so i took it into my own hands..
Good luck.
Old 08-26-2009, 08:13 PM   #73
itsatdm
itsatdm's Avatar
Oddometer: 4,868
I am sure if know if the hub is trashed, but the manual says to apply 100c heat to the hub to pull or put them in.
I am really surprise your dealer would not warranty that item. Seems unusual at 6,000 miles and potentially life threatening. Not exactly good publicity for BMW and I would think it would motivate them to keep you happy.
itsatdm screwed with this post 08-26-2009 at 08:19 PM
Old 08-27-2009, 07:41 AM   #74
DockingPilot
Oddometer: 9,552
I just ordered 5 SKF bearings with seals. I'm just not a gambling man.
Frank Reinbold
Old 08-27-2009, 08:03 AM   #75
ROYAL COACHMAN
ROYAL COACHMAN's Avatar
Oddometer: 933
I think I will follow your lead DP
Who did you order from?
Did you order by size or a part number?
Glen
2009 KLR 685
ROYAL COACHMAN is offline   Reply With Quote
Times are GMT -7.   It's 07:57 PM.
