Old 01-21-2010, 09:12 AM   #826
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,484
Cool, thanks guys. Now I just have to find a time where I can stand to be without the bike for a bit. Kind of tough now that I have the studded tires, just want to keep riding!
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 01-21-2010, 10:15 AM   #827
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
If you make an appointment, you should just be to take the wheel in and walk out with new bearings an hour later.
Scott - Semper Fi
'04 BMW R1150GSA, '05.5 KTM 950 Adventure
Y E T I is offline   Reply With Quote
Old 03-25-2010, 06:39 PM   #828
gwhis
gwhis's Avatar
Oddometer: 543
I was told no warranty coverage of wheel bearings
My bike is in the shop now and they wouldn't even take the wheel off and check the bearings because the wheel didn't have side play in it. I was told that wheel bearings are wear items and not covered by warranty.
It'a a disease and once you have it-that's it, it doesn't leave your body.
Colleen Millsaps, On Any Sunday The Next Chapter
gwhis SE IN
DR650 DRZ
gwhis is offline   Reply With Quote
Old 03-25-2010, 08:22 PM   #829
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
Did you check your bearings? Are they shot? I wouldn't expect my dealer to check my bearings for me under warranty either.
When I discovered mine were bad my dealer initially told me the same thing. I then took the wheel in with the crunchy bearings and they agreed to cover them.
Scott - Semper Fi
Old 03-25-2010, 08:34 PM   #830
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,824
Same here. I had to bring in the unmounted wheel. It got handled just fine after that.
drrags is offline   Reply With Quote
Old 03-26-2010, 02:23 AM   #831
gwhis
gwhis's Avatar
Oddometer: 543
Not covered
Yea, I had checked them and told them that one of the bearings feel gritty when turned with my finger. I had to agree to pay a half hour labor for them to remove the wheel and check it. After checking it they said it wasn't bad enough to need replacing yet. The shop owner also pointed out that I had not bought the bike from them, so I guess that also has an effect on the service rendered to me. Since the the closest dealer is 100 miles from me, I told the owner that I wanted it fixed even if I had to pay. I read on a different site that the dealership had been bought by the Harley dealer and will be moving, so service may improve.
gwhis SE IN
DR650 DRZ
Old 03-26-2010, 04:32 AM   #832
RV8Pilot
Blue,Green,Blue,Gree.....
RV8Pilot's Avatar
Oddometer: 213
Are the bearings still a problem with the newer bikes or was this reserved for just the initial batch? I just bought a 2010 F8, should I just replace the bearings in it as a preventative measure?
1200 GSA-DR650-1961 BSA Gold Star-Moto Guzzi 1100i Sport-Victory Vision Tour-CL77
Vans RV8
RV8Pilot is offline   Reply With Quote
Old 03-26-2010, 04:43 AM   #833
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,200
The problem wasn't the bearings it was the machining in the hub. I imagine that the problem doesn't effect many newer bikes, so I doubt you need to change your bearings.
You probably should check the everytime you have the wheel off though, just in case.
Ducksbane is offline   Reply With Quote
Old 03-26-2010, 06:31 AM   #834
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,466
it's NOT your bearings ,,,it IS your hub
guys i'm flabbergastered that after all the R&D and bench-racing on this thread,,,that all of you are still just settling for bearing replacement....
you can swap out all the new bearings of whatever brand suits your fancy til dooms day,,,if the undersized bore on your bike's rear hub is not brought up to .001''interference fit,,,the new bearing WILL FAIL sooner or later....the early symptoms are a crunchy gritty sensation when you twist the bearing with your finger.
the Rx is
1,,honing/boring the hub out for proper fit ,ie.001'' crush
2,,replacing/re-lacing with a new corrected hub
3,,replacing the wheel assy
FYI,,most everyone that had just the bearings swapped has had to swap them again,,evry 1,000-2,000 miles
demand a solution and not just a band-aid
here's the parallel thread that explains it all:
http://www.advrider.com/forums/showp...1&postcount=15
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 03-26-2010, 08:14 AM   #835
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
Woody, I'm sure you're right, but BMW isn't going to replace the hub after just one set of bearings goes bad as much as I wish they would. I'm on my second set now with about 4k miles on them. I'm going to be checking them this weekend and, if they're shot, I will be requesting a new hub or that they let you re-machine this one. I'll report back after they're checked.
Scott - Semper Fi
Old 03-26-2010, 10:53 AM   #836
Lion BR
I'd rather be riding
Lion BR's Avatar
Oddometer: 4,261
If the problem happened in a low miles bike, at the rotor side of the rear wheel, wouldn't that be enough evidence to kick in the warranty service based on BMW's own assertion of a set of miss-machined hubs?
Lion BR is offline   Reply With Quote
Old 03-26-2010, 10:55 AM   #837
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
Except that BMW has never acknowledged that any hubs were mis-machined.
Scott - Semper Fi
Old 03-26-2010, 11:02 AM   #838
WOLVERINE
Keep her pinned!
WOLVERINE's Avatar
Oddometer: 628
I have 8000kms on mine and no wheel play or any sign of failure at this point. It was a January build date last year so Not sure if that makes a difference. Then again, I have a bigger issue with the bike!
If you think you're free, there's no chance of escape!
2008 R1200GSA
WOLVERINE is offline   Reply With Quote
Old 03-26-2010, 11:04 AM   #839
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,824
They did for me (Honda of Houston). But I suspect a lot of it has to do with how enthusiastic your dealer supports you. And IIRC I already 12k miles on mine. BTW, 10,000 miles later I just checked them and they feel like new.
Hey, does anyone know if the XChallenge rear wheel fits the F800GS?
Old 03-26-2010, 11:09 AM   #840
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
They replaced your hub? Or your bearings?
Scott - Semper Fi
Times are GMT -7.   It's 08:23 PM.
