09-23-2011, 05:03 AM
#1306 |
Oddometer: 188
Is there a process to present this data to BMW in order to affect some sort of warratny claim/recall?
![]() (me hiding behind wall of naivete)
Marc Langlois BMW F800GS BOA #166285 |
09-23-2011, 09:22 AM
#1307 | |
Random Hooligan
Oddometer: 6,259
-Scott- Semper Fi '04 BMW R1150GSA, '08 KTM 450EXC-R, '04 KTM 625 SXC No Pride and Even Less Sense - A Ride Report |
09-23-2011, 09:29 AM
#1308 | |
Built to Last
Oddometer: 3,095
what to present to BMW,,,,
IMHO....you can print out a few of the posts related to this subject,,it's actually recorded on every major BMW forum.... be nice yet firm,,,ask them to please measure the bore to see if it is within spec ie 47mm minus .001'' anything smaller will mitigate premature bearing wear....FYI the early hubs had the disc side measure circa .0025'' under ie .0015'' too tight and the sprocket side .002'' about .001 too tight,,, '' remember ,,,many dealerships don't even have the apparatus or someone trained in this technique..... have them record your complaint,,,let them know you want peace of mind and do not want live in anxiety that the bearing will go kaput every 3-5,000miles remember,,they will give you the official spin that you have a 2,000 mile warranty on any BMW component or something to that effect... the words i want this problem repaired and /or fixed versus please replace them will have way different outcomes ![]() go for it ![]() woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 09-25-2011 at 06:41 PM |
09-25-2011, 02:53 PM
#1309 |
Oddometer: 406
2010 f800gs
Picked up my F800GS in November of 2009 (2010 Model). Watched the bearing problem develop over the next year and whatched my bearings. At 5,093 miles, when replacing the rear tire, I noticed that the bearing were getting notchy. Took the wheel to the dealer. He replaced the bearings, but talked to BMW. He checked the hub OD and found it to be within tolerance. Were talking about the rotor side of the rear wheel. I have since put on 3,689 miles and I am replacing the rear tire again. The bearings still feel like they did when new. When this new rear tire wears out I will check them again. To bad the tire couldn't last a little longer, oh well, its the price we pay to have fun.
![]() I though a little positive might be good to hear! ![]() LaPorte
If you don't know where your going don't lead!
09-28-2011, 10:07 PM
#1310 |
Oddometer: 120
one more
Add me to the list... I had the bearing come apart while I was riding today. It felt like I had low air so I was slowing down before it completly came apart. I have less than 14K on my 2009 F800GS
Adventurer Rider Training - www.advcamp.com |
12-31-2011, 12:16 PM
#1311 |
Really, Really Cool
Oddometer: 3,341
Coming home from dinner last night I heard a squeak and then felt a little thumping.
Pulled over, checked for anything obvious, then limped home (about a mile) slowly. ![]() It has been a while since the wheel's been off so hadn't checked bearings lately but there was no other warning. 13,000 miles on 2009 . |
12-31-2011, 12:23 PM
#1312 |
Oddometer: 2,722
WOW... add another issue to F800's list.
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
12-31-2011, 01:05 PM
#1313 |
Really, Really Cool
Oddometer: 3,341
I still love the bike. I should have been more proactive with the bearings, it's not like I didn't know others had issues. I live in a very salty environment where corrosion is a big problem for everything. Hell, I probably even rode through salty or at least brackish water at some point with the bike. I'm just glad I was in town and not on the highway when I caught it, or it might have caught me. FYI, the wheel still rolled just fine on the center stand and didn't make any noise. There was just the slightest bit of lateral play when shaking the wheel side to side. I'm talking about "do I feel a little play or not?" kind of movement. . |
12-31-2011, 03:26 PM
#1314 |
gonzo
Oddometer: 580
This was my experience as well, when my bearings started to go. Luckily I caught them before they totally grenaded, but I could see the beginnings of scoring/heating evident on the axle when I pulled the wheel off and discovered the crunchiness of the bearings.
Stubborn and Stupid "It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be the way." ~ Rubin, Road Trip |
03-04-2012, 09:39 PM
#1315 |
Oddometer: 9
at 10000km and less than 1 yr old i was told that my bearings are not covered under warranty. only covered for 6000km. looked in the manual, and it actually states 7500km. looks like i am sol. they also wanted $380 for 10,000km service, so they can cram it.
03-05-2012, 08:49 AM
#1316 |
MoveAlongNothingHere
Mine were replaced under warranty. Twice! Keep on-'em.
~MK~ F800GS AMA-262640 |
03-05-2012, 01:05 PM
#1317 | |
Built to Last
Oddometer: 3,095
totally un -acceptable....
When most motorcycles get 40-60,000 trouble-free miles as the norm on oem bearings....and i can say this from my perspective of 39 years doing this kind of work for every manufacturer in existence,,then track down and locate the source of the 800GS rear hub/bearing failures....4 years ago,,,, i'd humbly submit the following threads for you to peruse and glean what ya need to press your case.... be calm,,,share your findings,,,record your attempts at getting it it fixed when /where via copies of your work/repair order,,,request the hub be measured etc etc http://www.advrider.com/forums/showp...postcount=1308 http://www.advrider.com/forums/showthread.php?t=505577 http://www.advrider.com/forums/showthread.php?t=637591 I'm a firm believer that the higher ups in BMW,,ultimately want you to be a happy /return customer... ![]() good luck woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
03-05-2012, 03:26 PM
#1318 |
Oddometer: 2,871
03-05-2012, 03:34 PM
#1319 |
Dorkus Malorkus
Oddometer: 1,772
Just thought I'd chime in again... BMW replaced my hub 26,000 miles ago under warranty for this bearing issue. 26,000 miles and rough roads in Central America and Mexico later and the bearings are still going strong. I really thought I, and Wild West Honda had set a precedent almost two years ago. I'm bumming that after all this time it's only been a very select few that have been successful with this issue. BMW certainly knows about this issue, and for a dealer to not even replace the bearings is unacceptable, IMHO.
03-05-2012, 04:36 PM
#1320 |
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 413
Seems like inmates in the Great White North don't have as strong of consumer protections and BMW is just taking advantage of cost savings. Thought I saw a number of posts that BMW was also not covering the leaking valve cover gasket which is an acknowleged problem and covered for those of us State side. Bummer, but goes to show what corps will do if allowed to run free.
On topic; I plan on having my dealer check out mine when I send it in for it's annual checkup, along with the rear caliper not floating as it should. Will report back if anything is amiss.
F800GS Mag/Black 2009 "Faucon GriS" Farkles; Garmin GPSMap478 in a TT cradle, throttle Rocker, Airhawk seatpad, Pivot Pegs, Renthal grips, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard. Wishing for farkles; If/when I can ride offroad better- suspension, rims. |
