01-27-2013, 04:32 PM
#1456 |
Oddometer: 323
01-27-2013, 07:39 PM
#1457 |
Red Clay Halo
Oddometer: 11,176
On other bikes, I've had very good success with heating the hub with a heat gun. I've had 2 sets basically drop out of the wheel after heating and flipping the wheel over. Usually a minimum of tapping is all that is needed to get them out once heated.
Same for installation as well, except the bearings usually go in the freezer for a half hour before I try to install them in the heated hub.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx You can be Han Solo, and I can be another Han Solo... |
01-28-2013, 09:05 AM
#1458 |
Oddometer: 15
Noob - how to check wheel bearings
Hi folks,
I recently bought a used 09 800GS with 20,000kms. It is under factory warranty until April and I will get it into the dealer for a look over/service before then - but in the meantime - is there a link or sticky to "How to check your wheel bearings"? I've read through the vast majority of this thread and searched - but my eye's may have glassed over and missed it.. Appreciate any help. |
01-28-2013, 09:32 AM
#1459 |
Oddometer: 15
04-29-2013, 10:04 AM
#1460 |
Oddometer: 115
A question for those in the know -
I am replacing the bearings in my F800GS. The seals that the bearing shop had were 8mm thick instead of 7mm. Will these be OK or should I look around for some 7mm thick seals? Thanks Paul
EEUC |
