Nice? 30 13.04%
Nasty? 33 14.35%
Nasty but nice? 167 72.61%
Voters: 230. You may not vote on this poll
Old 02-05-2011, 07:17 AM   #1531
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,203
Originally Posted by Dirtyboydeadly View Post
What about a good wicked woman
Or a wickedly good woman
Old 02-05-2011, 07:30 AM   #1532
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
Originally Posted by pjcr12 View Post
You have to choose?
Purely theoretical dear fellow, not least as I have no choice in any matters at this time
Or at least so few reserves to combat 'not successful' so as to lead to the conclusion that it is better to have not tried and not had 'not successful' than ever to have tried at all, and also had 'not successful then too ergo 'Nothing Cannot Be Destoyed' ergo un-met non-expectations are so much simpler than un-met expectations ergo 'Nothing Cannot Be Destoyed' ergo rtp to end...
Old 02-05-2011, 07:32 AM   #1533
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
All permutations are under theoretical consideration.
Old 02-05-2011, 10:47 AM   #1534
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
Forgive me, but I need to take this opportunity to remind you all that your subscription renewals are now due. If you will all just forward me the 1000 per visit fee now due and you can continue to enjoy (?) the thread, and, at no extra cost to you - NOW IN 3D!?! -
Old 02-06-2011, 03:59 PM   #1535
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
Ongoing jobs list...
Some jobs to get DMW back on the road, some done after:
  • * New rear tyre 2nd hand M/Works WHR00001 . 110 Avon Roadrider? i.e. 400x18
  • New oil filter/sort oil cooler feed SIA37575
  • * Replace 2 or 3 burnt wires in the harness. WD40 everywhere. Find source of problem. Heatshrink some ends on unused clocks plug. Heatshrink u turn on charge warning light bypass.
  • * Fix horn so it's no longer blowing fuses (!)
  • Small baffles inserted into exhaust end? i.e. Highway hawk? or similar? Fit braided bendy sections of flexible pipe on exhaust out (adaptors needed?) with Supertrapps on far end? (pj currently has flexi pipes?)
  • Front drive shaft gaiter clip TRA30297
  • Edging on plate 11mm.
  • Mount flyscreen properly, ally strap, brackets etc. Find flyscreen!?!
  • * MOT/Tax/Insurance swap
  • Refresh speedo (battery/spare unit?) - bike type
  • Er...
* Have to be done to get on road, others would like to do.
Jobs for STD1
  • Battery? ELA59652 current one screwed.
  • Battery rubber straps FRA43562
  • Dashboard volt meter replacement? Current one very jumpy. Does PJ have one? Will my other 1 work or fit?
  • * Tighten steering head bearings v slightly.
  • * Check Fork tops tightened slightly? & replace fluid. Oil leakage from top - O-rings? Bars off, big socket @ shedquaters. Book torque?
  • * Choke return springs (current don't fully return chokes) FUA37370. Later 'cable/spring closing' rather than earlier 'wires push shut' type. Or shorten springs already in place without snapping them...
  • Rubber strips between fairing & Pockets FAA07190 Not a big issue but pockets are wet thru without. DIY store options cheaper. Briefly investigate.
  • * Replace air screw in left carb (pointy end mangled) FUA35302 Causes carb imbalance & sooty plug on one side. Get carbs adjusted via magic Dave ear.
  • * Side stand spring pivot plate (just 1.50!) - is it 1 or 2?, how are the springs? FRA10739 & FRA10721 - where was the previous discussion & pics in this thread? Do please find it for me dear minions of mine...
  • * Top strip 'sidelight' bulb? LIA63576
  • Pannier clip, canibalise extra case from Asstrall
  • * Cut section from centre stand
  • * Kurerust on stand & bare sections
  • Er...
planktonnn screwed with this post 03-14-2011 at 05:14 AM
Old 02-07-2011, 12:21 AM   #1536
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
Laydees n Gennelmen...
If I could take this opportunity to remind you of the Martha Farquar motto - CAUSEM OMNI DESPERANDUM, and ask that you all try to carrry the spirit of our motto with you into every sphere of your lives.
Thank you.
Carry on.
Old 02-07-2011, 06:48 AM   #1537
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,203
Hang in there Planktonn.
We're rooting for you, mate.
Old 02-08-2011, 06:26 AM   #1538
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
Why Kubica is in the trouble he's in...
planktonnn screwed with this post 02-08-2011 at 03:53 PM Reason: Link edit
Old 02-08-2011, 06:28 AM   #1539
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
Forgive the goreish interest, but I'd been trying to work out what happened -
Old 02-08-2011, 06:30 AM   #1540
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
I think that's now clear...
Old 02-08-2011, 08:14 AM   #1541
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
I am reminded of the truly inspirational Alex Zanardi, and he rides a BMW -
Old 02-08-2011, 09:27 AM   #1542
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,644
My life is a series of cubes.
crazydrummerdude is offline   Reply With Quote
Old 02-08-2011, 10:02 AM   #1543
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,106
Any cube may be filled with a series of scaled spheres.
In other news I got some more modern windows put in, but I couldn't afford the latest models...
Old 02-08-2011, 10:41 AM   #1544
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,203
Har and har...
Old 02-08-2011, 05:04 PM   #1545
Bloo
Jack Russel Dodger
Bloo's Avatar
Oddometer: 97
Here's one of mine
Finally figured out how to post pictures so here's the R60/6.
I know its a cafe poser but its fun.
R60/6
R100RS
Bloo is offline   Reply With Quote
Times are GMT -7.   It's 03:15 AM.
