Nice? 31 13.30%
Nasty? 33 14.16%
Nasty but nice? 169 72.53%
Voters: 233. You may not vote on this poll
Old 07-31-2011, 09:35 AM   #1876
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
wd - Deus Ex Machina
Old 07-31-2011, 06:36 PM   #1877
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
Create a perfect sketch of your accident.
Old 07-31-2011, 06:41 PM   #1878
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
La Calera
Old 07-31-2011, 06:47 PM   #1879
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
A Batpod replica
Old 07-31-2011, 07:35 PM   #1880
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
So it seems somebody has been to the ear of the pig? In other news I've been at the spanners.
  • The rear engine mount bolt got loosened so that I could pad out the exhaust brackets with an off-cut of exhaust wrap. The claps are 40mm, the downpipes are s/s aftermarkets with their mouths stretched to 40, but their main runs @ 38mm. Thus the pipes are not gripped, and because there are no end cans (mounted to the frame, giving a fixed rear point) the downpipes can shift forward from the heads by 3/4 of a centimetre when the throttle is blipped. Variable length exhausts are of interest, as are variable inlet tracts, but loose is something else.
  • I've been washing my clothes 3 times a day and I may just about have broken the back of the fish thing. I am not looking towards wearing them though, as body heat may unfortunately bring it all out again. I've tried to warn people that they sit next to me @ their peril.
  • I cut another mini stud for the left rocker cover, as I had a selection of threaded rod available, and popped off the cover to insert the replacement. In the process the thread on the centre bigger stud finally gave up the ghost, so I came back up 3 floors to sift thru the 'magic bucket of bolts & parts all tipped together' to find a new one I had. I couldn't find it, but then I have no idea where anything is in my boxed up shed, which is the least I deserve. I cut a replacement from a larger threaded rod & very carefully set about inserting it into the head, as I could really do without a fucked thread just there. All went well, and even ripping the gasket by mistake didn't ruin the job. I won't really know until it's had a good run but it all seems good for now.
  • I then set about thinking how I was going to repair the tail light/plate/mudfenderguard mount as mentioned before. I think sometimes it's really best to sit around a bit and ponder, as the early ideas I came up with would never have worked, and it took me some time to fashion a self springing flexible mount from a flat strip of aluminium. I really can't visualise things internally, nada, so working this stuff out takes a bit of a while. That's what happens for we visualexic.
  • Not being in possession of my own island, I have to stop these things at a reasonable time, but I was able to get it all on & tight before the proles started heckling. Just a couple of little bits to finish off & the jobs done.
planktonnn screwed with this post 08-01-2011 at 03:58 PM Reason: ir+o
Old 07-31-2011, 08:23 PM   #1881
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
Arghhhhhhhhhh
Kidney stones...
Old 08-01-2011, 11:33 AM   #1882
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
Old 08-01-2011, 03:06 PM   #1883
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
Online parts & shop manuals @ dansmc - no relation :-))
Pictured - PJCR12s new lowrider :-D
Old 08-01-2011, 03:10 PM   #1884
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
Fiche
Old 08-01-2011, 03:17 PM   #1885
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
Rockerboxer
Old 08-01-2011, 03:19 PM   #1886
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
BMW bike engine & chassis numbers, + other info resources
Old 08-02-2011, 06:27 AM   #1887
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
Old 08-02-2011, 10:57 AM   #1888
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
a message to you...
Old 08-02-2011, 01:17 PM   #1889
pjcr12
Stercus accidit
pjcr12's Avatar
Oddometer: 801
Hmmmm.......a little high for my liking
pjcr12 is offline   Reply With Quote
Old 08-03-2011, 07:09 AM   #1890
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,172
Vyrus Moto2
planktonnn screwed with this post 08-03-2011 at 08:12 AM Reason: add pic n text n fixlink
Times are GMT -7.   It's 09:46 AM.
