Nice? 31 13.30%
Nasty? 33 14.16%
Nasty but nice? 169 72.53%
Voters: 233. You may not vote on this poll
Old 05-09-2013, 11:35 AM   #4096
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
Studio in the sand...
G'is a job...
http://downloads.bbc.co.uk/podcasts/...0326-0905a.mp3
'The music of refugee camps of the Saharawi people in Algeria and their efforts to bring their forgotten plight to international attention with a new studio in the desert.'
You see two of my intersecting trades are Audiologist & Music Tech Trainer...
planktonnn screwed with this post 05-09-2013 at 06:38 PM
Old 05-09-2013, 06:11 PM   #4097
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
Todays pictures were brought to you by the search-terms Airhead Swinging Arm & Braced.
Tho/ough I flush cookies & other cached items both on this machine & in any remote identities I find it interesting that Google image search increasingly primarily throws up images from ADVriders based sources in these search results. This must say something about the efficacy & reach of this site and its envelopment of the subject of airheads...
http://www.computerdoctorswebsitedes.../SEO-FAQs.html
planktonnn screwed with this post 05-09-2013 at 06:20 PM
Old 05-09-2013, 06:50 PM   #4098
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://www.largiader.com/tech/oilpan/
http://www.motoren-israel.com/produc...il-filter.html
This would, tho/ough, obviate the oil cooler feed as usually applied.
planktonnn screwed with this post 05-09-2013 at 06:57 PM
Old 05-09-2013, 06:56 PM   #4099
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
Unless one used one of these ones?
http://www.motoren-israel.com/produc...5dc2f1be1cec6d
Exquisite tho/ough the pairing is, it would come in at something around €498* excluding import duty & carriage.
* 420.42 or $649.33
planktonnn screwed with this post 05-09-2013 at 07:07 PM
Old 05-09-2013, 07:19 PM   #4100
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://www.motoren-israel.com/produc...ising-kit.html
Or for €199 ($259.57/168.01) one could raise the engine by approx 3mm, tho/ough I don't see any specific ref to forward movement? On the other hand the seeming rearwards positioning of the frame connection bolt holes does seem to give forward movement?
I wonder if the external filter/deep sump & applicable oil cooler fit with this?, the 1st pic seems to indicate it's possible? Or at least that a sump deepening ring can be used in co-ordination with the risers? Would the front filter foul the exhaust crossover pipe or bring it into too close proximity re heat transference?
It's be interesting to see a block with a variety of their products applied.
planktonnn screwed with this post 05-09-2013 at 08:01 PM
Old 05-09-2013, 07:27 PM   #4101
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://www.motoren-israel.com/produc...th-EG-ABE.html
Given the lottery end of Lottery or Lobotomy* I'd like to run one of these run with just one of my Supertrapp Spark Arrestor end-cap strapped on, though I suspect the pipe may foul my braced swingarm?
http://www.maradyne.com/supertrapp/hiw.html
Old 05-09-2013, 07:41 PM   #4102
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://www.motoren-israel.com/produc...r-gearbox.html
A cheap & useful addition which brings the functionality of a K series engine oil level window to an airhead gearbox, also allowing one to monitor the condition of the gearbox lubricant.
Of course all of these things are un-gettable, as I am a pauper*
planktonnn screwed with this post 05-09-2013 at 08:11 PM
Old 05-09-2013, 07:43 PM   #4103
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://www.motoren-israel.com/produc...-elektron.html
An alternative method of increasing oil capacity...
Old 05-09-2013, 07:47 PM   #4104
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://www.motoren-israel.com/produc...-trigger-.html
A variant on the 336 cam with the following characteristics:
Oez Spr AO/AS/EO/ES NV Hub MH HoT Best.-Nr.
336 110 104/52/64/92 N 8.60 M 3.6 114032
Oez: duration of valvelift, degree crankshaft
AO: exhaust opens, degree crankshaft before BDC
AS: exhaust closes, degree crankshaft after TDC
EO: inlet opens, degree crankshaft before TDC
ES: inlet closes, degree crankshaft after BDC
NV: N means: following information is for cam lift V means: following information is for valve lift
Hub: camlift of valvelift, mm
MH: M means: for mechanical valve clearance H means: for hydraulic valve clearan
HoT: camlift or valvelift at TDC, mm
Old 05-09-2013, 08:09 PM   #4105
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
* from previous post...
* A poor thankless wretched pauperised ingrate begging mendicant, impoverished broke & broken. A deprived indigent necessitous wiped out conked out disfavoured destitute stricken bankrupted disadvantaged needy ruined waif.
planktonnn screwed with this post 05-09-2013 at 08:14 PM
Old 05-10-2013, 03:44 AM   #4106
dirtsurfer
Challenged Adventurer
dirtsurfer's Avatar
Oddometer: 2,021
That right there is a brilliant looking bit of kit . Who has fitted one that will vouch for its merits?
dirtsurfer is offline   Reply With Quote
Old 05-10-2013, 06:13 AM   #4107
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://w6rec.com/duane/bmw/exhaust/
Old 05-10-2013, 06:14 AM   #4108
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://www.advrider.com/forums/showthread.php?t=508828
Old 05-10-2013, 06:24 AM   #4109
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
Had we not copywritten the nomenclature already? Tsk tsk...
http://www.who-sells-it.com/cy/airhe...008-18232.html
Still, they may have their uses...
Old 05-10-2013, 06:27 AM   #4110
planktonnn OP
.also, i am a twat
planktonnn's Avatar
Oddometer: 4,179
http://www.bmwmoa.org/forum/showthre...6-ISDT-Airhead
Times are GMT -7.   It's 05:06 PM.
