Old 08-29-2009, 03:06 PM   #16
NCJ
NCJ's Avatar
Oddometer: 3,283
Originally Posted by Little Faus
The oil cooler is from Setrab, a Swedish outfit, cost about $60.
Thanks for posting that up - I've been googling around for an
appropriately (both thermally and physically) sized oil cooler for our
KL250's rather hot running little engines and so far everything I've
found have been sorta automotively clunky and large - Beet, Jeggs,
various a/t coolers etc....
That Setrag appears to be just about right. Pricing looks good, too.
Looking in to it.
NCJ is offline   Reply With Quote
Old 08-30-2009, 01:37 AM   #17
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
Sorry for the hijack. That really is a trick set up and I like the way you incorperated the rock guard for the headlight. When you turn the bars to the stops there's no problem with the hoses binding?
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 09-05-2009, 06:11 PM   #18
screamin injin
FUBAR
screamin injin's Avatar
Oddometer: 2,519
Looks good, just did mine.
screamin injin is offline   Reply With Quote
Old 09-05-2009, 06:18 PM   #19
FREDO RIDER
I'll find my way !
FREDO RIDER's Avatar
Oddometer: 666
Cool ! Where... Where...
Love to see a closer picture
FREDO RIDER is offline   Reply With Quote
Old 09-05-2009, 07:39 PM   #20
screamin injin
FUBAR
Oddometer: 2,519
Yeah, wasn't visible, so I took a fresh one.
Got it from JC Whitney and used stainless sink connectors sprayed black.
Old 09-05-2009, 07:57 PM   #21
Ben99r1
Ben99r1's Avatar
Oddometer: 3,081
screamin injin. What the temp rating on those water lines? Ben
Ben99r1 is offline   Reply With Quote
Old 09-05-2009, 08:04 PM   #22
vanpelt999
08 xr650l
vanpelt999's Avatar
Oddometer: 412
it,s not high enough, those hoses will break down and float crap all over the inside of engine.
vanpelt999 is offline   Reply With Quote
Old 09-06-2009, 10:13 AM   #23
screamin injin
FUBAR
Oddometer: 2,519
you think they will? Oil looks good, only had an issue with one touching the header.
Old 09-06-2009, 02:04 PM   #24
XR750
Oddometer: 23
One more shot.Attachment 214389
Nice work. Not to be critical, but it looks like you didn't push the hose on the fitting far enough. I don't know what the oil pressure is (40psi, 60psi, ?) but having that hose come off would not be a good thing! That push lock hose can be tough, best method for swivel elbows like that is to lock a male fitting in a vice, tighten the female elbow on, wear some gloves, and push like your life depends on it.
XR750 is offline   Reply With Quote
Old 09-06-2009, 03:52 PM   #25
vanpelt999
08 xr650l
vanpelt999's Avatar
Oddometer: 412
I have made a cooler for mine, ended up finding out that auto trans line is rated out to 255-260, as far as the pressure in those lines its not much at all, its all volume, maybe 2-3 psi if that, its not to say that if one of the lines got clogged that the psi would go up high.
Man don't take my word for it, go down to the auto parts store and talk to them about heat ranges on rubber hoses, the ones you are useing don't have a range because of there intended use.
Old 09-08-2009, 03:40 PM   #26
Ben99r1
Ben99r1's Avatar
Oddometer: 3,081
Google a company named THE HOSE MAN. They should be able to replace you water line. They make custom hoses for sort of apps. Ben
Old 09-08-2009, 04:09 PM   #27
truck6driver
The Fireman
Oddometer: 7,496
Here is my JAGG oil coller set up. Has been on the bike now for 10 years with no issues.
Here is the hose routing.
Ray
Life has F@#ked with the wrong man. I will come out on top. Just watch.
truck6driver is offline   Reply With Quote
Old 09-08-2009, 04:49 PM   #28
Bbasso
my name is Rob
Bbasso's Avatar
Oddometer: 1,878
Ray,
Your hottest temp since the oil cooler has been on the bike?
Also, I can't really see how it's mounted. looks like it attaches to the bike in only one place and then kinda stands up?
Bbasso is offline   Reply With Quote
Old 09-08-2009, 04:54 PM   #29
screamin injin
FUBAR
Oddometer: 2,519
Thanks guys, I'll check on some different lines.
Old 09-10-2009, 07:22 PM   #30
Little Faus OP
Little Faus
Little Faus's Avatar
Oddometer: 50
Oil cooler placement
I see two problems with mounting your oil cooler on the side of the frame, truck6driver. One is a crash on the left side. The other is the amount of air flow getting through the oil cooler. One advantage with your placement is the length of the hoses. So far my setup has had no problems. BTW, I saw that funny thread about the KLR. My bike weighs about 330 lbs. fully fueled, and will CRUSH a KLR in the dirt. Its also more reliable without all that doohickie crap. Just as good on the street, too.
Little Faus is offline   Reply With Quote
Times are GMT -7.   It's 03:51 AM.
