Old 10-07-2013, 04:53 PM   #151
JRWooden
Oddometer: 4,293
Originally Posted by Gangplank View Post
If you mean the roll over safety valve then yes they do.
GP:
sorry to be fuzzy ...
In addition to the tip-over valve I think I understood that the EU bikes also have P/N: 16 11 7 721 943 "VENTILATION VALVE"
the pressure/vacuum check valve but I could be wrong...........
Old 10-08-2013, 09:57 AM   #152
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Originally Posted by JRWooden View Post
GP:
According to realoem.com it looks like they do have it. What they don't have is the charcoal canister and the entire Ventilation Emissions Monitoring System parts 16 13--- and the FUEL TANK BREATHER VALVE no. 13901465030 (04 in the diagram below).
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 10-08-2013, 11:07 AM   #153
JRWooden
Oddometer: 4,293
Thanks GP
I didn't realize they had the Euro parts fiche as well...
and yeah... looks like the ventilation valve is a common part on both bikes:
16117721943
Old 10-30-2013, 10:54 AM   #154
Full Power
Oddometer: 1,531
My 2013 model looks very similar.... but I can't figure out HOW to remove it.
Unplugged everything, can't fit it through the frame rails, it appears TRAPPED, as if they welded up the frame around the charcoal.
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 03-11-2014, 05:26 PM   #155
20Fingers
MCarrera GS-Giants
20Fingers's Avatar
Oddometer: 139
I found the same problem!
I have the same issue, not enough room to remove the canister and I found nothing with the 2013 F800GS, specifically. Unless someone comes up with a way to remove the canister, without pulling the rear shock, I am simply going to alter it and leave it in place. This will save some time if I ever need to return the bike ti OEM status.
A dedicated rider in central Maine. I offer tour and ride support to anyone traveling through, mapping help online, Q&A by email, just about anything adventure riding and camping related!
20Fingers is offline   Reply With Quote
Old 03-01-2015, 02:36 PM   #156
(I^2)R/746
Rider
Oddometer: 175
You guys are funny. I just did this in like 30 minutes. Did it just like the R1150GS. Tank vents to ground old school style, took off the solenoid to the TB's, stuck a bolt in the hose to plug it and secured with safety wire, left the plug disconnected to the solenoid no problems. Can was a pain to get out took some hassle had to remove the front sprocket guard but whatever. Need the space for the new shock I'm getting it has high and low speed compression. Anyways runs like a champ just like my other GS. If they start smogging bikes in CA I'll probably move to OR or WA. Place is already stupid enough with gun laws, divorce laws, taxes..... you name it. Don't get me started on the hassle I went through to smog my 49 state truck I bought here from a dealer used and have never had out of state. Stupidity. Anyways easy deal guys just freaking do it.
(I^2)R/746 is online now   Reply With Quote
Old 03-02-2015, 04:12 PM   #157
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,763
Horsepower, the 2013 bikes and newer might be different with the larger fuel tank.
Pre-2013, is easy, and yes mine happened to fall off during some routine maintenance.
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 03-03-2015, 12:05 AM   #158
(I^2)R/746
Rider
Oddometer: 175
You Sir, are the very first person to name me by my translated user name! Somebody finally got it
Yes mine is a 2009 I assume some stuff has changed. I was mostly concerned the system would miss the solenoid (throw an error) but it hasn't. It was so similar of a setup to my 2002 R1150GS I was pretty surprised. Chances are it hasn't changed to this day outside of routing and placement. Anybody that understands the basic principle of what is mechanically required should have no problem. For the rest of the folks.... this thread delivers! Just encouraging people to get in there and get the job done it's so easy. As for the "smog cops" coming to get you I think there's just as much a chance of getting busted for taking the tag off your mattress.....
Old 03-03-2015, 07:33 PM   #159
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,763
746 is the common conversion from watts, then... well just call me a geek engineer.
From the complaints, above it almost sounds like the fuel tank intrudes on the space by the canister and makes it difficult to remove on 2013 and newer bikes. But maybe I'm reading wrong.
Times are GMT -7.   It's 02:46 AM.
