Old 03-18-2012, 11:09 AM   #106
JRWooden
Oddometer: 4,267
Originally Posted by ebrabaek View Post
Yeppers on the 24 month warranty on the parts... At least thats what my dealer states as well. Personally I would rip out the cc... Just for good measure. I reinstalled the pressure/vacuum valve in my filter....as it is minimizing the fuel oders venting to the outside...and I have had no issues with over pressurized tank. My opinion..... Even with an over pressurized tank....ie... malfunctioning vent system..... it will NOT cause the tank to crack...... You would need to engage with pressures and vacuum numbers....far greater than what the bike would tolerate..... I really think bad casting is the issue here.... Mine is '09....HOT desert.... lots of uv..... not a thing... Just imho....
Erling
Thanks Erling!
Maybe they will have the difficulties ironed out in 2 years .... if not I wonder if the 2-year clock starts over when I get the replacement ... replaced ...
I'm going to check the pressure/vacuum valve my self, and confirm the canister is free-flowing ....
Then have a cold one and comtemplate my next move ...
Old 03-18-2012, 11:34 AM   #107
L.B.S.
Oddometer: 1,421
Has anyone heard of a single instance of a US model F800S or ST tank ever cracking? I haven't. They use the same charcoal cannister and emissions system (albeit in a different location, but all the parts are still there)
There have been many instances reported of stall outs and poor running due to plugged up cannisters and so on, but no cracks ever appearing. (like I say, that I know of)
So. Either the material, the shape, or the parts used ie: the pressure/vacuum valves, have something subtley different enough to do this.
If the hoses, and pressure/vacuum valve thingies are the same as the S and ST models, the CC itself is identical, then it boils down to if the tank material or construction requirements are changed, or the actual shape of the thing.
Also the newer R models are different, both US and Euro, but again, no instances of cracking has been heard of by me.
Maybe the plastic just can't be molded in the specific shape needed on the GS. Too sharp bends or something. There is a slot molded into the top of the GS tanks for a frame brace that is not present on the S, ST and R models.
L.B.S. screwed with this post 03-18-2012 at 11:39 AM
L.B.S. is offline   Reply With Quote
Old 03-19-2012, 11:32 AM   #108
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,493
I had a very high pressure in my tank every time I filled up during a long ride around town (> 50 miles)
My tank was later replaced (after signs of cracking) and the Y fix completed - No more large pressure releases since... why ?? i don't know.
Warranty over now....The CC gets the boot this weekend!
Note:
You can test the electronic valves with the GS911 device.
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass screwed with this post 03-19-2012 at 01:01 PM
HighTechCoonass is offline   Reply With Quote
Old 03-20-2012, 08:10 AM   #109
JRWooden
Oddometer: 4,267
Note:
That is very weird.... if I understand how this "system" works ... a the presents or absence of a properly functioning CC should not change how much pressure can be built up in the tank as the CC is "pass thru" and the little pressure-vacuum valve, which is also installed on non-CC bikes controls that pressure.
JRWooden screwed with this post 03-20-2012 at 08:33 AM
Old 03-20-2012, 08:30 AM   #110
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 506
Let me add this, as Joel has been helping me with my 2011 bike that has been pressurizing the tank.
The pressure-vaccum valve should let air pass freely TO the tank, and slowly away. The check ball has microscopic pores that let air away from the tank at a very slow rate. Problem is, within 6500 miles and 1 winter's storage - my pores were starting to clog and were restricting flow away from the tank too much.
The ball can be removed. The cylinder splits into 2 pieces. This way, your tank still vents great, AND the fumes get taken care of by the CC.
Thanks go to Joel on this one, I'm just relaying knowledge to the collective.
NCD is offline   Reply With Quote
Old 03-20-2012, 08:35 AM   #111
JRWooden
Oddometer: 4,267
The pressure-vacuum valve should let air pass freely TO the tank, and slowly away. The check ball has microscopic pores that let air away from the tank at a very slow rate. Problem is, within 6500 miles and 1 winter's storage - my pores were starting to clog and were restricting flow away from the tank too much.
THANKS NCD...
I missed that post somehow... I did not realize that the check-ball was porous (well supposed to be porous) ...
I'm not sure I get the point of that valve, but I'm sure there IS a point.....
Taking the ball out, or maybe just replacing it with an in-line coupler might be a plan...
Old 03-20-2012, 08:46 AM   #112
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 506
He did say that very early bikes were a spring loaded valve, instead of porous.
WARNING: I haven't tested running the bike this way yet, so who knows - I may end up with a canister full of fuel. Now with the check ball gone expanding fuel has free run to the canister.
Old 03-20-2012, 11:03 AM   #113
JRWooden
Oddometer: 4,267
Nut'n is easy is it......
I sure would not think fuel would run all the way to the canister unless the bike was upside-down in which case the tip-over valve should be closed, or that the bike was really overfueled.... ???
Old 03-20-2012, 04:46 PM   #114
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 506
Remember, the gas coming out of an underground tank might be 55 degrees. Top off your tank on a hot sunny day and it's going to expand sending air pressure out that vent. Now, hang a nice, sweeping right hand corner and the gas hits that upper corner of the tank - - and out the vent line it goes - - straight to the CC.
We'll see soon enough.
Old 03-21-2012, 06:20 AM   #115
HighTechCoonass
Oddometer: 2,493
yeap the way I see it ... if you dont need the CC you dont need the valve... the valve must be to limit the chance on the CC filling with gas ... No CC no Valve.
Gas expansion, flipped bike, etc. how does Honda do on the dirt bikes?? F it. Let it go thru the hose on the filler cap...
Old 03-21-2012, 07:58 AM   #116
ebrabaek
Oddometer: 4,763
I agree with HTCA above..... The valve is not needed. .....But I want to add this function that I mentioned way back in this thread.... When a very small suction is applied against the arrow on the valve..( away from the tank) the valve opens full up..... Something inside displaces the ball when suction is applied... When I found this ..... it threw me for a loop... Not really making sense of that. The only way this could occur is when your purge valve is opened by the zfe and vacuum is applied to the CC to combust the fumes.... If the vent ( with or without the t modification) is plugged effectively plugging the CC, as with a gas infused CC....... that vacuum will now travel up the line and fully open the valve.....and now suck fuel in from the tank.....etc.... I experimented with reinstalling the valve in my CC'less bike......and it is somehow minimizing the odor in the garage....and the tank has no overpressure.... But I believe that if a component is not needed.....it'l be removed...... So will this soon.... It was not much more fumes...without the valve.....
Erling
Old 03-21-2012, 01:55 PM   #117
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 506
Seemed fine today. Temps in the 80's, full tank - - no pressure at all.
I want to keep my CC as I park in an attached garage alongside the shared wall with the house. Don't want stinky gas fumes in the living room!
Only time will tell.
Old 03-28-2012, 03:08 PM   #118
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
Yeah, the micro porous check ball allows air to travel to tank freely and is supposed to limit the rate of evaporation to the canister. It has a small affect on HC emissions that is too small for me to care about, and if removed will make it a little easier to flow fuel to the canister. The micro porous ball plugs all the time. The effect on flowing fuel to the canister is only relevant to people who habitually put 4.5 gallons of fuel in a 4.2 gallon tank.
The canister filters air going to the tank AND stores HC emissions. A bike sitting on the sun or riding down the road will emit FAR more HC then a car because the tank is exposed to the sun AND huge engine, exhaust, and fuel pump heating.
I am very far from an environmentalist, but the shit that turned the air brown, kept people indoors, and made for pretty sun rises in the Las Angles area, that was HC.
I don't mind people driving big SUV's or starting forrest fires, but for me, the charcoal canister and TWC are always going to stay on my bike because they make a huge difference with little to no negative impacts.
Also note, laws are getting more enforced all the time. I am safety inspection certified in Missouri and have been informed by the officer that inspects my work that Missouri is going to start enforcing the emissions rules on bikes, so if I pass a bike that has the TWC or carbon canister removed, I am liable for up to a 20 grand fine.
Im not over emotional on this. I will happily step aside and let someone else at the dealership pass the bike, but between the risk of getting caught and the knowledge that these things really do matter, I won't pass it myself.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 03-28-2012, 05:45 PM   #119
HighTechCoonass
Oddometer: 2,493
Laugh before / after....moe pictures...
Before:
AFTER......
Old 01-31-2013, 02:07 PM   #120
SpadedAce
Injun!
SpadedAce's Avatar
Oddometer: 11
Originally Posted by YetiGS View Post
There are a couple of DIY's on how to remove the charcoal canister from the F800GS but they don't have pictures. So here's how I did it.
The charcoal canister has three hoses coming out of it, two on top and one from the bottom. One from the top goes to the gas tank vent valve, the other goes to a breather valve. The hose coming from the bottom is routed to the bottom of the motorcycle. To make it more clear, I made up the following diagram:
Tools and supplies needed:
Torx T25
Torx T30
Snips
Needle nose pliers
5/16” vacuum hose plug
5/16” Uni Filter crankcase filter
First remove the countershaft sprocket cover via the three T25 torx screws.
Remove the two small triangular side panels via the one T25 screw and then slide the panels off the two prongs. Don’t lose the rubber grommets.
Remove the rectifier via the two T30 screws being careful not to lose the two spacer washers which are between the rectifier and its mount. The remove the mount via its two T30 screws.
Snip the two big cable ties holding the canister onto the frame and slide the canister holder as far off to the side as you can. At this point I was able to remove the bottom line off the canister and one of the top lines.
Then snip this cable tie and move the wires out of the way.
Snip the cable tie which is holding the two wires to the canister bracket and move them aside.
You can then move the canister down, pull off the last line from the top of the canister and work the canister out through the countershaft sprocket area. It is tight but you can work it out.
Once the canister is out you'll have three hoses:
Reach through the frame and pull the hose off the breather valve that came from the canister. Then put the 5/16” plug over the bung. (I forgot to take a picture of this.)
Then put the Uni Filter on the line that goes to tank. I then zip-tied the filter up out of the way so that it will stay as high as possible and out of any water’s way. (This is not where I left it. I just took a picture before I tucked it up out of the way.)
Then zip tie the two wires that were attached to the canister bracket to the frame with a cable-tie like so:
Then discard the line that goes to the ground, put all the panels back in place and go for a test ride.
In all, it took about an hour, but without stopping to take pictures this could easily be done in a half hour or 45 minutes.
Please let me know if you have any questions, need anything clarified or can't figure out what the hell I'm talking about.
Scott -
Any chance you still have the pics from your original post of the 'how to' for this CC removal? A couple very key images are not showing (dead links) and I'm not much of a wrencher on the GS. Dirtbikes no problem, but the F800GS is more technical than I am. Me =
If not, no biggie.
Thanks.
'Oh Shit!' is usually the moment when your plan parts ways with reality!
TEAM WANKER
2006 GasGas 300XT / 2011 BMW F800GS / 2012 KTM 450 XC-W
SpadedAce is offline   Reply With Quote
Times are GMT -7.   It's 03:01 AM.
