Old 05-06-2012, 11:18 AM   #3736
Dash65
wherethefarkarewe?
Dash65's Avatar
Oddometer: 302
Thumb 14 Days and 4000k of fun
Couldn't sleep as I'm all pumped about my trip, 3 days on tar to Bundy and then a week to get back via as much dirt as I can.
Here is my Ten all packed and ready to go.
Cheers,
Dash
XT660Z Tenere - 2010
Honda XR250 - 1985
Growing old is inevitable, Growing up is optional
Dash65 is offline   Reply With Quote
Old 05-06-2012, 03:18 PM   #3737
TenereTravelers
Let's go there!
TenereTravelers's Avatar
Oddometer: 62
Hi Shelbyjet, I bought my temperature gauge of Ebay. Search digital temperature gauge and they pop up every now and then. They were cheap enough so that you can buy a few should you need to replace it in the future.
Cheers, Jan
"For my part, I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to move."
Robert Louis Stevenson - Travels with a Donkey in the Cévennes (1879)
TenereTravelers is offline   Reply With Quote
Old 05-06-2012, 03:55 PM   #3738
Aussie Trev
aka DRTrev
Aussie Trev's Avatar
Oddometer: 5,858
Did the cush drive mod with an inner tube yesterday. Tight as a drum now - will check it out in a thousand kms and see what's happening in there.
Anyone looking to buy a second-hand Touratech bash plate?
I think I'll go with the B&B model and link it up to the SW-Motech crash bars, which, unfortunately will not fit with the Touratech.
2011 Triumph Tiger 800XC
1982 PE175Z
Full member......Quorn Schnitzel Club
"Just having a crack"
Aussie Trev is offline   Reply With Quote
Old 05-06-2012, 04:02 PM   #3739
Arek Kontrol
Arek Kontrol's Avatar
Location: Ex-pat Poles in Adelaide Hills, South Australia
Oddometer: 258
G'day Trev,
large ?
Finally the BMW R/GSW ....... My Videos - YouTube
I live more in 5 minutes on my motorcycle than some people live in a lifetime...
Arek Kontrol is offline   Reply With Quote
Old 05-06-2012, 04:13 PM   #3740
Aussie Trev
aka DRTrev
Oddometer: 5,858
Originally Posted by Arek Kontrol View Post
G'day Trev,
large ?
I would have thought I was about average Arek, but here is the bash plate, which is of the large variety.....
photo.....
1982 PE175Z
Old 05-06-2012, 04:20 PM   #3741
Arek Kontrol
Oddometer: 258
I've sent you PM
Old 05-06-2012, 05:34 PM   #3742
regie308
regie308's Avatar
Oddometer: 1,443
Originally Posted by TenereTravelers View Post
Hi Wilmo, I rode my bike home, put it on the mainstand, took off my riding gear and then checked the oil and nothing showed on the dipstick. It took another 600ml to register normal readings! Always pays to double check..
Cheers, Jan
From memory fella's i think i remember something in the manual about checking the oil level on the "side stand" (check it out i could be wrong)
As this might give you a different oil level reading to the centre stand vertical position.
cheers.
My current ride: 2011 HUSKY TE 511
My old rides: 2009 XT660Z TÉNÉRÉ - 2000 WR400 - 1992 TT350
My FAVORITE ride: GRANTS MUM!........
IT's NOT GAY!... UNLESS THE BALL's TOUCH
regie308 is offline   Reply With Quote
Old 05-06-2012, 07:06 PM   #3743
Paulba
Paulba's Avatar
Oddometer: 43
An extract from the service manual.....
Hope it helps.
Paul
In The shed ..
2010 XT660Z
1988 XT600Z
Paulba is offline   Reply With Quote
Old 05-06-2012, 07:26 PM   #3744
regie308
regie308's Avatar
Oddometer: 1,443
.... typical me!!! allways remembering "the wrong" way... oops!
Old 05-07-2012, 03:00 AM   #3745
TenereTravelers
Let's go there!
Oddometer: 62
Cush drive modification - another option
Folks,
I tried a different take on modifying worn Tenere cush drive rubbers and basically cut pieces of inner tube and pushed the worn cush drives into the inner-tube sleeves. I did over 6000 km with this modification and whilst they were worn when I finally replaced them with new ones, there still was no noticeable movement, so this is another way of doing it that works as well.
Cheers, Jan
Old 05-10-2012, 07:23 PM   #3746
Dash65
wherethefarkarewe?
Dash65's Avatar
Oddometer: 302
Question Fuse Box
Hey Guys, I'm trying to work out what fuse box to get and where to put it under the seat??
I have installed a GPS and USB charger but I want to install Driving lights, heated hand grips and a couple of 12v Cig adapter plugs.
Any help would be appreciated.
Cheers,
Dash
Honda XR250 - 1985
Old 05-10-2012, 09:13 PM   #3747
shelbyjet
shelbyjet's Avatar
Oddometer: 62
Cheers,
Dash
Hey Dash,
I recommend you just put an inline fuse in. I wired up straight to Battery and run my 12v and accessories off it. I have a 12v outlet (if I use two ports for USB charging then I may run 3.5amps), GPS only draws around 1/2amp, Heated Grips (<3amps) and LED driving lights (2 amps total). That is 9 amps so I have a 10 amp fuse, but always carry a 15 with me just in case...
All accessories can be run while bike is off (except driving lights - they are relayed to the ignition system) so just be careful you don't run down too much overnight (charging phones/scala/camera etc...) - I think this would really only be a problem in very cold conditions with a deteriorated battery.
Can buy them from most auto or marine shops (I bought from Whitworths) and even has an LED indicator to identify fuse condition - all for around $8.
Cheers.
PS - I can't yet upload photos, but Msg me your phone number again and I will sms you a piccie of mine if you like.
Greg - Sydney
http://www.facebook.com/endoftheroadtenere
shelbyjet screwed with this post 05-10-2012 at 09:20 PM
shelbyjet is offline   Reply With Quote
Old 05-11-2012, 08:09 PM   #3748
Portly
Plodder
Portly's Avatar
Oddometer: 310
Dash
Google Eastern Beaver, He is based in japan and has a couple of fuse box options.
The three circuit solution looks like a tidy little unit.
This guy rides and a lot of his stuff is motorcycle specific.
I have just ordered a couple of things from him for my DR, including the headlight relay kit with driving light lead.
Portly screwed with this post 05-11-2012 at 08:12 PM Reason: addition
Portly is offline   Reply With Quote
Old 05-12-2012, 12:36 AM   #3749
roswellj
ARGHventurer
roswellj's Avatar
Oddometer: 802
At one stage I made a fuse box for the ten. It was smaller than any commercially available one and found that it still saved more space to have inline fuses rather than a fuse box.
2012 Triumph Sprint GT
2010 Tenere xt660z (Gone)
2002 yamaha xt600e (Gone)
And god said unto moses come forth... but he came fifth and won a teapot
roswellj is offline   Reply With Quote
Old 05-12-2012, 12:54 AM   #3750
davo_0104
Oddometer: 8
Pissed Help!
Is there special trick to removing the rear brake pad retaining pin?
What should have been a very simple job of replacing the rear pads will now cost me a new calliper I think. I've somehow managed to break the calliper piston during my fit of rage and put my finger straight through it
Is there any chance of saving it?
Cheers,
Davo
2010 Yamaha Tenere XT660Z
davo_0104 is offline   Reply With Quote
Times are GMT -7.   It's 01:51 PM.
