Old 05-26-2005, 04:07 PM   #1
skeeter OP
Captain Safety
skeeter's Avatar
Oddometer: 1,872
Torque values for DRZ400
Would anyone happen to know the torque values for the counter sprocket nut and rear axle nut on a DRZ400. I don't have my service manual yet and haven't been able to find the values on the internet yet. I torqued them to the values for my KLR650 (72 ft/lbs on counter sprocket, 58 ft/lbs on rear axle). Close enough? More? Less????
skeeter is offline   Reply With Quote
Old 05-26-2005, 06:10 PM   #2
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,764
rear axle 72.5 ft/lbs
countershaft sprocket 79.5 ft/lbs
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is online now   Reply With Quote
Old 05-26-2005, 06:50 PM   #3
skeeter OP
Captain Safety
skeeter's Avatar
Oddometer: 1,872
Thanks!! I'll re-torque them.
Old 05-27-2005, 12:13 AM   #4
oldasdirt
Oddometer: 261
Talking oldasdirt on countershaft sprockets.
I've got the same as tbitd sp does. On the counter use some blue locktight too. They have kind of a reputation for working there way loose. Sure don't hurt to give it a tug now and then either. it truly is one of the things to watch on the DRZ.oldasdirt
oldasdirt is offline   Reply With Quote
Old 05-27-2005, 07:30 AM   #5
DRZ400SK4
DRZ400SK4's Avatar
Oddometer: 2,047
Word to the wise...
It is absolutely essential that you apply red Loctite to the CS splines and threads!
Despite the spline locking washer, the nut WILL come loose eventually, and this will cause the CS oil seal to fail.
Do it now! It's a critical issue with the DRZ.
DRZ400SK4 is offline   Reply With Quote
Old 05-27-2005, 11:06 AM   #6
viverrid
not dead yet
Oddometer: 30,482
Originally Posted by DRZ400SK4
It is absolutely essential that you apply red Loctite to the CS splines and threads! Despite the spline locking washer, the nut WILL come loose eventually, and this will cause the CS oil seal to fail.
I too have heard people post on Thumpertalk about disasterous CS oil seal failures, loosening sprockets, etc. Yet FWIW, I know of numerous dirt ridden DRZs, none of which has had any of this.....
I DON'T think its a BAD idea by any means, just maybe not as critical as all that??? (But then I don't know anyone with a problem with the A.C.C.T. either.)
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 05-27-2005, 11:11 AM   #7
DRZ400SK4
DRZ400SK4's Avatar
Oddometer: 2,047
It's basically a very easy fix to do, so well worth the peace of mind in my opinion.
There have been many posts from guys on the TT forum, who have had the bike suddenly spew oil all over the rear tire while riding. Not a good scenario. And even more guys who have found the nut to be hand tight upon checking it.
So this simple 15 minute job could very well save your life.
A good project for the next rainy afternoon.
Old 05-27-2005, 01:24 PM   #8
skeeter OP
Captain Safety
skeeter's Avatar
Oddometer: 1,872
Word to the wise...
If you use red locktite, I would imagine you would have to use some kind of puller to remove the sprocket later?
Old 05-27-2005, 01:29 PM   #9
jdiaz
Oddometer: 32,305
If you use red Loctite, you would just need heat to remove the nut.
That said, I only torqued the nut on my bike to spec and used the locking washer, and never had a problem. My DRZ didn't have a lot of miles on it, but saw an inordinately large amount of mud packed between the CS sprocket and the engine case while I had it, and the seal never failed.
Jon
jdiaz is offline   Reply With Quote
Old 05-27-2005, 06:45 PM   #10
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,764
I've changed my front sprocket 3 or 4 times at least, never used locktight and never had a problem. Of course, this means I was re-torquing it to spec every so often. I think a lot of folks don't tighten them enough.
Agree, not a bad idea, but critical? I don't know. That SOB is hard enough to get off (normally anyway) I personally am not gonna make it harder.
Mike S.
AMA MSTA
Old 05-27-2005, 06:47 PM   #11
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,764
Jon
Jon, did you still have the plastic countershaft sprocket cover on? I ditched that thing and got a B&B Aluminum case saver, much less mud build-up.
Mike S.
AMA MSTA
Old 05-27-2005, 11:21 PM   #12
jdiaz
Oddometer: 32,305
No, I yanked that thing the first day. I just happened to ride a lot with people who liked mud.
Jon
Old 05-28-2005, 03:35 AM   #13
skeeter OP
Captain Safety
skeeter's Avatar
Oddometer: 1,872
Jon
With the cover off it makes it a lot easier to see if the nut is coming loose.
Old 05-11-2011, 11:42 AM   #14
fujian
fujian's Avatar
Location: Langford ( Victoria ) British Columbia, Canada
Oddometer: 191
Agreed, Also have my Front sprocket cover off.
fujian is offline   Reply With Quote
Old 05-11-2011, 02:50 PM   #15
Naq
Kitsune
Naq's Avatar
Oddometer: 200
Bluhduh
FWIW my CS sprocket was only being held on by the bent washer at 3500miles. I blue locktited it.
That side up.
'02 FZ1, '02 DRZ400S, '09 TE250
Naq is offline   Reply With Quote
Times are GMT -7.   It's 08:34 PM.
