Old 09-08-2009, 10:05 PM   #1
Tyrepliers OP
Oddometer: 2
Motorcycle Tyre Repair Kits & Bead Breakers
Hi Everyone
After many years of frustration with the lack of tyre repair products available for the motorcyclist, we decided to develop a range of puncture repair products and Manual Tyre Changing Equipment. We did this to cater for those people, like ourselves, that were sick of being handed either push bike puncture repair gear or automotive patches.
Finally after years of development, testing and manufacturing, we have produced a comprehensive range of products that are light weight (while being incredibly strong ) and compact.
After reading through your site I realised most of your subscribes probably wouldn't be aware of our product range that would be handy to a lot of your readers. I appreciate the opportunity to show all interested parties a range of products that I'm sure many of your readers are unaware are available.
Here are a few of our Products and more can be seen at our website http://www.tyrepliers.com.au I am more than happy to answer any questions you have about the products, (please take into account time zones for our response times) and we are more than open to group purchase discounts if the products are shipped to one location.
Motorcycle Bead Breaker
Video Of Product Working
http://www.youtube.com/watch?v=RWcMGnISWQM&feature=player_embedded
The Tyrepliers Motorcycle Bead Breaker is suitable for use on rims up to 6” in width. The tool has been designed knowing weight and size is a big issue. The Motorcycle Bead Breaker weighs only 700 grams, and has been sized to fit in a pannier bag. The unit has been electroplated for rust resistance, and has a High Tensile thread for strength. The Tyrepliers Motorcycle Bead Breaker comes with a 12-month warranty.
PART NUMBER BB105
The unit has also been designed to work in the simplest way.
To break the bead all pressure in the tyre must be released by removing the valve.
To use this tool correctly please follow these instructions:
Adjust the tool to the width of the rim.
Place the bead breaker through the centre of the rim between the spokes and locate on the tyre bead.
Break the bead by winding the tool to apply equal pressure to both feet until the bead is broken. **Ensure that the feet push only on the bead of the tyre.
Move the tool around the rim and repeat the action until the bead pops.
Complete Motorcycle Tyre Repair Kit For Tubed Motorcycles
Complete Tubed Motorcycle Repair Kits
2 x 200mm Tyre Levers Forged Both Ends
1 x Stitching/Rasp Tool
6 x 32mm Round Tube Patches
6 x 43 mm Round Tube Patches
6 x 57mm Round Tube Patches
2 x Internal Radial Patches
1x Valve Extension 90deg
1 x Vulcanising Valve Stem (will reattach to old tube)
2 x 10cc Vulcanising Cement
1 x Chalk 2 x Tyre Valve Cores
1 x Valve Cap With Valve Removing Tool
1 x Co2 Inflator/Hand pump
3 x Co2 Cylinders
PART NUMBER KIT116
With Beadbreaker and 300mm Levers
1 x Motorcycle Beadbreaker
2 x 300mm Tyre Levers Forged Both Ends
3 x Co2 Cylinders
PART NUMBER KIT114
Complete Motorcycle Tyre Repair Kit For Tubeless Motorcycles
Complete Tubeless Motorcycle Repair Kit
1 x Motor Cycle Bead Breaker (Patent No. PP4684)
1x Plug Reamer / Insertion Tool
5 x Bullet Inserts (Maruni)
1 x Internal Universal Patch
4 x 32mm Round Patches
1 x Chalk
3 x Co2 Cylinder
1 x Plug Trimming Blade
PART NUMBER KIT115
Tyrepliers is offline   Reply With Quote
Old 09-09-2009, 08:54 PM   #2
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,969
I've had the bead breaker for a couple of years now, and it's saved my bacon more than once. I do tires for a living, and this is hands-down the best thing on the market for getting the job done quickly and easily.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 09-09-2009, 08:57 PM   #3
Tyrepliers OP
Oddometer: 2
Great to hear
Old 09-10-2009, 03:46 AM   #4
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
Agreed, except it would be nice if it was smaller and lighter - packing it in for us is a question of will we or won't we devote the space and weight to it everytime we go on a trip - never left it at home yet though.
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C is offline   Reply With Quote
Old 09-10-2009, 06:31 AM   #5
Bigger Al
Bigger Al's Avatar
Oddometer: 7,969
I fitted the tool to the two bikes I have and then cut off the excess length of rod to make it more compact. Saves a lot of room.
Steve McQueen
Old 09-10-2009, 09:54 AM   #6
Singletrack_mind
Cave Man
Oddometer: 434
I am liking the look of this thing, especially since it's been redesigned & hopefully no longer suffers the problems the first one had.
One thing worries me though: Once the bead pops off on one side, how do you get the second side loose? I'd love to hear from those who've used it in the field.
I'll be using it on a BMW GS800 running Heidenau K60s. I've already discovered the the rear can be a bitch to remove even when it's smoking hot from running down the road flat. Some tough sidewalls . . .
Singletrack_mind is offline   Reply With Quote
Old 04-17-2011, 02:48 PM   #7
DRIVER
DRIVER's Avatar
Oddometer: 41
Anybody ever get an answer for this possibility? When one side of the tire lets go how do you get the other side loose? Move it a bit and hope the other side lets go instead of the one that came off previously? From the looks of the tool I don't think I'd want to stick in on the rim and then try to pull the difficult side loose. I'm holding off on my purchase wondering ...
OK tire experts ... educate me on what I should carry on my next trip.
Mike
BMW F800GS
Suzuki DRZ400
DRIVER is offline   Reply With Quote
Old 11-26-2011, 11:48 AM   #8
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,946
According to this post you have to wrestle with it (scroll down quite a bit).
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 04-10-2013, 12:40 PM   #9
nuttynu
nuttynu's Avatar
Oddometer: 969
how much for the bead breaker alone for and ADV member ?
shipped to 99504?
nuttynu is offline   Reply With Quote
Old 04-10-2013, 08:12 PM   #10
Rich1961
Oddometer: 6
How much for kit114 to 95713?
Rich1961 is offline   Reply With Quote
Times are GMT -7.   It's 09:40 AM.
