Old 09-14-2009, 07:22 AM   #1
ADVJake OP
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Torque wrench.. Left hand thread?
Hi fellas,
I'm attempting to put a 46mm nut back on the crank, because its a Left hand thread im afraid my (new) kincrome wrench i just got doesnt work for LH threads and that ive stuffed it trying to get it to click...
I got my dad who weighs 90KG or so to physically stand on the wrench to try and tighten to 130NM. So far, there is no more movement and it still isnt clicking.
Ive never tightened to this torque before, and the breaker bar i used to remove the nut had much more leverage.
Thanks for any advice.
Jake
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 09-14-2009, 09:10 AM   #2
Guzz
Gutless wonder
Guzz's Avatar
Oddometer: 4,912
Well, if the torque wrench is ~ .3m long, and your dad was standing on it, and it doesn't move anymore, you're done. Go ahead and continue on the rebuild, because I believe you've actually over torqued it. (or my math maybe way off, wouldn't be the first time )
Are you sure your toque wrench doesn't do LH threads? Put the torque wrench on a low value, put an old bolt in your vice, and try it out. Does it click or not?
Change must come from a barrel of a gun. -- Mao Tse Tung
When governments fear the people, there is liberty. When the people fear the government, there is tyranny -- Thomas Jefferson
Guzz is offline   Reply With Quote
Old 09-14-2009, 09:50 AM   #3
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 12,166
+1 -- some wrenches have a little doo-hickey on the head that clicks, magically reversing the ratching action (and, therefore, the direction the torque will be read).
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 09-14-2009, 02:07 PM   #4
yosmitetom
Oddometer: 3,354
Left-handed torque wrenches are as hard to find as left-handed Crescent wrenches.
yosmitetom is offline   Reply With Quote
Old 09-14-2009, 02:27 PM   #5
D.T.
Up in this MF'er!
D.T.'s Avatar
Oddometer: 10,909
Eh?
This is what I was thinking. Those LH box end wrenches too, damn.
This thread makes no sense.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 09-14-2009, 02:57 PM   #6
gsweave
Yinz, blinkers are on.
Oddometer: 11,469
130NM?
yea your most likely over torqued.
Someone smarter than me can do the conversions and math.
(Guzz, I see you've done the math, 0.3cm, oh my!!)
90KG that's like two stone?
what is length of torque wrench?
Beam type torque wrenches for LH work, for future referance.
It's going to be just fine.
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 09-14-2009, 03:01 PM   #7
cagiva549
whats a cagiva
Oddometer: 2,454
Beam wrenches work both ways , Good clicker torque wrenchs work both ways , I know my Proto's do . but you better check it before you bet your motor on it . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 09-14-2009, 03:17 PM   #8
Guzz
Gutless wonder
Guzz's Avatar
Oddometer: 4,912
Ok, I will admit something.
I was working on my car the other day and there was one bolt that required 130 nm torque. I think it was that much, can't remember, but I do remember that my torque wrench didn't go up to the required torque. Trying to get the nut off was a bitch though, took my longest breaker bar and I still cracked my socket.
So I just set the torque wrench to the highest it could go and went to town on it. I have to say that I couldn't physically get the damn wrench to click it was so high a torque and in a bit of an odd position.
So, I got out the jack out of the car, grabbed a chunk of 2x4 (to reach). Kept cranking up the jack, started to hear the 2x4 creak a bit, then the blissful sound of the "click" of the torque wrench. Backed off the jack and said "I'm done." and finished up the project. If that nut comes off, I'll be really surprised.
Old 09-14-2009, 05:39 PM   #9
ADVJake OP
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Well i just rang kinchrome and it doesnt do left hand thefts
most likely overtorqued a f**king crankshaft nut, the worst...
What problems would this cause on an LC8 engine?
Old 09-14-2009, 05:58 PM   #10
gsweave
Oddometer: 11,469
does it press on or into a bearing, or seal?
change those!!!
The nut will be stout, I would just check for garfed-up threads and reuse.
1Paul 2:15
Old 09-14-2009, 06:12 PM   #11
ADVJake OP
***** dweller
ADVJake's Avatar
Oddometer: 4,341
Its for the timing pickup ring, it clamps against the washer & sprocket. Maybe the bearings weren't damaged then?
Old 09-15-2009, 06:54 AM   #12
cagiva549
whats a cagiva
Oddometer: 2,454
As long as everything felt smooth as you were torquing its probly fine , I tend to overtighten everything , I dont have things falling off my bikes . I also dont have jap bikes , I got tired of broken bolts and parts . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
Old 09-15-2009, 02:59 PM   #13
the_gr8t_waldo
Oddometer: 2,107
fwiw-a "stone is 14 lbs and 90 kgs about 198.5lbs
the_gr8t_waldo is offline   Reply With Quote
Old 09-15-2009, 03:24 PM   #14
PaulRS
Dutch fool
Oddometer: 789
Do the math.
130 Nm is 130 N (13 kg) applied on a lever 1 meter long.
Or for you yanks, approx 29 lbs and 3.3 feet.
Not an awfull lot.
Paul.
PaulRS is online now   Reply With Quote
Old 09-15-2009, 04:01 PM   #15
Guzz
Gutless wonder
Guzz's Avatar
Oddometer: 4,912
Originally Posted by PaulRS
Do the math.
Not an awfull lot.
Paul.
When did you last see an torque wrench that was 3.3 feet long?!?!?! (outside big industrial assembly). Most are 1 to 1.5 feet long (12 - 18 inches, 30 - 46 cm) roughly.
So that 130 Nm is 96 lbs at 1 foot away on a lever.
Times are GMT -7.   It's 11:13 PM.
