Old 05-27-2006, 11:44 AM   #511
modrover
BOOMSHANKA!
modrover's Avatar
Oddometer: 3,576
Just a note... I've got my 1988 Africa Twin up for sale in the flea market. Those of you USA guys who've been spank'n the monkey on this thread... NOW'S YOUR CHANCE TO SHAG THE REAL DEAL!
BTW... nice photos Greg!
~Michael (of The Land of Misfit Land Rovers)
Had an Africa Twin and Transalp
X-Files Gov't Issue Sprinter TurboDiesel
Series IIA 109" Land Rover Deluxe Station Wagon
Washougal, WA USA
modrover is offline   Reply With Quote
Old 05-28-2006, 04:35 AM   #512
Tim
Tim's Avatar
Oddometer: 2,358
Originally Posted by CG125
Not as badly as a lot of people here who've never even seen an Africa Twin, let alone ridden or owned one!
Why, is Brighton an Africa Twin free zone?
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Old 05-30-2006, 11:48 PM   #513
John K
Ambitious but rubbish
John K's Avatar
Oddometer: 609
That's "here" as in "on ADVrider"
Actually, Sussex seems to be a bit of an Africa Twin hot spot!
John K is offline   Reply With Quote
Old 05-31-2006, 07:00 AM   #514
Slimie
Oddometer: 1,071
Now, why is that?
Are we going to see you out on the 11th of July, CG? See "other site" for details
Cheers
-Simon
Slimie is offline   Reply With Quote
Old 06-01-2006, 01:28 AM   #515
John K
John K's Avatar
Oddometer: 609
Originally Posted by Slimie
Now, why is that?
Probably something to do with the condition of the roads round here!
Can't make that one, but maybe see you at one of the midweek jaunts if you can make it!
Old 06-01-2006, 04:48 AM   #516
Nik0s
Nik0s's Avatar
Oddometer: 58
Some pics from a recent trail ride
Although not of the best quality, here are some pics at a recent trail ride with my AT
Nik0s is offline   Reply With Quote
Old 06-01-2006, 04:49 AM   #517
Nik0s
Nik0s's Avatar
Oddometer: 58
Old 06-01-2006, 04:50 AM   #518
Nik0s
Nik0s's Avatar
Oddometer: 58
Old 06-01-2006, 04:51 AM   #519
Nik0s
Nik0s's Avatar
Oddometer: 58
Old 06-01-2006, 04:51 AM   #520
Nik0s
Nik0s's Avatar
Oddometer: 58
Old 06-01-2006, 08:32 AM   #521
beemer boy
Oh no, he's gone Asian
beemer boy's Avatar
Oddometer: 871
Have an Africa Twin question that I could not seem to google up an answer for.
The rectifier went out on my RD07. Because of the high voltage it goes up to in process of dying, it burned out all the lights, cooked the battery, killed the CDI, and the tachometer also now does not work. It will not go above 2000 RPM indicated no matter what the engine is doing. I have replaced all the parts , and now the bike runs fine. Except the tach still does not work. To prevent this from happening again I am putting a voltmeter on all my Twins. Has this anyone on this board had the same experience, and is there some tricky fix for the tach ?? I understand they are pretty pricey. Thanks in advance!!
If you can't pick it up by yourself, it is not an adventure bike.
beemer boy is offline   Reply With Quote
Old 06-01-2006, 11:29 AM   #522
Slimie
Oddometer: 1,071
No answer from me but you might find someone more knowledgeable over here...
www.xrv.org.uk
Old 06-03-2006, 04:07 AM   #523
beemer boy
beemer boy's Avatar
Oddometer: 871
Decided to put the old Zaga bags from my BMW onto one of my Africa Twins.
Ordered the regular Touratech frames. After carefully looking at I did not like the look of the wider box on the exhaust side. So.........off to the welding shop. Had them cut the exhaust to be in the low position, about one inch below the box. Then had them cut the frame apart, and then bring it in to be the same as the left side. Total cost here in Thailand for the work was about $ 75.
Had the boxes powder coated as well. Now when I smash them up, a little touch up paint, and they look new again. Also the painted surface does not turn your packed gear black like bare aluminium.
beemer boy screwed with this post 06-03-2006 at 06:14 AM
Old 06-03-2006, 04:23 AM   #524
GSPD750
GSPD750's Avatar
Oddometer: 1,436
A Dyna charge monitor would have given you a heads up in that situation and possibly averted your disaster. Here's a previous post of mine. I have one on my gspd too and swear by them.
http://www.advrider.com/forums/showt...na#post2533960
1999 XRV 750 Africa Twin
1996 XL 600v Transalp
GSPD750 screwed with this post 06-03-2006 at 06:25 AM
GSPD750 is offline   Reply With Quote
Old 06-03-2006, 04:34 AM   #525
beemer boy
beemer boy's Avatar
Oddometer: 871
Lord, I have seen the light !!!!!!!! I had already ordered two dyna charge indicators just before the rectifier died. Am now putting them on all my Africa Twins. Those CDIs are EXPENSIVE. Great idea though . Otherwise you are motoring down the road happily looking at scenery, next moment you are by the side of the road in the middle of nowhere with a dead bike. Easy call to put one one.
beemer boy screwed with this post 06-03-2006 at 07:30 PM
Times are GMT -7.   It's 02:00 PM.
