Old 02-06-2013, 10:34 PM   #16
_cy_
Oddometer: 6,359
_cy_ screwed with this post 02-07-2013 at 04:18 PM
Old 02-07-2013, 06:14 AM   #17
blaine.hale OP
blaine.hale's Avatar
Oddometer: 3,177
Originally Posted by Wirespokes View Post
The stock rubber bits make it pretty easy with no stretching. It's been a while since doing one, so don't recall how to do it, but your knowing it's possible should make it easy for you to figure out the solution. Essentially, one side will go in farther than the tubing, giving enough space on the other side to slip it on. Try it without the grommets first to get the idea.
If you do it like Blaine (with the shorter nonS stalks) - remove the black plastic do-nuts from the turn signals. The signals will then mount normally.
What are these black plastic do-nuts your speak of? Haha
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 02-07-2013, 12:41 PM   #18
davebeef
Buffoon
davebeef's Avatar
Oddometer: 263
Blaine,
I fitted a genuine cockpit fairing to my R100 using the stock, short front indicators. You have to remove the hard rubber inserts on the indicator bodies where the stalk passes through. This then gives enough length on the stalk to pass through the fairing and be able to be clamped within the indicator body.
The fairing flexes enough to fit over both short stem stalks in situ. Just pass over one first and then the other.
Some pictures below. Any more info just ask.
davebeef is offline   Reply With Quote
Old 02-07-2013, 01:01 PM   #19
blaine.hale OP
Oddometer: 3,177
Just to clarify, this thread is over a year old. I've removed and installed that fairing maaaany times over :)
I'm just answering the person that re-vised the thread.
1974 BMW R90 /6
Old 02-07-2013, 05:55 PM   #20
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,213
Yep, Dave did it the way I know about. Remove the hard black plastic donut from the signal body. It's a separate piece and pops out - not easily, but it will!
Old 02-07-2013, 10:37 PM   #21
davebeef
Buffoon
davebeef's Avatar
Oddometer: 263
No probs.
Old 02-08-2013, 06:03 AM   #22
blaine.hale OP
Oddometer: 3,177
Now I know why I have no clue what you're talking about....I've only ever had metal body turn signals
1974 BMW R90 /6
Times are GMT -7.   It's 01:26 AM.
