Old 08-20-2011, 05:56 AM   #1591
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
header differences between stock and Leo Vince TI single system
stock
Leo
if you want a reasonable priced slip on .. here it is
http://cgi.ebay.com/ebaymotors/FMF-E...#ht_3649wt_939
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 08-20-2011, 06:21 AM   #1592
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Diablo
How did you handle the brake rotor / caliper issue with the SM wheel set?
Old 08-20-2011, 06:40 AM   #1593
indykwak
indykwak's Avatar
Oddometer: 159
Originally Posted by DiabloADV View Post
TE with moto wheels...very nice; very nimble. Swapout to enduro wheels is a snap.
After I looked at this pic, I realized how horrible the Leo stickers look. They just peel right off those end caps.
Very nice! Did you just the TE brake rotors or swap our to a SMS caliper and rotor, etc? Looks like a great option for street riding.
2008 BMW R1200GS
indykwak is offline   Reply With Quote
Old 08-20-2011, 08:11 AM   #1594
tshrey
Oddometer: 200
I just ordered the Q4 from that link this morning. So much for not spending money on the bike right away...
Sent from my DROIDX using Tapatalk
tshrey is offline   Reply With Quote
Old 08-20-2011, 08:37 AM   #1595
DiabloADV
Semi-Occasional
Oddometer: 2,325
Originally Posted by Fast1 View Post
Diablo
Just put a TE rotor on the SM wheel. Needed to drill out the mounting holes a little -- 11/32" was perfect. The SM wheel takes a larger bolt. I used stainless countersunk screws instead of the cap screws that the SM uses.
Other than that, it just mounts right up. Axle from the TE; axle spacer from the TE. Plug-n-play.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 08-20-2011, 08:38 AM   #1596
weldpro
Oddometer: 83
Originally Posted by sethro View Post
Hello all
Just wanted to share with the group. I had a set of foot pegs laying around off my 2010 FE570 and wondered if they would fit on the 630. The 630 foot pegs are just to narrow to stand on for very long.
Anyway all you got to do is gring them down a little bid as they are a touch too wide to fit in the bracket. They look great and are heck of allot wider than the stockers.
BTW Husaberg foot pegs are the same as all the late model KTM bikes
Huge improvement and work awesome
Sethro
I found this out as well. I ended up buying IMS pro pegs for the late Husaberg, and KTM models. Very little grind work to make them fit! I absolutely hated the stock pegs.
www.stubbswelding.com
1150gs,Husky TE630,crf450r(#101),450exc(#115p)
weldpro is offline   Reply With Quote
Old 08-20-2011, 10:06 AM   #1597
kpt4321
kpt4321's Avatar
Oddometer: 1,671
Diablo
Diablo's solution is totally acceptable (TE rotor on the SM wheels), as long as you don't mind giving up some braking power.
I don't mind the little rotor with knobbies, but I am more comfortable with a bigger rotor with the sticky tires.
On my TE (610), I use a caliper relocation bracket with the SM wheels. Right now I am using one from motostrano, but there are others out there, and I have also made my own for previous bikes (need access to a mill or CNC though).
These bikes are a BLAST with the smaller wheels and sticky rubber on them!
TAT 2008 / Colorado 2010
"Both the man of science and the man of action live always at the edge of mystery, surrounded by it." -Oppenheimer
2007 Monster S2R / 2006 TE610 / 1999 KDX 200 / 2000 DRZ-E
kpt4321 is offline   Reply With Quote
Old 08-20-2011, 10:17 AM   #1598
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Have you compared the larger rotor and relocation bracket braking performance to the OEM SM caliper/rotor?
I've been looking at the Motostano full SM kit for $1219 which includes everything you could want for an easy swap.
Warp 9 Supermoto Wheels 17x3.50 front mated with a 17x4.25 rear
Wheels are complete with all spacers, seals and bearings
Warp 9 Stainless Steel Wave Brake 320MM Rotor
Warp 9 Anodized Brake Caliper Relocator
Warp 9 Rear Steel Rotor
Warp 9 7075 T6 Aluminum Sprocket
Rear Steel Vented Rotor
NAK Seals
OEM Bearings
Zinc Plated Nyloc Hardware
All required mounting hardware, screws, bolts and nuts
Light weight non-oring chain, for better clearance (NEW!)
CHOICE of either Continental ContiForce Supermoto Tires or AVON Distanzia Tires (both are DOT road oriented tires) or Michelin Pilot Powers
Acerbis Supermoto Fender
Set of heavy duty Bridgestone or Michelin Supermoto Tubes with valve stems and Rim Strips
Old 08-20-2011, 10:48 AM   #1599
DiabloADV
Semi-Occasional
Oddometer: 2,325
True, the TE rotor will fade quicker than the larger SM rotor on hard, extended braking. But, I don't ride that hard where I'm braking hard repeatedly.
A relocator bracket and 320 rotor kit runs about $200 from a few suppliers. Dan at Motoxotica can order one.
Or, you can get the Motostrano kit. I found used OEM wheels. Otherwise, I would have gotten that kit.
Old 08-20-2011, 11:42 AM   #1600
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
My friend just purchased one and I think my other friend is placing his order now.
FMF site indicates retail of $650 for this system.
http://www.fmfracing.com/Products/Bi...USQVARNA_TE630
Old 08-20-2011, 12:33 PM   #1601
DiabloADV
Semi-Occasional
Oddometer: 2,325
Are you sure you're getting two mufflers on that order?
Old 08-20-2011, 01:55 PM   #1602
wrryder
wrryder's Avatar
Oddometer: 165
It was a local dealer that shared this info with me. Not all that earth shattering nor would it keep me from buying one (which I am considering) but still a little weird that they would abandon that market segment after just releasing a major upgrade to the model. It seems like all the redesign and tooling costs were completed so why not just keep pumping them our for a few more years? Nothing bigger than the TE511 will be offered... at least until the TE900 shows up. Same guy said that will a couple years off...
why don't you just divulge the source of your rumor..
Craig
RD07a
Sacramento, CA
Don't Feed the Bearcat!
wrryder is offline   Reply With Quote
Old 08-20-2011, 02:50 PM   #1603
xymotic
xymotic's Avatar
Oddometer: 8,367
Um, have you heard of a company called BMW?
Xchallenge. Radically new design, and everybody decided to 'wait and see' after about 9 months folks decided they were pretty good and BMW yanked them because first year sales weren't good.
g450x RADICALLY new design in a completely new market segment. BMW pulled the plug almost instantly. Like they thought all those KTM guys were just waiting for them to appear at the track?
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 08-20-2011, 03:52 PM   #1604
pinocono
Husky Dü
pinocono's Avatar
Oddometer: 484
It'll be a shame, if it's true, that BMW is going to pull the plug on the TE630 after this year. There's nothing equivalent to it in the marketplace, out of the crate. The XRL, DR and KLR 650's don't hold a candle to it's dirt prowess, and the TE is just as capable as those 3 on the tarmac. Oh well, I've got a soft spot in my heart for orphans.
'11 Husky TE630
'07 H-D FLTRI
'99 H-D FXD
pinocono is online now   Reply With Quote
Old 08-20-2011, 04:14 PM   #1605
DiabloADV
Semi-Occasional
Oddometer: 2,325
Turning back to muffler topics...
I picked up my 630 with the dual Leo slipons already on it. I don't care about torque and power results from dynos or any of that stuff. The bike is plenty powerful with the p/u kit installed.
What I want are pipes that run cooler than the cat-enclosing stockers, but are just as quiet. The Leos are pretty barky and started to bug me.
So, I put the stockers on the bike and I like it A LOT better. Smoother quieter sound, especially on acceleration and deceleration. In fact, at first I thought something was wrong with the motor cause I was hearing some kind of clatter. It's the valves, of course, and I couldn't hear them before.
But, the stock pipes are really, really hot right at that big steel heat shield.
So...what to do? Do I find some way to quiet down the Leos (ideas...?) or knock the cats out of the stock cans to eliminate the heat? But...that might make the stock cans louder.
Times are GMT -7.   It's 07:22 AM.
