Old 02-06-2012, 02:37 PM   #2836
jtemple
jtemple's Avatar
Oddometer: 572
Originally Posted by Dahlin View Post
I'm new in the TE-world, can someone please explain what the "power up-kit" is and what it does?
The power-up kit is a resistor jumper, exhaust plug and gasket.
You remove the O2 sensor from the exhaust and unplug it from the wiring harness.
You plug the resistor jumper into the wiring harness in it's place.
You plug the exhaust hole with the plug & gasket.
Here are the part numbers for the power-up kit:
  • 8000A7724 - Oxygen Sensor Plug
  • 8000A7749 - Gasket, O2 Sensor Plug
  • 8000A6750 - Oxygen Sensor Connector
I wouldn't even bother riding mine without that installed at minimum.
If I change the exhaust on a TE630, do I need to do something with the EFI?
Typically, yes. You have a few options:
  1. You can do some basic tuning with iBeat software and the accompanying cable used to connect it to a computer.
  2. You can get a JD Jetting kit HERE.
  3. You can get a PowerCommander & AutoTune module.
  4. You can get a PowerCommander without AutoTune and have a custom map made by a tuner.
jtemple is offline   Reply With Quote
Old 02-06-2012, 04:48 PM   #2837
xymotic
xymotic's Avatar
Oddometer: 8,367
+1. My 610 had it installed so I never knew any better til I traded a friend and rode his. I seriously thought his bike was broken. And after riding mine he bought the kit the next day
Completely transforms the bikes.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 02-07-2012, 02:29 AM   #2838
Dahlin
Need more time...
Oddometer: 169
Good info from jtemple
Thanks for the help.
Just to clarify, you can (and should) use the power up kit, even if you run with stock exhaust?
Or is it only for bikes with aftermarket exhaust?
2003 Honda CB1300
2009 Yamaha XT660Z
2011 Husqvarna TE630
2012 Husaberg FE390
Dahlin is offline   Reply With Quote
Old 02-07-2012, 07:29 AM   #2839
pinocono
Husky Dü
pinocono's Avatar
Oddometer: 466
You absolutely should be running the power up kit, even stock.
'11 Husky TE630
'07 H-D FLTRI
'99 H-D FXD
pinocono is offline   Reply With Quote
Old 02-07-2012, 09:17 AM   #2840
jtemple
jtemple's Avatar
Oddometer: 572
Originally Posted by pinocono View Post
you absolutely should be running the power up kit, even stock.
qft
Old 02-07-2012, 10:08 AM   #2841
tshrey
Oddometer: 200
My dealer won't let any Husky's go out the door without installing the power up kit. He said it is the only way to make people happy with their purpose.
edit: 'purchase' not 'purpose' :)
tshrey screwed with this post 02-07-2012 at 10:16 AM
tshrey is offline   Reply With Quote
Old 02-07-2012, 10:14 AM   #2842
xymotic
xymotic's Avatar
Oddometer: 8,367
Sounds like a good one. When a dealer gives you the rote line about a PU voiding warranty, you can guarantee they won't fight for you to get *any* warranty work done.
Albert Einstein
6:10 to Yuma
Old 02-07-2012, 02:56 PM   #2843
jtemple
jtemple's Avatar
Oddometer: 572
That's what I'm thinking.
When I bought my power-up kit, I asked about voiding the warranty. "We can work around that", is what I was told.
Old 02-07-2012, 06:12 PM   #2844
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Another way to look at it is.. how many TE630's actually required any warranty work?
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 02-07-2012, 06:17 PM   #2845
jasonmt
Oddometer: 522
From most of the posts in here it seems like I have one of the few bikes with this graphics package?
jasonmt is offline   Reply With Quote
Old 02-07-2012, 06:37 PM   #2846
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,587
Yes, the last ones they built. I guess they got sick of people asking what it was.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR • Laguna Seca 2012 RR • Sequoia 3-Day Campout • Thanksgiving 2012
browneye is offline   Reply With Quote
Old 02-07-2012, 06:48 PM   #2847
R'oli
Oddometer: 204
I am saddened I didn't buy one of these bikes before they all disapeared...
R'oli is offline   Reply With Quote
Old 02-07-2012, 06:53 PM   #2848
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,587
There are four of them on cycletrader around the country. You'd have to call and see if they actually have one.
There have been just a couple of used ones that have come for sale, so that's always an option to look for. People lose interest or find it's just not for them, or get in a bind and have to sell.
They were easy to buy when the dealers had them. You just walked in and signed your name and BMW Bank took care of the rest.
Old 02-08-2012, 09:18 AM   #2849
jtemple
jtemple's Avatar
Oddometer: 572
Mine did:
  • clutch push rod replacement
  • rear sprocket nuts replacement
  • clutch master cylinder leak
  • clutch cover oil pump leak
  • gauge cluster not water tight
Old 02-08-2012, 11:32 AM   #2850
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Mine did:
Wasn't the push rod and rear sprocket nuts under recall and not warranty?
However yours is an exception and one of the few that were reported with warranty claims(first off the production line??).
I'll contend that the clutch master cylinder had too much fluid. Both 630s I have did this and only
required removal of some fluid to resolve the issue. My TE510 did the same thing.
Not sure what a clutch cover oil pump is?
But any Husqvarna dealer can provide warranty coverage, not just the one you purchase your bike at.
Times are GMT -7.   It's 04:04 AM.
