Old 02-02-2013, 01:20 PM   #3526
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Originally Posted by Gryphon12 View Post
Interesting. Would you say that despite your projection, your TE-630 still needs less care and feeding than a new KTM-500-EXC-F used as a dual sport?
At the first cam chain replacement on the TE630 engine (10K to 15K miles) you would most likely have to rebuild the entire KTM engine.
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 02-02-2013, 02:36 PM   #3527
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,093
@ jtemple, I can't remember, did you observe significant wear of the timing chain components when you tore into it or just replace it because you had it apart?
I'm wondering how much the recommended service intervals are based on an assumption of race use? I suspect a lot of these bikes (500exc,FE570,TE630) will go 20-30K miles w/o major service needs when used like a typical bike. I think one of the Berg guys has 30k on his 570.
TE630.KLX250S.GL1800.CBR900RRturbo.919
HoW (ForeverWest) 2014 CO/UT 2013
Northern Rockies 2013 IBA Key West 2014 Tentspace
DYNOBOB is offline   Reply With Quote
Old 02-03-2013, 04:52 AM   #3528
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Specified maintenance "replacement items" from the shop manual
timing chain 20,000 km
timing chain slider 20,000 km
timing driven gear 20,000 km
spark plug 10,000 km
engine oil 5,000 km after break-in
oil filter 10,000 km
air filter 10,000 km
clutch and break fluids 10,000 km
drive chain and tensioner rollers 10,000 km
rear sprocket 10,000 km
fork oil 10,000 km
no major engine maintenance specified for the first 20,000 km
** thanks to JTemple for the shop manual
Old 02-03-2013, 05:54 AM   #3529
jtemple
jtemple's Avatar
Oddometer: 574
My chain had a lot of slack in it; it was due for a replacement for sure. The gears and sliders looked fine, but they got replaced anyway. The reed valve showed no signs of contact with the cam chain.
jtemple is offline   Reply With Quote
Old 02-03-2013, 08:28 AM   #3530
aviatorbdm
aviatorbdm's Avatar
Oddometer: 107
Hey guys thanks for the info. Helps make a decision. There's a good dealer in the area so parts should not be an issue. Time to buy!
aviatorbdm is offline   Reply With Quote
Old 02-04-2013, 02:41 AM   #3531
asi00007
Oddometer: 62
Hey Guys !! Im about to get my first new Husky in the next few days!!
hope it will be good as I want so
asi00007 is offline   Reply With Quote
Old 02-04-2013, 02:56 AM   #3532
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,159
Originally Posted by browneye View Post
If I was riding to south America I would get a cheap aircooled bike, ride it down there, and then give it away or sell it and fly back. We had a fellow come through here (so-Cal) last year from Calgary that took his G650 Dakar to Panama and then flew himself and the bike back. Not sure what that cost, but he probly should'a left it down there.
+1. If you were specifically looking at a bike to ride down to South America I'd get a Honda XR of the Japanese dated bikes. Having done the trip, Honda is by far the most common bike of the big 4... if you wanted a bit more hard core I'd get the 400 over the 650 as they have a newer 400 there and many of the parts swap. Kawasaki for Asia and Yamaha for Africa!
rickypanecatyl is offline   Reply With Quote
Old 02-07-2013, 10:33 AM   #3533
Gehtlos
Einer geht noch
Gehtlos's Avatar
Oddometer: 151
Just had a friend of mine do this subframe mod. Thought I shared this with everybody. Its working great.
Just hope I remember how everything goes together
Pretending I'm a pleasant person all day is EXHAUSTING!
Gehtlos is offline   Reply With Quote
Old 02-07-2013, 07:02 PM   #3534
SilverBullet
Oddometer: 444
That is a radical design compared to anything else I've seen thus far. I will be welding mine soon and planned to do the standard gusset plates but this would be nearly 2X the strength I bet. I might be considering something similar. Were those cut with that arc or bent?
_
2013 Yamaha Super Tenere
2011 Husqvarna TE630
2004 Suzuki VStrom 650
2002 KTM 300EXC
1974 Suzuki TM400
SilverBullet is offline   Reply With Quote
Old 02-07-2013, 08:14 PM   #3535
Gehtlos
Einer geht noch
Gehtlos's Avatar
Oddometer: 151
It's bent square tubing.
Old 02-07-2013, 10:58 PM   #3536
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,373
[QUOTE=Gehtlos;206751
It's bent square tubing.[/QUOTE]
Sure looks like it should be strong.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 02-08-2013, 03:00 AM   #3537
asi00007
Oddometer: 62
Hi Guys !!
I'm the new owner of TE630 2012.. picked it up today and looking forward to check it...
just one question ....(for now...)
how you guys get along without a fuel gauge ? maybe there is one and I missed it?
Ill try to upload some pictures tomorrow ...
I'm following this thread for a few weeks and the information is great !!
Asi
Old 02-08-2013, 05:39 AM   #3538
pinocono
Husky Dü
pinocono's Avatar
Oddometer: 485
Originally Posted by asi00007 View Post
Hi Guys !!
Asi
Welcome to the club!
There isn't a fuel gauge, but there is a low fuel light. Mine lights up when I've got about 2/3's of a gallon left. I made it 30 miles on pavement after my light went on once.
'11 Husky TE630
'07 H-D FLTRI
'99 H-D FXD
pinocono is offline   Reply With Quote
Old 02-08-2013, 05:40 AM   #3539
SilverBullet
Oddometer: 444
Hi Guys !!
Asi
No fuel gauge only a low fuel warning light. When it comes on you have about 25 mile range only so better head straight for a petrol station. Or if you're in the outback riding alone better to use the remaining fuel to start a fire and pray somebody comes along, haha
_
2002 KTM 300EXC
1974 Suzuki TM400
Old 02-08-2013, 11:20 AM   #3540
rickcj7
rickcj7's Avatar
Oddometer: 514
There is a fuel shut off on each side of the tank, you could use the right side for a reserve if you want.
I live in the east and its never more than a few miles to gas.
Husqvarna TE630
WR250R sold
FE450E sold
XT, NX, KLX, KLR, DR all long gone.
rickcj7 is offline   Reply With Quote
Times are GMT -7.   It's 09:32 PM.
