10-27-2012, 01:02 AM
#3556 | |
110 POWER
Oddometer: 1,657
Rears
From what i understand the desert rear is a harder compound and less grippy on the road when water is added.What are the fronts like?
Take the green pill or the red pill- the choice is yours;This is your last chance. After this, there is no turning back. You take the blue pill - the story ends, you wake up in your bed and believe whatever you want to believe. You take the red pill - you stay in Wonderland and I show you how deep the rabbit-hole goes. |
10-27-2012, 02:07 AM
#3557 |
Lost but laughing.
Oddometer: 4,578
I found the front to be excellent on everything, even wet tar.
Desert has a higher speed and load rating. Michelin Desert / Desert Race Desert Racing Excellent durability, even in high temperatures DOT-legal, so you don't have to trailer your bike to the trails New Desert Race rear tire delivers improved handling, grip and traction Rear Desert Race casing engineered for reduced operating temperature and improved tire life. Michelin T63 Dual Sport: 50% Off-Road / 50% Road True multi-purpose tire: reinforced knobs resist tearing and chunking on asphalt, with excellent traction and stability for off-road use; DOT-legal Knob pattern derived from Dakar-winning MICHELIN® Desert™ tires
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin Cruz screwed with this post 10-27-2012 at 02:41 AM |
10-27-2012, 05:03 AM
#3558 |
Twisted Throttle
Oddometer: 1,673
+1
I've had the Michelin Desert front on my TE510 and TE630 and was very impressed with the tire. I plan on purchasing another. The desert, besides having what I feel were good handling characteristics, also lasted much longer. ![]() ![]()
11 Husqvarna TE630 11 Husqvarna SM630 08 Husqvarna TE510- sold 10 Yamaha FJR 1300 |
11-11-2012, 08:13 PM
#3559 |
Reseda, CA
Oddometer: 3,489
Wow. I guess the Terra is getting all the attention now.
Had to go 7 pages in to find the 630 thread. After the 300 plus mile day that included a bit of everything, I would be hard pressed to find a more versatile bike. No way the Terra would have lived through what the 630 just railed through. That statement pertains to the weight of the bike and isn't a bash on quality. ![]() The girl done good today!
http://johngil.whereamiriding.com |
11-11-2012, 09:40 PM
#3560 |
lucky dog
Oddometer: 254
9 mo of ownership/2500 miles. Love how it takes me effortlessly where I want to go.
![]() ![]() ![]() White Rim Trail ![]() ![]() ![]() ![]() Southeastern Ohio ![]() ![]() Tellico Plains, Tennessee. Near beginning of TAT. ![]() ![]()
KLX250S.TE630.GL1800.CBR900RRturbo.919 DYNOBOB screwed with this post 11-12-2012 at 06:19 AM |
11-11-2012, 10:01 PM
#3561 |
lucky dog
Oddometer: 254
Very happy w/ the TCI outback rack. Can run Wolfmans or Pelicans. I did add CJ's subframe braces. Recently switched to FMF slip-on which exactly off set the weight of the rack.
![]() Just installed a fuel pressure gauge and blue led over speedo indicating power to pump. ![]() ![]() Pleased with how it runs after adding the PC-V. Just got iBeat and couldn't improve on Dynojets map adding or removing fuel. ![]() Before/after Power Commander.
KLX250S.TE630.GL1800.CBR900RRturbo.919 DYNOBOB screwed with this post 11-12-2012 at 06:42 AM |
11-11-2012, 11:50 PM
#3562 | |
110 POWER
Oddometer: 1,657
Had a couple of big days on the te now and got 4200km after just 3 months of ownership.Pretty easy to dewater too if you got enough manpower. Dynobob did plugging in the pcv make a noticeable difference to power or economy?
11-12-2012, 06:26 AM
#3563 |
lucky dog
Oddometer: 254
Second graph shows before/after PCV, you can feel the difference. I average around 48mpg, I had seen as high as 52-55 before the PCV.
KLX250S.TE630.GL1800.CBR900RRturbo.919 DYNOBOB screwed with this post 11-12-2012 at 06:34 AM |
11-15-2012, 10:57 AM
#3564 |
Oddometer: 14
Arrow pipes & the ecu box?
Hello!
I have been owning this bike for about 6 month, and i love my TE630. I am from Sweden and have own Ktm 990 & 690e & also the Yamaha xt660z tenere. The 630 is the best bike of them (for me) Its' a awaysome gravel & trailbike & i drive it to work everyday also. I have been thinkin' about to farkle the bike with Seat Concets seat & the Arrow pipes with ecu box. Also thinkin' about put in Compression shims stack in the forklegs.....or maybe by new forklegs from te610.. its a bit taller than the 630 ies and they have compression adjusting. What do you think about those things? |
11-15-2012, 11:20 AM
#3565 | |
PIN IT & BANG GEARS
Oddometer: 2,513
Not everyone likes Husqvarna LOL
![]() Thought you fellas might get a kick out of such a rant. I did. Especially the big harry ass part.
Chris Brown - "The Browneye" ![]() http://www.stewardsofthesequoia.org/ • Grand Canyon Adventure Ride 2012 Laguna Seca 2012 RR • Sequoia 3-Day Campout • Thanksgiving 2012 browneye screwed with this post 11-15-2012 at 09:05 PM |
11-15-2012, 12:22 PM
#3566 | |
Justa Venturer
Oddometer: 1,245
___________________________________________ So much riding-so little time |
11-15-2012, 03:51 PM
#3567 |
Twisted Throttle
Oddometer: 1,673
Just had to do it.. got tired of burning up my expensive dirt only tires on the pavement or mounting substandard knobs for multi use.
Plan on mounting up a pair of Distanzias that I've ordered. Anyone have any experience with the Distanzias on hardpack graded dirt roads?
11-15-2012, 04:07 PM
#3568 | |
PIN IT & BANG GEARS
Oddometer: 2,513
Distanzias will evaporate. The 150 rear I think is a harder compound, may do ok. If the front is a 17 it's a sumo compound, very soft. They work just okay, some will say pretty good. Never been a big avon fan. Conti Trail or road attacks. The pirelli scorp trails are really quite good. The new dunlops are probly worth a try. Or just go for some good street rubber - PS2's, angels, BT023's etc. Let us know how it goes...
Chris Brown - "The Browneye" ![]() http://www.stewardsofthesequoia.org/ • Grand Canyon Adventure Ride 2012 Laguna Seca 2012 RR • Sequoia 3-Day Campout • Thanksgiving 2012 |
11-15-2012, 04:40 PM
#3569 | |
Mercedes
Oddometer: 515
S1
1975 Suzuki GT750A, 1986 Kawasaki KL600, 2001 BMW R1150GS, 2011 Husqvarna TE630 The Great Pacific Northwest SPOT map (Automatically updates in real-time) ; http://www.advrider.com/forums/showthread.php?t=719703 |
11-15-2012, 05:04 PM
#3570 | |
Twisted Throttle
Oddometer: 1,673
The 150/60 rear is sumo compound. I hope to get about 2000-3000 miles from a pair of the sumo specific Distanzias. Doesn't appear that the Pirelli Scorp, Conti trail attack or new Dunlops offer a tire in the sumo sizes I want.. 150/60 R and 120/70 F. Read some positive reviews in several sources about the Distanzias but like any tire, rider skill, surface, temps, type of bike, intended use all impact results and invoke a multitude of opinions. Have you personally used any you mentioned? the Distanzias?
