Old 12-06-2012, 07:05 PM   #3586
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,508
Originally Posted by Beet View Post
Hi all, just did an oil change, filter and screen clean. My manual does not give intervals, just says service at 1,000ks, 5,000ks, 10,000ks etc. Questions - do You do the screen behind the clutch cover every 5,000ks, sooner than that or do You skip it for longer? What oil do You use and how much $ and where are You getting oil filters??. thanks in advance Beetle.
If you look at the OIC again you'll see it says 1K or 600 miles on the first change. I did mine at 250 miles. Then it shows replace oil and filter at 5K km, or 3000 mile intervals. I do mine at about 2000 with Amsoil synthetic after it had about 12-1400 miles on it. Filter from the dealer, or you can get a Hiflo, but get the right one, we've covered that in depth on cafehusky.com. They run about $5.
If you need a shop manual let us know, they are free for download...30mb PDF.
Amsoil at dealer cost if you want it. Other oils are fine as well, I just prefer the full syn they have, good price too.
EDIT: On the clutch-side screen, I checked it at a couple of thousand and it was clean so probably wait 'till about 5or 6 to check it again.
browneye screwed with this post 12-06-2012 at 07:33 PM
browneye is offline   Reply With Quote
Old 12-08-2012, 06:08 AM   #3587
jtemple
jtemple's Avatar
Oddometer: 545
12,000 miles on mine. I have checked the screen under the clutch cover several times and have never seen even a hint of debris in there.
That said, once you have the oil drained, pulling that cover is a piece of cake. The gasket is reusable. Wouldn't hurt to check it every now & again.
jtemple is offline   Reply With Quote
Old 12-08-2012, 06:40 AM   #3588
sTE610vE
sTE610vE's Avatar
Oddometer: 1,664
On my 03 TE610E (same basic bottom end) the screen under the clutch cover was perfectly clean after 14k. I clean the left one under the shifter ever oil change of course.
TRAIL STAND (advrider thread)- Dual Sport Portable Jack Stand www.endurostar.com
Husqvarna TE630
Husqvarna TE610E (for sale)
Cagiva Gran Canyon
sTE610vE is offline   Reply With Quote
Old 12-08-2012, 07:22 AM   #3589
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,508
Friday December 7, 2012
International Motorcycle Show, Long Beach, CA
Walked the show last night. Finally got to see the Terra 650. Looks like the 630 but different. Looks to have the same suspension. Probably make a lot of people a very nice dualsport.
Specs revealed an 80lb weight gain though. Holy crap, that's double what I figured it would come in at. Oh my. I feel real bad for those that will take them offroad. It's just as bloated as the Sertao. I can hardly lift that one off the kickstand.
So even with my Dirtbagz and all my gear I'm just about up to the dry weight of the new Huski. OMG.
Bar-10 Ranch, North Rim of the Grand Canyon, 2012
Old 12-08-2012, 10:46 AM   #3590
blaisew
blaisew's Avatar
Oddometer: 398
Chris, no way the Terra is in the same league as the TE630! Don't even think about it, if you ever really did. I think it will be a nice road bike with the ability to poke it's nose down a few reasonable trails. I'll have mine in Death Valley (along with the 630) and you can try it out if you like. Just keep it off of Lippencott or the trail to the Salt Trams!
Ken
blaisew is offline   Reply With Quote
Old 12-08-2012, 03:35 PM   #3591
Gryphon12
Gryphon12's Avatar
Oddometer: 689
Same Suspension? First, it's non-adjustable. Then...
TR650: GC: 8.1" Seat: 34.4" Travel f/r 7.5/ 7.5" Rake: 26.5* Trail: 4.41" WB: 59.1"
TE630: GC: 11.8" Seat: 37.2" Travel f/r 10.6/12.6" Rake: 30.0* Trail: 4.58" WB: 58.5"
Capabilities: All the difference in the world! TR better for the street - TE better off-road.
And...It is a Husky Sertao!
1990 Honda NT-650 Hawk-GT
Never doubt that a small group of thoughtful, committed citizens can change the world;
indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 is offline   Reply With Quote
Old 12-08-2012, 05:56 PM   #3592
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,508
What is 'GC'?
I did not realize there was that much difference in suspension. I just looked at the Terra forks and they looked the same.
BTW, the Terra had crappy (cheap) looking rims. I did notice that.
I'll be keeping my 630.
Old 12-08-2012, 06:05 PM   #3593
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,508
Ken
Speaking of the Salt Tram, you should plan to do that ride with us. I would love to do it again. Awesome scenery, you look across at the Sierra range, not up at it.
We came up the back side from the 395, down into Saline Valley. That's quite a downhill, certainly easier than trying to go up it.
Sierra range in the background here...
Old 12-08-2012, 08:29 PM   #3594
Gryphon12
Gryphon12's Avatar
Oddometer: 689
What is 'GC'?
Sorry, I type too fast sometimes and forget my database short-hand doesn't always translate. "GC" is ground clearance. Sometimes analogus to seat height, and sometime correlates with suspension travel, but not always. Together with steering geometry and wheel-base, they give me a pretty good picture for comparing with other similar bikes - until the test ride, when it all goes out the window!
Old 12-09-2012, 05:22 AM   #3595
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 2,508
Ah, well yes, if they took 3" out of the suspension then it reduced the seat and ground clearance by the same. Wow. I can't imagine, even the 630 is pretty limited, it bottoms regularly if ridden hard. I may have to have mine updated/re-done.
Old 12-12-2012, 10:14 AM   #3596
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,673
Has anyone attemped install of the compression adjusters, changed fork weight oil or volume and/or changed front springs in their forks?
Results?
Difficulties doing the install/labor?
Source for compression adjusters?
11 Husqvarna TE630
11 Husqvarna SM630
08 Husqvarna TE510- sold
10 Yamaha FJR 1300
Fast1 is offline   Reply With Quote
Old 12-12-2012, 03:02 PM   #3597
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,489
Results?
Yes.
Adjuster was from Marzocchi and I purchased from my local suspension shop. I had the forks re-valved, so I can't compare with a stock setup.
I have a set of .52 springs, but haven't put them in yet.
I believe LT Racing has the adjusters in stock.
johngil is online now   Reply With Quote
Old 12-12-2012, 08:10 PM   #3598
955616846
Oddometer: 1,690
Results?
Yep... Springs, adjusters, RT valve stacks and tuned with Redline yellow fluid. The rear received similar work. They are an easy fork to work on and the results were as expected from properly tuned suspension.
The forks found their way onto my girl's G650GS and were replaced with parts from a 510... I wasn't about to put the 510 forks on the GS.
It has now been a year since I last rode a TE... They are currently looking a bit sad buried under a pile of gear and dust in the corner of the shed.
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800
Founding member Longtails SC
955616846 is offline   Reply With Quote
Old 12-12-2012, 09:46 PM   #3599
blaisew
blaisew's Avatar
Oddometer: 398
I had LTR work on both forks and shock; a world of difference. While he was in there I had him remove the spacer in the forks to give me back the extra inch Husky took out on the 630. Nice. The stock rear spring was way too heavy and it was lightened quite a bit. Maybe a notch too much though. It's perfect when riding without gear, but sags just a bit much when fully loaded for full on adventure rides and can bottom on big hits. It's so cushy though I think I'll leave it alone since there is plenty of pre-load that can be cranked in when needed.
Old 12-12-2012, 09:48 PM   #3600
blaisew
blaisew's Avatar
Oddometer: 398
Chris, if you guys do the Salt Tram again, I definitely want to go! Sounds like a challenge, and fun! I can't wait to load up and head for Death Valley again. Glad you are taking the RV this time as it has to be a LOT better than the tent.
K
Times are GMT -7.   It's 05:24 AM.
