Old 04-11-2013, 10:05 AM   #3616
rickcj7
rickcj7's Avatar
Oddometer: 500
Originally Posted by SilverBullet View Post
Anybody know what happened to the TE610 thread? My subscribed link is no longer showing up and I searched and can't find it. Did they merge it into this thread? Many things in common with our TE630's so I always liked to keep current there also.
_
http://www.advrider.com/forums/showthread.php?t=156429
Husqvarna TE630
WR250R sold
FE450E sold
XT, NX, KLX, KLR, DR all long gone.
rickcj7 is online now   Reply With Quote
Old 04-12-2013, 05:52 AM   #3617
SilverBullet
Oddometer: 429
Originally Posted by rickcj7 View Post
Thanks. My search didn't find it because I wasn't putting in the dash. Still don't know why I got unsubscribed though.
_
2013 Yamaha Super Tenere
2011 Husqvarna TE630
2004 Suzuki VStrom 650
2002 KTM 300EXC
1974 Suzuki TM400
SilverBullet is offline   Reply With Quote
Old 04-20-2013, 06:26 PM   #3618
asi00007
Oddometer: 62
Fuel pump issue
Hi guys..
I put it on CH as well..
I got my 630 two month ago and I did 800 KM on it.. I just love that bike.. amazing what I can do with it.. well.. its me how try to keep up with the bike
But I have a problem .. Yesterday i took a ride to the bush and everything go well until we decided to head home , so I'm trying to start up the bike and nothing happend .. the fuel pump doesn't make any noise .. everything else is working fine .. after a few phone calls I tried again and suddenly it making the regular BZZZ and she fire up in a second and the N flash once , I'm going tomorrow to the dealer to sort that out but I wonder if anyone else here had the same problem .. I didn't find any information on CH but I'll be happy if someone have information about this issue
Asi
asi00007 screwed with this post 04-20-2013 at 10:29 PM
asi00007 is offline   Reply With Quote
Old 04-20-2013, 11:16 PM   #3619
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,298
Hi have a look here
http://www.cafehusky.com/threads/doc...k-areas.30149/
Welcome to the weird electrical faults some 630's suffer.
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 04-20-2013, 11:27 PM   #3620
asi00007
Oddometer: 62
Hi
I already looked there.... didn't find anything about the pump problem
there is the Fuel tank leaks and the temp sensor problem that i'm aware of
Ill keep you posted when i find somthing
asi00007 screwed with this post 04-20-2013 at 11:34 PM
Old 04-21-2013, 07:36 AM   #3621
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,799
Originally Posted by asi00007 View Post
Hi guys..
Asi
Sometimes I have to jiggle the ignition switch or re-click it. Like a sticky contact or something.
I suppose one day I'll be forced to hot-wire it in the field.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 04-21-2013, 07:44 AM   #3622
asi00007
Oddometer: 62
I have that feeling its coming from the kill switch on the handle bar
Old 04-24-2013, 11:07 PM   #3623
Maxyb
Falling over slowly
Maxyb's Avatar
Oddometer: 104
I decided to weigh my 630 to work out what specs are actually correct as I've seen so many numbers been thrown around.
To make sure the weight was correct i weighed it twice on two different scales - calibrated digital refrigeration scales and some analogue oldies that are accurate as all buggery.
With everything stock plus
oil
water
2L of petrol
husky rear rack
ktm 690 windscreen
radiator braces
skidplate
beefed up subframe
and barkbusters
my 630 weighed in at 155kg! or about 340lb
It's not a heavyweight afterall.
A side note, i'm loving my 630 more and more everyday, and I'm sure many of you guys are too
Maxyb is offline   Reply With Quote
Old 04-25-2013, 04:12 AM   #3624
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,298
oil
water
2L of petrol
husky rear rack
ktm 690 windscreen
radiator braces
skidplate
beefed up subframe
and barkbusters
Good to hear mate
mine is a pos atm
blown map sensor number 3
wiring is corroded in the loom
i love how the thing goes when it is going
but it is becoming unreliable often
looks like i am gunna ride a ttr across the desert next week
Old 04-25-2013, 07:22 AM   #3625
SilverBullet
Oddometer: 429
oil
water
2L of petrol
husky rear rack
ktm 690 windscreen
radiator braces
skidplate
beefed up subframe
and barkbusters
You could drop an easy 20+ lbs by going to a single FMF exhaust and a Li-Ion battery.
_
2002 KTM 300EXC
1974 Suzuki TM400
Old 04-25-2013, 10:43 AM   #3626
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Originally Posted by WILL_S View Post
Good to hear mate
mine is a pos atm
Seems like some of this story is missing since you are one, if not the only, that has this problem and feels this way.
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Old 04-25-2013, 10:55 AM   #3627
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,042
He's detailed his problems on CafeHusky. I think it's a case of dealer incompetence/run around. Sucks in any event, I'm sure he'd like to be riding his bike.
TE630.KLX250S.GL1800.CBR900RRturbo.919
HoW (ForeverWest) 2014 CO/UT 2013
Northern Rockies 2013 IBA Key West 2014 Tentspace
DYNOBOB is offline   Reply With Quote
Old 04-25-2013, 11:59 AM   #3628
Maxyb
Falling over slowly
Maxyb's Avatar
Oddometer: 104
_
Or about 30lb with the Leovince ti system and a Li-Ion battery
would bring it down to stock ktm 690 weight
Old 04-25-2013, 12:14 PM   #3629
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,298
Yes being the only one with this problem makes it hard for huski to accept or workout what is really going on.My wiring is corroded in the loom,the wires have gone black.This has only been discovered by the guys working on my bike when map sensor failed for the 3rd time.Water was getting into the connecting plug at the tp s.A new throttle body was fitted,you cannot buy the tp s assembly separately.600 km later it went again.Water in there again, another TB and a new seal was fitted.300km later it goes again.Water residue in the plug.Only road riding in light rain.This time a another plug was sent they strip the wires back to solder it on and find the wiring corroded.So my bike sits ,no looms available here.Might have another sensor.I leave in a few days for a ride that i had brought and was setting the bike up for.I have been told it won't be ready and they wouldn't trust it if was.
Yes i would love to be riding it.
The dealers have been great.
It is the distributor/warranty mob over here that has not been helpful.
Old 04-25-2013, 01:27 PM   #3630
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,042
Will, Speaking as a bystander, it seems to me the dealer should have found the problem after the second "bad" tps. No one else has had one bad tps, much less two (or three). I wouldn't be surprised if none of the tps' have actually been bad. I can believe water got into the plug causing corrosion/resistance and improper tps values going to the computer. I could also believe you've had an intermittent short in the wire harness and may have some burned wires. My point would be, the dealer should have been digging deeper after the first replacement tps didn't fix the problem.
It's pretty common in all types of vehicle repair to throw parts at the problem instead of making the effort to pinpoint the problem. I wouldn't be surprised if the distributor/warranty people feel like this is whats happening and are reluctant to keep playing. It is hard though to manage the relationship w/ a dealer and not alienate them.
Hope they get if figured out this time but I sure wouldn't blame you gave up on the 630. Keep us updated and get some pics of the "black" wire harness if you can, it may help someone else.
DYNOBOB screwed with this post 04-25-2013 at 03:28 PM
Times are GMT -7.   It's 08:08 PM.
