Old 02-02-2014, 08:21 AM   #3931
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,092
The 630 has 12,000 miles (19,000km)
Based on what SimpleOne (and Ken Web) just found w/ his, I'd definitely look as cs splines.
TE630.KLX250S.GL1800.CBR900RRturbo.919
HoW (ForeverWest) 2014 CO/UT 2013
Northern Rockies 2013 IBA Key West 2014 Tentspace
DYNOBOB screwed with this post 02-02-2014 at 08:27 AM
DYNOBOB is offline   Reply With Quote
Old 02-02-2014, 11:58 AM   #3932
jasonmt
Oddometer: 566
Originally Posted by browneye View Post
On the tuner, some of the riders on cafehusky have the settings at zero, or same as factory, or maybe just one of the five changed. So I couldn't see spending $250 on something that didn't change anything.
When you say 'out of the box settings' does that mean they put some adjustments in compared to stock? Or is that 'same as stock'?
What I notice is the power just kind of tapers off over about 5800rpm, and it will ping sometimes, so I think it's lean up high. I'm thinking it should pull harder all the way to redline, or pretty close. I'm running de-catted and gutted stock cans. No issue with flow, that's for sure. Otherwise stock, just the PU, and airbox maze out. I get about 50mpg.
Yes, the seat concepts seat is only wider at the back for when you sit down. Mine got put on as new and can't imagine the bike being any other way.
The JD Tuner for the TE630 is available for under $200 if you do some shopping and it comes "pre-programmed" with some recommended settings. My bike pulls hard to redline without a hiccup but as I have mine mounted where it is easy to adjust on the fly I am not sure what exactly my settings are at.
That being said I am in the process of switching to a PC5 (Motomummy has them for $265).
jasonmt is offline   Reply With Quote
Old 02-02-2014, 08:17 PM   #3933
Pcfly
Dude?! Seriously??
Pcfly's Avatar
Oddometer: 1,117
Question
Originally Posted by SilverBullet View Post
Yep it is really that easy. Do it first and you'll probably find no reason to buy a JD tuner or PC-5. Both of those are add-ons to stock ECU so something else possible to go wrong also. Early back in iBeat posts the numbers posted were very low and most didn't bring dramatic change. Only with Dynobob's dyno results did the CO numbers jump to 110/110/120 for max power. Not sure if anyone prior actually dyno'd or just seat of the pants. Even George at Uptite only recommended 104/106/110 or something in that range. I still need to fine tune my settings with a dyno but I'm pretty close. See Dynobob's thread at CafeHusky for details.
I was content with my bike's power before but it didn't have the high end punch like you mentioned. Now it pulls strong all the way to redline. Previously I could get mine to ping under certain circumstances also. If I was cruising 70-75mph and going uphill or standing on the pegs causing drag and hit the throttle it would sometimes ping. Now under exact circumstances it now longer does that and will accelerate strong to near triple digits without having to downshift first.
LAB2LV was a great ride and definitely will do it again some year. Next time I want to do all the hard way options. This time I only did half of them as my travel and riding buddy DNF'd last year and wanted to ensure this year he finished the entire ride and wasnt taking any chances. I did break away from him for some sections the last time being the hard way up into Red Rock but turned around half way into the technical and came back down as I was with a heavy BMW 650 Dakar that wasn't up to the task. Honestly at that point I was probably looking for an excuse to bail also as was up to my eyeballs with the ice and snow and didn't want to slide off the cliff only 20 miles from the finish.
Prior to LAB2LV we rode two days in AZ and then parked our haul rig in LV and rode the bikes via dirt to Barstow before switching onto pavement at darkness to ride into OC the day before Thanksgiving. That was a cold night ride.
_
I don't suppose there are any of you in the Northern California/SF Bay Area that might have access or could help me with an iBeat reset for my 630.
Maybe anyone of you going to the Death Valley Noons ride perhaps?
2011 Husqvarna TE-630 The Red Raptor
2012 Yamaha 50th Anniversary Badass-Sounding R1
2008 BMW 1200GS The Blue Rhino (SOLD)
Pcfly is offline   Reply With Quote
Old 02-03-2014, 12:45 AM   #3934
Simple_One
Oddometer: 52
Originally Posted by bj4x4 View Post
Hi,
Im currently looking at a te630 with 20,000km on it. Is this getting pretty high for a te630? What sort of kms would i expect to get out of the te630 engine? Im currently tossing up between a Very well setup te610 And a te630 with a safari tank and racks and not much else. The te610 is cheaper though its about 2 days drive there and back.
http://www.gumtree.com.au/s-ad/buder...610/1036558251
http://www.gumtree.com.au/s-ad/lake-...sky/1037292959
Like you, I came from a DRZ, don't have enough saddle time to tell you how the Husky compares as yet. A short test ride suggested it was similar in performance to a fairly modded DRZ400SM, but with much smoother throttle response and better low end torque.
I paid the asking price for this bike:
http://www.bikesales.com.au/private/...=0&pss=Premium
It's not perfect, but I wasn't budgeting on it being perfect either. I'm going to have to replace the counter shaft due to spline wear. I've ordered a 45t Kush sprocket (~$110 shipped) in the hope of warding off future counter shaft wear, but a Rad Mfg cush hub will set you back $550 plus shipping if you go that path instead. A few of the bearings were below average (wheel and swingarm) and the lower head bearings were buggered, so it's cost me $237.10 in bearings so far for front & rear wheels, steering head, swing arm (from R&D Husqvarna in Sydney) and I'll install them myself. I've order Indy Unlimited's (on here) clutch cup washers for the clutch mod (http://www.advrider.com/forums/showp...ostcount=22671). I've sent the subframe off to get a small crack repaired and have weld in gussets added as suggested on Cafe Husky, that will be about ~$150-$200 with the subframe removed off the bike and just given to the bloke for gusset fabrication and welding.
I haven't pulled the linkage bearings yet, but they might be an additional cost.
The counter shaft I haven't priced yet, but I'm hoping for $750, maybe under a thousand in parts and labour if I take the engine to someone (already removed from the bike frame).
Transport from Melb to Syd cost me ~$300 with Motomovers.
Rego and blue slip will be about $600 i reckon.
I'll see what sort of state the engine is in once it gets split, hoping to get it out tonight and down to the mechanic by Wed. This bike has ~15,400km's on it, mostly longer dual sport km's from what I understand. It was never run with a Kush Sprocket or cush hub, which is part of what has hurt the coutner shaft I would guess.
Another good forum (not that ADVRider isn't great!):
http://www.cafehusky.com/forums/610-630.70/
TE630 buying advice:
http://www.cafehusky.com/threads/te6...e.39244/page-2
Some stuff about the bike I have bought and its repairs etc:
http://www.cafehusky.com/threads/te6...houghts.39383/
Known problems on the TE630:
http://www.cafehusky.com/threads/doc...k-areas.30149/
I've also got some other parts on the way, including an iBeat cable.
jtemple on Cafe Husky can provide you with a bunch of TE630 related goodies including manuals, parts catalogues, iBeat (etc.) all free of charge.
Cheers,
Kris
Simple_One screwed with this post 02-03-2014 at 01:04 AM
Simple_One is offline   Reply With Quote
Old 02-03-2014, 01:08 AM   #3935
Simple_One
Oddometer: 52
Also some other bits in the Oz TE thread:
http://advrider.com/forums/showthrea...69990&posted=1
Good luck with the purchase!
Despite the extra costs involved with my bike, it's still going to come in it far lass than a KTM 690 of more kilometers and similar model year. A quite a bit less than a Husaberg FE570 (though frankly I still lust after one of those for reasons unknown, I'll call it love at first sight!)
Old 02-03-2014, 01:03 PM   #3936
mattadv93
mattadv93's Avatar
Oddometer: 228
Thanks for the replies. I was actually looking at the same bike but looks like you got in before me. I gave the guy a ring about the the 630 I listed above and he said it had been using a fair bit of oil.. so I guess that ones off the list haha.
The world is a book and those who do not travel read only one page.
-Husaberg FE570
mattadv93 is offline   Reply With Quote
Old 02-04-2014, 08:52 AM   #3937
Thumperama
RIP Husaberg
Thumperama's Avatar
Oddometer: 180
Originally Posted by Simple_One View Post
And quite a bit less than a Husaberg FE570 (though frankly I still lust after one of those for reasons unknown, I'll call it love at first sight!)
I had the same urges regarding a Husaberg FE570 and ended up having to scratch that itch before all the good ones were gone. If you get the opportunity, they are a fine, fine motorcycle.
'12 GasGas 250 Raga Replica
'11 Husqvarna TE630, '11 Husaberg FE & FS 570's
'10 Triumph T-Bird 1700, '07 Ducati Monster S2R 1K
'01 Triumph Sprint ST 955i, '97 & '87 XR600R's
Thumperama is offline   Reply With Quote
Old 02-05-2014, 12:09 AM   #3938
Simple_One
Oddometer: 52
So ball park pricing for the counter shaft is:
A full days labour (even with the engine already out of the bike, add another half day it needs to come out and go back in) so about 10hrs = ~$900 AUD
Counter shaft = $165 AUD
Then are the other extra direct expenses like seals and gaskets that need replacing.
Then there is everything else you might want to do whilst the block is split like checking gearbox selector forks, 2nd gear, bearings, piston, rings, bearings etc.
Old 02-05-2014, 01:07 AM   #3939
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,328
I know it might seem daunting but it might be time to get familar with the internals yourself.At least pulling the motor out shouldn't be to bad.
Luckily you got the bike cheap and well set up.Even with a complete rebuild and going over it will still work out a bargain.The added bonus is all the downfalls will have been addressed and should no longer resurface.
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 02-05-2014, 04:14 AM   #3940
Simple_One
Oddometer: 52
Will, your spot on mate, that's exactly how I'm looking at it. I've stripped the bike right back now, just a frame and a wiring loom left on the bike, so not much of a bike actually. Every bearing is going to get replaced now, including the shock linkage bearings which also turned out to be pretty stuffed. I've got the engine out and I've ordered a case separator so a bit of this and a bit of this
Never opened a bike engine up before, other than taking off a clutch cover once, but with the shop manual, some time and some tools, I shouldn't go to far wrong. I've got a good local bike mechanic down the road anyway, so if I end up a bit up the creek, I'll just take it to him for further surgery!
I've actually quite enjoyed my little bonding session with the bike, getting to know all of it's little secrets and intricacies, what makes it tick and all that good stuff, and I suppose I reckon I can manage a bit more of that. But at the same time, a bloke is always hoping for fourth base and the chance to give her a good hard ride; so I live in hope that it will happen eventually!
Old 02-05-2014, 05:40 AM   #3941
DYNOBOB
lucky dog
DYNOBOB's Avatar
Oddometer: 1,092
There's a lot of value to knowing your bike this well.....and if you're gonna do it, the 630 is a worthy platform.
Old 02-06-2014, 05:12 AM   #3942
Simple_One
Oddometer: 52
While I'm mucking around in the engine, is it worth fitting a manual cam chain tensioner to the 630, or is the stock one pretty good?
Similarly, is there anything else I should be looking at or replacing at ~15-20k km's mark?
(I'm thinking gaskets obviously, but what about seals, clutch bushings, selector forks etc?)
Old 02-06-2014, 07:25 AM   #3943
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,263
I'm no expert cuz I've never torn one down...mine has about 5600 miles on it and has always run like a clock.
From the threads I would say to check the clutch basket bushing, and do the spring cup update while you have it apart.
Haven't heard anyone with problems with the CCT. I would go over to cafehusky and browse the threads there, especially JTemple, I think he has over 25K miles on his and has done some work. There is at least one engine problem thread, one for 3rd gear and one for top end?
I had not heard of the worn countershaft spline issue. I guess it's from lack of cush hub. I was looking at my setup last weekend and the counter sprocket is pretty worn, going to replace it. Was going to replace the chain and both sprockets because the chain was getting kinky, but I cleaned it all out, each link and use some penetrant oil on a couple of the stiff ones and everything freed up, all orings in tact, it's not loose and floppy. It was just caked dirt and maxima chain wax gunk, I'm done with that stuff - PJ1 from here out. Or just clean with WD40. The rear sprocket is really pretty good. The front seems tight on the shaft, feels like just thousanths of play. I'll get a closer look when the new sprocket goes on. Maybe I can squeeze a few more miles out of the drive train.
Cafehusky is the place for this stuff, although most of the members are here too. But we have one thread here and there are MANY there - one for anything you could possibly want to know.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 02-06-2014, 11:01 AM   #3944
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,328
Manual adjusters work well.I am not sure of any 630 adjuster failures.Cam chain would nearly be due.Rings?
When you do pull it down could you take plenty of pics like the threads below?
http://www.supermotojunkie.com/showt...%28assembly%29
http://www.supermotojunkie.com/showt...step-with-pics
I will be taking at least the top off mine in the near future and having a look at the bore/ring wear.
Old 02-06-2014, 03:51 PM   #3945
Simple_One
Oddometer: 52
Yep, no probs, I'll grab some photos. The real issue will be that I won't really know what I'm taking photos of!
Need to wait for the case separator to turn up before I can really start, and I'll be leaving for two weeks away from Mid Feb, so there might not be much action on this front until early March.
Times are GMT -7.   It's 01:45 AM.
