Old 01-19-2011, 07:12 PM   #796
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Originally Posted by BMW Atlanta View Post
Ohhh, 08 TE510? Ya might not want to use the kick starter too much. It's got the same assembly that's been failing on the TC's and the only difference between the TC and TE is the TE has electric start = not using the kicker. There is a technical service bulletin from HSQ to replace the kick starter gear assembly on 08 TC's only as HSQ IT felt the TE/TXC kicker isn't necessary anyhow. If it fails it can crack the crank case cover, so use your kicker sparingly, I'd hate to have to try kicking it over to life in the boondies only to wind up with metal bits floating around the case and oily air blowing out the freshly formed crack
(that ought to give the 610/630 crowd some ammo)
What is the number and date of that TSB?
BTW, mine starts first kick.. FI not carbed like the TC...
regardless.. rumor has it that it breaks external to the cases.. Does the TC run higher compression than the TE?
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 screwed with this post 01-19-2011 at 07:23 PM
Fast1 is offline   Reply With Quote
Old 01-24-2011, 12:27 PM   #797
Ragin Rabbi
Semper Fidelis
Ragin Rabbi's Avatar
Oddometer: 5,101
Originally Posted by xymotic View Post
And we're baaaccckkkk
I had to re-start that "debate".
It was an enjoyable exchange...
Each according to their need, each according to their ability.
It takes a village to raise a child.
Go You Spurs!!
Ragin Rabbi is offline   Reply With Quote
Old 01-24-2011, 05:35 PM   #798
Hoder
Card carrying greeny
Hoder's Avatar
Oddometer: 1,019
How long should the kick lever be? Is it better to have a shorter or a longer leg?
See my pics
Dave:
The 610 really makes me want to ride like a punk everywhere I go.
bikefrk:
You now understand supermoto.
Your training is complete.
Hoder is offline   Reply With Quote
Old 01-25-2011, 08:14 AM   #799
Rattletrap
When in doubt-Gas it
Rattletrap's Avatar
Oddometer: 302
When folded should it be more forward or straight up? Which gives the best leverage? I think a hand crank from a model T would be best.
Rattletrap is offline   Reply With Quote
Old 02-07-2011, 07:14 PM   #800
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Old 02-09-2011, 07:56 PM   #801
lout
AYCIC
lout's Avatar
Oddometer: 769
Originally Posted by Fast1 View Post
Nice clown suit...just needs a big red nose and you'll be set.
I heard the same arguments when we started moving away from points ignitions.
make sure your battery is servicable, i've never had a battery failed that I didnt know was going to.
Lout.
TASMANIA - Explore the corruption.
Orange paint and 37 clicks of suspension adjustment doesn't make up for being a shit rider :j Mo
It's not that I don't believe in God..I just believe in one less God than you.
Monsanto - The evil that keeps on growing
lout is offline   Reply With Quote
Old 02-09-2011, 08:04 PM   #802
xymotic
xymotic's Avatar
Oddometer: 8,367
Talk about going backwards... Nothing but sealed and lightweight batts for me. If you're worried about it you could carry two high-tech cells with less space and weight than a wet cell.
And, IMO the risk of a wet cell corroding OTHER components is not worth it.
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 02-10-2011, 10:22 AM   #803
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
next time take off your dunce cap before you post..
Old 02-10-2011, 05:22 PM   #804
lout
AYCIC
lout's Avatar
Oddometer: 769
I'm guessing you dont have many RL friends..
you do know what points are ?
I know i'm gonna regret this but ...whats your valuable opinion on ABS?
Lout.
Old 02-10-2011, 05:24 PM   #805
lout
AYCIC
lout's Avatar
Oddometer: 769
subframe
How strong is the subframe on a 630, does it need reinforcing to carry 15-20 kgs of gear as well as my 105 kgs
Lout.
Old 02-10-2011, 06:31 PM   #806
xymotic
xymotic's Avatar
Oddometer: 8,367
The 610 definitely needs some gussets, and from what I have seen the 630 looks very similar in design.
Albert Einstein
6:10 to Yuma
Old 02-11-2011, 02:30 PM   #807
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
Have points in my 67 Camaro along with the condensor.. and gapped appropriately..
ABS on my FJR1300 is fantastic and worthless in my Tacoma IMO.
and now did you get a read on the TE630 long term review?
If I'm not mistaken, the TE630 received revisions to the subframe from the former TE610.
Old 02-11-2011, 03:05 PM   #808
WFO
Oddometer: 133
The subframe on the 630 is beefed up compared to the 610 but that's alot of weight to mount right at the end. i don't think it would stand up to continus washboard. You should use a giant loop bag to spread the weight out / lower the weight.
WFO is offline   Reply With Quote
Old 02-12-2011, 03:27 PM   #809
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
http://www.youtube.com/watch?v=ljMI3T1mI48
Old 02-12-2011, 08:08 PM   #810
lout
AYCIC
lout's Avatar
Oddometer: 769
he doesn't say a real lot about technical stuff, ..more like an ad for husky.
no mention of warranty, different subframe?, cush drive (or lack therof)
service intervals etc etc
ps. I love trailzone with a passion ....but ore needs lots of work.
Lout.
Times are GMT -7.   It's 07:33 PM.
