Old 09-20-2009, 08:09 PM   #1
Scooter1942 OP
Average Dude
Scooter1942's Avatar
Oddometer: 88
Has anyone tried this lowering kit for the 800GS?
I saw that Touratech had a lowering kit for the F800GS made by Hyperpro. I gotta admit, that even with the low seat, I'm damn near on my toes. This would drop it 2". Heck, that would even allow me to get the Sargent seat and still be 1" lower than I am right now.
Aside from some ground clearance, what other disadvantages might there be in going with this kit? Center stand or side stand issues? FWIW, I'll be 80%+ on pavement with only occasional gravel/dirt roads.
Here are the details...
Brief Description:
The height lowering kit by Hyperpro, the Dutch specialist for suspension products. The set includes replacement fork springs and a replacement spring for the shock absorber. This spring set provides you with a sensible 2 inches (50-mm) reduction in height without affecting the riding properties - at the expense of a little ground clearance..
The set includes replacement fork springs and a replacement spring for the rear shock absorber. The progressive springs have been designed to match the F800GS perfectly, and offer a tremendous improvement in response and greater safety in extreme situations. Replacing the front and rear springs will lead to a significant improvement in your suspension system.
Delivery includes detailed installation instructions, the correct fork oil and a special fork seals grease to improve the suspension action and sealing.
Scooter1942 is offline   Reply With Quote
Old 09-20-2009, 08:14 PM   #2
TexasMule
Float away ya fairy...
TexasMule's Avatar
Oddometer: 3,882
Mulewife has the same kit, although we didn't get it from TT.
She ordered her F8GS with the F650 centerstand, and I'm waiting on the side stand from Chicago BMW (should arrive this week).:fingerscrossed
The lowering kit should be on shortly thereafter.
Should be perfect for her.
TMule
You can buy everything, but more time...
______________________________________________
-to my mind alloy triumph tanks rank near titties in their inherent attractiveness -Mutt
TexasMule is offline   Reply With Quote
Old 09-20-2009, 09:10 PM   #3
itsatdm
itsatdm's Avatar
Oddometer: 4,873
Brief Description:
I have/had Hyperpro full length springs on my 800 gs and they worked fairly well. Not only will you lose ride height, you will lose a like amount of travel. Maybe not important for your riding situation. You know that the front has a spacer don't you? Seems like you could achieve the same reduction by removing it. There are threads on "F800 Forum you may find interesting.
itsatdm screwed with this post 09-21-2009 at 10:22 AM
itsatdm is online now   Reply With Quote
Old 09-21-2009, 06:41 AM   #4
Scooter1942 OP
Average Dude
Oddometer: 88
Are these alterations mandatory/recommended if you lower the suspension? If so, why?
Old 09-21-2009, 07:43 AM   #5
TexasMule
TexasMule's Avatar
Oddometer: 3,882
Originally Posted by JoelWisman
The shorter center stand is not MANDATORY, but due to the angle that the center stand will strike the ground with lowered suspension, it will become very hard to center stand the bike unless you go with a lower center stand.
The shorter side stand IS mandatory on a bike with lowered suspension. With a long side stand and 2 in lowered suspension, the side stand will support the bike beyond level, ie it will fall over.
Mr. Wisman is a wise man, he speaks the truth.
TMule
Old 09-21-2009, 05:58 PM   #6
tmex
tmex's Avatar
Oddometer: 2,039
Mr. TMule, it is not crystal clear from your posts if both the center stand and the side stand are F650 parts. I got that the center stand is, but is the part you are waiting for from Chicago BMW the F650 side stand?
Thanks.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 09-22-2009, 07:38 AM   #7
TexasMule
TexasMule's Avatar
Oddometer: 3,882
Thanks.
Yes, as Wisman stated above, if the F8 side stand is used, the bike would go beyond "center" and fall over.
Talked to Chicago and the side stand should be here this week.
She's getting antsy with the bike just sitting there. Had to put a couple boards under the bike so the F6 centerstand would reach the ground.
TMule
Old 09-22-2009, 07:47 AM   #8
Scooter1942 OP
Average Dude
Oddometer: 88
If you don't mind my asking, how much would the 650 center and side stands set me back?
Just trying to get a total cost for making this mod.
Also, can anyone comment on differences in handling characteristics, etc?
Old 09-22-2009, 08:09 AM   #9
TexasMule
TexasMule's Avatar
Oddometer: 3,882
Side Stand $125.77
Center Stand $160.95
Both of which can be purchased at Chicago BMW for 20% discount. (if you don't mind waiting )
TMule
Old 09-22-2009, 02:36 PM   #10
gslost
Oddometer: 3
Hyperpro ,Save $70.00 EPM performance imports 877-786-6543.
Brief Description:
gslost is offline   Reply With Quote
Times are GMT -7.   It's 10:47 AM.
