Old 09-26-2009, 06:36 AM   #1
John Smallberries OP
John Smallberries's Avatar
Oddometer: 1,287
05 R1200GS Brake fluid change interval?
Hi all;
I've read my '05 1200GS maintenance manual and it's not perfectly clear on the issue of brake fluid changes. I bought my bike used with 10,000 miles, so I'm looking ahead to 12,000. The manual shows a brake fluid inspection at 12k, but also lists brake fluid CHANGE annually, with the full change of fluid in the control module every 2 years. By this math, I should be on my 5th brake fluid change. The brakes seem to work fine now.
My dealer warned me that NOT changing the brake fluid can cause the control module to fail (likely stick or rust internally) with a replacement cost of $2000.
I'm setting up an appointment for a fluid change to be safe. Does anyone else have a clearer understanding of the manual than me? Do we really need new brake fluid annually?
Craig
John Smallberries is offline   Reply With Quote
Old 09-26-2009, 07:15 AM   #2
JetSpeed
Naviator
JetSpeed's Avatar
Oddometer: 3,289
You are correct, change the brake fluid in the wheel circuits first at 6,000 miles then every 12,000 miles (or annually) and change the brake fluid in the ABS control circuit first at 6,000 miles then every 24,000 miles (or bi-annually), that is about as clear as BMW makes it.
This is likely one of the most commonly neglected service items on a GS and yet there seem to be few system failures reported.
I would recommend taking the time to learn the procedure (it isn't that difficult) and then you can DIY the fluid change at the proper intervals without the hassle or expense of taking the bike to the dealer, there are a few good write-up's on this forum that walk you through the process.
Pull chocks.
JetSpeed is offline   Reply With Quote
Old 09-26-2009, 08:07 AM   #3
BerndM
Shiftless One
BerndM's Avatar
Oddometer: 1,569
All my brakes fluids were changed by the dealer (at additional cost, of course) during the 12K service.
i am now at 24K and am in the process of doing everything myself, using JVB's fine video tutorial. I have the laptop in the garage and just going along with the video. Finished the valves yesterday and they were found to be absolutely PERFECT.
Get the DVD and have fun!
Regards
Bernd
BerndM is offline   Reply With Quote
Old 09-26-2009, 06:34 PM   #4
Oddometer: 1,287
Brake fluid change - dealer advice
I paid a visit to my local dealer to discuss the brake fluid change and got an odd response. My bike has been serviced there since new by the previous owner (who was actually a dealership employee), so they have all the records. He confirmed that my bike (now at 10k miles) was up to date on its service as of 6000 miles. I asked specifically about the brake fluid and he confirmed it would NOT have been changed as part of the 6000 mile service. What about the "every year/every other year" issue - his answer: Yes - you should do that, but you have to ask.
That's a bit odd - I would expect the dealer to wring every last buck out of us owners and try to sell me an annual brake fluid change. Here is a bike cared for by the dealer and it has never had a brake fluid change in 10,000 miles and 5 years.
I scheduled a fluid change with an estimated cost of $190 - which doesn't sound too bad considering the time involved.
I'll get the DVD and consider doing the next one myself.
Craig
Old 09-26-2009, 09:30 PM   #5
jeffjbmw
Threadkiller
jeffjbmw's Avatar
Oddometer: 773
Frankly, I think the interval for changing brake fluid everywhere on the bike should be about two years.
I did my wife's RS after its fifth year. I did mine after the third year. That probably was too long, but every 6000 miles isn't necessary.
How often do you change your car's brake fluid? Having owned VW's and I learned from their maintenance schedule to change it every two years.
Even on my bikes with those long times, the fluid was pretty good and actually very clean coming out of the control module.
I have been using this rule of thumb for a long time with good results. Never had a caliper fail.
You can never have too many motorcycles and musical instruments. But if it is only one of each....... a R1200GS. And a Martin 00-18H......
Read my blog: http://jeffszen.blogspot.com/
jeffjbmw is offline   Reply With Quote
Old 09-26-2009, 11:06 PM   #6
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,470
The interval for the '05 was spec'd at 1 year for the wheel circuit and 2 years for the control circuit. You can see this in the original maintenance schedules [pdf]. At some point BMW changed the spec to every 2 years for wheel circuits and 4 years for the control circuits. That's how it reads in the '07 version of the RepROM.
I compromise with my '05 and change the fluid in both wheel and control circuits every 2 years.
marchyman is offline   Reply With Quote
Old 09-28-2009, 06:50 AM   #7
PETDOC
User Awaiting Email Confirmation
Oddometer: 1,212
I recall seeing a BMW bulletin posted on ADVRIDER which doubled the brake fluid change interval if you have stainless steel brake lines.
PETDOC is offline   Reply With Quote
Old 09-28-2009, 09:13 AM   #8
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,989
Same here, no point in half a job anyhow.
By the way, all servo-ABS systems on the R1200 have SS lines.
Jim
Old 09-29-2009, 05:32 PM   #9
Oddometer: 1,287
Taking the plunge: doing the brake job myself
After reading the Wisdom information and lots of other posts, I'm taking the plunge and doing the brake bleed/flush myself on my '05 1200GS. I ordered the funnel/reservoir, the speed bleeders, the hose, the collection bag, the DVD..., the works.
The posted instructions and photos are so well done, I feel confident I can take this on. If I do this every year, I'd hate to have to chuck out $190 a pop.
Next: getting ready for the valve adjustment an 12k service! Thanks to those who have posted instructions.
Craig
Old 10-01-2009, 10:09 AM   #10
drdata
R1200GS
drdata's Avatar
Oddometer: 2,160
Craig
Agree, and I too plan my own bleed, that is if no more abs faults on my test ride after having topped up. To date its seems a flush does not fix anything, just prevents. Hate to do the work if I yank the servo out anyway.
One thing I am not clear on it the wheel vs control circuit. I thought there were two separate bleed points, but from the how article it looks like you have extra fluid above the servo, open a wheel bleeder, and then hit the brakes to pump fluid through. That seems to be the wheel circuit.
Edit: I see teh control stuff is further down. The main section title of both wheel and control threw me.
My question now is what is the deal with the simplified control bleed?
Have router, will split lanes for food.
drdata screwed with this post 10-01-2009 at 10:30 AM
drdata is offline   Reply With Quote
Old 10-01-2009, 12:46 PM   #11
Oddometer: 1,287
Bleed instructions
As I read the Wisdom article, you actually have to do nine separate bleed operations:
(2) - front brake calipers - both sides
(1) - rear caliper
(3) - taps for the front controls on the ABS servo module
(3) - taps for the rear circuit on the ABS module
I read later that it may no longer be necessary to do all of the servo circuits. While I have the patient open and the funnel gizmo attached, it seems like I should do them all - like the instructions.
CMR
Old 10-01-2009, 05:04 PM   #12
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,470
(1) - rear caliper
CMR
11 bleed operations. One of the three taps in the ABS module is done twice for both front and rear control circuits.
Old 10-01-2009, 05:20 PM   #13
drdata
R1200GS
drdata's Avatar
Oddometer: 2,160
WTF were they thinking? Not so much hard, but repetitive as all get out, and makes the whole design seem like a bitch baby about to crap its dipey because "zee korrect sequence vas nicht followed".
At 2k a pop, like he said. Might as well bleed the bitch dizzy while you got her knickers down.
Cheers
Old 10-01-2009, 05:46 PM   #14
JimVonBaden
"Cool" Aid!
Oddometer: 52,989
I do the two control circuits, and the main wheel circuits. The amount of fluid missed is drops IMHO. Nothing worth the extra hassle.
Some time back a dealer (IIRC) posted a tech bulitin, or similar, that said basically the same thing. I wish I had saved it, but I am confident that I am not missing enough fluid to justify the extra hassle of doing 11 circuits!
Jim
Old 03-01-2013, 04:48 AM   #15
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,050
Am about to flush all the brake fluid on my 2005 this weekend. Are we all still thinking that standard DOT 4 is the way to go?
Times are GMT -7.   It's 10:55 PM.
