Old 03-30-2013, 03:21 PM   #31
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,167
Old 03-31-2013, 11:59 AM   #32
GSMax
Oddometer: 18
Hi There,
I guess this will be stupid question.
In the RepRom for GS 2010 is mentioned only bleeding for front and rear breaks. Nothing about ABS unit. Is that means that non servo units does not need it?
GSMax is offline   Reply With Quote
Old 03-31-2013, 01:10 PM   #33
Blackfin31
Oddometer: 17
Flushed my System as Per JBV's video
I agreed with JBV, going through all the circuits, there's a point of diminishing returns. Check the color of your fresh brake fluid before and after the flush....The color of my old fluid was a light tea color, and the new fluid was crystal clear. This at least gives you some form of qualitative analysis....I flushed the servos in two circuits method as per JBV's video....After bleeding the system...the fluid in my system was almost the same color as the fluid in the new bottle...in other words most of the old fluid was removed by the two circuits method...
If your doing it yourself...I might also add making sure your gas tank is almost empty...My tank was full!....lesson learned..lol!
Also may sure you get the special funnel from the Beemer Boneyard too...
Paul
Blackfin31 screwed with this post 03-31-2013 at 06:14 PM
Blackfin31 is offline   Reply With Quote
Old 03-31-2013, 04:23 PM   #34
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,341
Originally Posted by GSMax View Post
Hi There,
It isn't really necessary every time. I actually know that most never bleed the ABS unit on the newer bikes, and it really isn't an issue. On the 2007 and newer bikes there is no need. However, if you have the GS911 it is nice to cycle the ABS for bleeding, but again, not really necessary.
Jim
Old 03-31-2013, 04:38 PM   #35
Paul_R_Canada
Still Upright
Paul_R_Canada's Avatar
Oddometer: 55
Noob question
Perhaps another stupid question but i bow to those who know,
I took out a 2010 for a test ride Saturday, couple of observations
It's got only 7000 km
The front brake reservoir had a cloudy look (possibly water in the system)
When I started it up in neutral before moving the bike the brake caution light was flashing (circle with brake symbol inside)
I've got a hold on the bike but I don't want to find out the abs is bagged at a 2k repair due to lack of Maintenance
Thoughts from the gurus would be appreciated, anything I need to check or ask about? I did tell the sales rep the fluid was bad.
thanks guys..
"There's an upside to everything"
Paul_R_Canada is offline   Reply With Quote
Old 03-31-2013, 05:39 PM   #36
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,531
That is the bike saying your ABS hasn't completed its initialization test. It won't complete until you are moving about 3-6 MPH. I'd STRONGLY suggest you download the riders manual for the bike and read it before buying so you know what is normal and what isn't. Riders manuals are available from BMW at this link.
marchyman is offline   Reply With Quote
Old 03-31-2013, 06:11 PM   #37
Paul_R_Canada
Still Upright
Oddometer: 55
Thanks marchyman for the link I was going to read the manual hard copy not knowing I could get it online... much appreciated.
Old 03-31-2013, 07:45 PM   #38
JimVonBaden
"Cool" Aid!
Oddometer: 53,341
thanks guys..
That "cloudiness" you see is likely the foam installed in the reservoir. If the brakes are working normally, and you have no fault lights, you are likely fine. I would ensure you have service records, but on a 2010 it is pretty unlikely that your ABS has an issue or dirty fluid, especially at such low miles.
Jim
Old 03-31-2013, 08:34 PM   #39
Paul_R_Canada
Still Upright
Oddometer: 55
Relief
Thanks so much Jim, I'm new to BMW and there's a lot of "I don't knows" I'll download and read the owners manual as well to get my bearings.
On the up side when I took it the bike felt like a kid again, it was a lot of fun to drive, can't wait to ink the deal.
Old 04-01-2013, 01:00 AM   #40
GSMax
Oddometer: 18
Jim
Thank you Jim,
Valuable hint as always. Will consider about GS911.
Times are GMT -7.   It's 12:01 PM.
