Old 10-06-2009, 10:08 AM   #1
roadtripp OP
roadtripp's Avatar
Oddometer: 113
Heavy duty tubes vs normal tubes
I am fixing a flat rear on my KLR 650. This is the first time I've ever owned a spoked-wheel bike, so I'm inexperienced with tube-type tires. What is the difference between heavy duty tubes and normal tubes? I heard somebody mention that heavy duty tubes are harder to patch - is that right?
Thanks for helping out a noob!
roadtripp is offline   Reply With Quote
Old 10-06-2009, 10:22 AM   #2
MrPulldown
MrPulldown's Avatar
Oddometer: 3,156
The heavy duties are just thicker. Most Mx and dual sport people seem to prefer them. When installing new tires on my bike I replaced the tubes with HD ones.
Coming from a cycling background most would avoid HD tubes due to the weight. Downhill guys however don't mind the weight nor do motorcycle riders. THough they do not provide more puncture resistance (nails and such), they help avoid pinch flats both on the install and the when you hit something really hard.
I would not think that HD tubes would be harder to patch. Patching is a surface treatment. The thickness really doesn't matter. They are noticably larger. Don't carry a HD as a spare.
MrPulldown is offline   Reply With Quote
Old 10-06-2009, 10:30 AM   #3
yosmitetom
Oddometer: 3,354
Lotsa folks like HD tubes. Not me. There is no nail/thorn/screw that goes through a tire that will not puncture a HD tube. HD tubes might some pinch flats while riding with low tire pressure. HD tubes are hard to work with, make the bike handle noticeably worse and cost more.
yosmitetom is offline   Reply With Quote
Old 10-06-2009, 10:38 AM   #4
freeflow
get in or go in
freeflow's Avatar
Oddometer: 15,768
I ran 20,000 miles on one HD tube in a KLR.
I replaced it with a new one and had a very wierd flat. The tube didn't fully unfurl itself after inflation and it folded back on itself on the outside (against the tire).
after 250 miles it got so hot, it burst thru at the creases in the tube. very odd. I've installed alot of tubes and tires on various bikes, but this one puzzled me. I did the baby powder, partially inflated, inflate - deflate trick when I installed the tube, so why it folded over is beyond me.
that said, I didn't mind the HD tubes. The thickness might help avoid a tear during a puncture. I think they may build up more heat though.
there is no perfect answer other than being proficient and have patches and spare tubes.
freeflow is offline   Reply With Quote
Old 10-06-2009, 11:21 AM   #5
roadtripp OP
roadtripp's Avatar
Oddometer: 113
Thanks, guys. I've also heard people say that natural rubber tubes are better with punctures than butyl rubber tubes - is this true?
As far as sizing goes, I'm looking at http://www.bigcee.com/klr650faq.html#wheelstires which says that a 4.00/5.10-17 tube will fit my rear rim. I found a natural rubber tube from Metzeler that will fit 4.10/4.60-17 rims. Will this tube fit my rim?
Old 10-06-2009, 11:30 AM   #6
yosmitetom
Oddometer: 3,354
No. Anything that will to through a tire will go through a tube. Natural rubber also looses air more quickly.
Old 10-06-2009, 11:49 AM   #7
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,549
I only use ultra heavy duty tubes
They last longer and I have fewer flats
I've never had any issues working with them
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 10-06-2009, 12:48 PM   #8
roadtripp OP
roadtripp's Avatar
Oddometer: 113
What are the reputable, reliable brands when it comes to motorcycle tubes? Or are they all pretty much the same?
Old 10-06-2009, 12:51 PM   #9
wibby
wibby's Avatar
Oddometer: 10,549
I prefer MSR or IRC
But Kenda heavy duty tubes are pretty good too
'05 DL650
'92 KDX200
Old 10-06-2009, 03:16 PM   #10
Dfrnt
Just pluggin' along
Dfrnt's Avatar
Oddometer: 979
Overkill?
I use Michelin ultra heavy duty and add some Slime too. Any heavy duty will help with friction wear between the tube and tire if you run low air pressures. I run around 10~14 lbs on my dual sport rides and do not want to have a flat in the middle of some two track 4 miles from the nearest road. The slime will stop MOST potential flats from trail objects such as thorns and small nails. I think they say up to 1/8" or so. I believe it also helps balance the tire as it is thrown to the outside of the tire when it spins, evening out the imbalance if you use enough. I use it in my Adventure bike too and have never balanced those tires with no issues well above posted speed limits. Just once to check it
"Roads? Where we're going we don't need roads" Doc Brown
Dfrnt is offline   Reply With Quote
Old 10-06-2009, 03:50 PM   #11
yosmitetom
Oddometer: 3,354
I run my tubes over 30,000 and them carry 'em for spares. I don't have any flats and use the cheapest tubes I can find, generally BikeMaster or IRC.
Old 10-06-2009, 06:09 PM   #12
MeterPig
Meh
MeterPig's Avatar
Oddometer: 17,176
I got the heavy duty from Bridgestone. It is heavier and on small HP bikes, you might notice a difference.
I have been flogging them over jagged rocks and hard surfaces. No pinch flats.
Then again, I run a Pirelli trials rear and stay up late at night thinking about changing that tire. Thus, I have the uber tough tube.
You looked down here...didn't you.
MeterPig is online now   Reply With Quote
Old 10-06-2009, 07:05 PM   #13
stephano
stephano's Avatar
Oddometer: 2,214
You can also run some slime.
2000 KTM LC4 640E
A Government big enough to give you everything you want, is strong enough to take away everything you have.
Your Government cannot give you something without taking something away from someone else.
I don't want to gain the whole world, and lose my soul. - Tobymac.
stephano is offline   Reply With Quote
Old 10-06-2009, 08:10 PM   #14
DirtyOldMan
Oddometer: 1,902
Bridgestone Ultra Heavy Duty, hell, they almost don't need air. I carry a lightweight 21" for a spare. No trouble changing them unless someones trying to help me.
Sandy Jackson
04 250 RFS
13 650 Terra
96 R1100R
DirtyOldMan is offline   Reply With Quote
Times are GMT -7.   It's 08:52 PM.
