Old 10-09-2009, 11:41 AM   #1
speedracertdi OP
speedracertdi's Avatar
Oddometer: 985
Setting up suspension on a Concours 14?
I just got a C14. I need help on setting up a baseline on the suspension. There is nothing in the owner's manual about it. I have had lots of bikes in the past but nothing this technologically advanced. Can any one give ideas or post a link to some good information? Thanks!
speedracertdi is offline   Reply With Quote
Old 10-09-2009, 12:31 PM   #2
mpowers
mpowers's Avatar
Oddometer: 738
Reread the owners manual, it's in there for setting up for 180lb rider. After that ride the bike, write down what you like and make one adjustment at a time in the direction you think you would like for the bike to feel.
Everyone with a c14 has their bike set up differently depending on road and style. So just use the owners manual as a base line and work from it.
mpowers is offline   Reply With Quote
Old 10-09-2009, 06:25 PM   #3
speedracertdi OP
Oddometer: 985
I re-read the manual tonight. You're right, thanks. I am still looking if anyone has links to any good articles to read on the subject. Biggest thing I would like to know is how you setup the preload sag to your weight for the street. Manual says the bike is setup for a 150lb. rider. I'm 245 and it feels fine. Although, I haven't pushed this bike at all yet.
Old 10-09-2009, 08:48 PM   #4
dduelin
Oh boy that was close
Oddometer: 1,457
Adjust the preload so the sag is about 30-33% of travel. This sag is measured with you on the bike in riding gear. If you google motorcycle suspension sag you will get plenty of information on the subject.
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 10-09-2009, 09:22 PM   #5
olie
olie's Avatar
Oddometer: 1,159
I am 245# and my set up has been so good that I only change the pre-load when riding 2up. I have a note of that someplace but I am sure I have posted on www.concours.org forum. Try a search there, meanwhile I will be looking for my notes and will post here.
Edit: copy of my posting
I am 6'-3 and about 245-250 Lbs. My settings are as follow:
Forks: 10mm and 4 clicks out (rebound)
Shock: 24 (?) clicks in and 1 click out (rebound)
These settings are a bit stiff but...I like them that way for spirited riding. For 2up, I will just adjust further the shock preload.
red 09 ZG /C14 ABS (gone with 59k miles); blue 13 ZG /C14 (7/13 new)
Remus HexaCone Ti, CF hugger,CB Ultra W'shield, GSG Sliders, Sargent seat
12 XT12, black
Akrapovic, Givi W'shield, Kappa saddlebags...
11 Vette, unmolested...
olie screwed with this post 10-09-2009 at 09:53 PM
olie is offline   Reply With Quote
Old 10-10-2009, 01:03 AM   #6
anglerdon
Senior Coot
Oddometer: 84
Good advice all.
I like those stock tires pumped up a little higher than the recommended 42psi. I had mine at 45 rear and 44 front. It handles better.
anglerdon is offline   Reply With Quote
Old 10-10-2009, 06:58 AM   #7
speedracertdi OP
Oddometer: 985
Thanks everyone. I'm going to read up on whatever I can find on-line. Olie, I'll try your settings we're close in height and weight. I can tell you, I was on bouncy I-95 running through Miami last night. Felt like the wheels were catching air on the rebound. I turned the fork damping out two clicks and it seemed to help alot. Couldn't reach the rear while riding (duh) so I'll turn the shock out a couple of clicks today. On a side note from last night, are R1s really that slow?
Old 10-10-2009, 07:46 AM   #8
vegasphotog
Las Vegas Cheechako
vegasphotog's Avatar
Oddometer: 3,262
"I would rather ride my motorcycle on Sundays and think of God, than sit in church and think about riding my motorcycle... GALLERY
vegasphotog is offline   Reply With Quote
Old 06-10-2012, 02:38 PM   #9
fretless
NYC Moto
Oddometer: 61
On a 2010 C14, are the rings around the front preload cylinders calibrated to something, like 2 or 3mm, or are they just an arbitrary reference?
fretless screwed with this post 06-10-2012 at 03:06 PM
fretless is offline   Reply With Quote
Times are GMT -7.   It's 11:58 PM.
