Old 10-29-2013, 06:02 AM   #2296
Speedo66
Transient
Oddometer: 6,701
Originally Posted by Desce View Post
Fellow dub guys, anyone know if I can run heated jacket and gloves on the 2000 w ? Thanks !
I run them both on my '01, never failed to start with the magic button. I do hook up the maintainer in between rides in the winter though.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 10-29-2013, 11:16 AM   #2297
Burninator
Zed's dead
Burninator's Avatar
Oddometer: 302
Same for me. Gerbing jacket and gloves. Battery tender in between rides.
Burninator is offline   Reply With Quote
Old 10-29-2013, 11:24 AM   #2298
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,797
There's three who make it work.
Old . . . and . . . Slow
ORexpat is offline   Reply With Quote
Old 10-29-2013, 02:37 PM   #2299
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,430
Nice ride today on the Dragon. Very little traffic.
Here I am stopped at the way out of Cade's Cove for a quick photo.
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is online now   Reply With Quote
Old 10-29-2013, 02:50 PM   #2300
Desce
Oddometer: 187
Thanks for the replies guys, anyone else I'm interested . Was hoping this would be the case, this way one set up for multiple bikes. The others can definitely handle the draw.
Desce is offline   Reply With Quote
Old 10-29-2013, 06:33 PM   #2301
AlanCT
The Byronic Man
AlanCT's Avatar
Oddometer: 3,473
I ran a heated Kanetsu vest the other day on mine with no issues. I'd like to run some Oxford heated grip wraps I have as well. These draw a less than a jacket and gloves, so I hope they are within the limit.
"You wouldn't be riding a motorcycle if you weren't an optimist."
- Matthew Crawford
2005 Ural Tourist, 2000 Kawasaki W650
IBA #23064
AlanCT is offline   Reply With Quote
Old 10-29-2013, 06:36 PM   #2302
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,797
Believe you'll be fine.
I do think its a good idea to use a battery tender over the winter.
Old 11-03-2013, 01:39 AM   #2303
GoonerYoda
Hot Dickens Cider
GoonerYoda's Avatar
Oddometer: 753
Lucas Valley Rd, I will drive. Mmm yes.
GoonerYoda is offline   Reply With Quote
Old 11-03-2013, 03:13 PM   #2304
orsurf76
engine braker
orsurf76's Avatar
Oddometer: 137
Replaced my triumph-esque tank badges with some simple vinyl decals--I'm pretty happy with the look.
Removing the original badges was rather labor intensive--that adhesive foam is really stuck on there. Not too difficult or tricky, just takes a lot of time carefully scrapping off the goo.
orsurf76 is offline   Reply With Quote
Old 11-03-2013, 03:39 PM   #2305
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,430
Deal's Gap aka the Dragon is now a nice ride because the crowds are gone.
Vince @ SWFL or WNC
2001 Kawasaki W650
2015 Ural cT
Old 11-06-2013, 10:15 AM   #2306
orsurf76
engine braker
orsurf76's Avatar
Oddometer: 137
Hagon Shocks
I'm ready to order some new rear shocks and was looking for a little input.
Sounds like most people who ordered Hagon shocks found the recommended spring rate to be too stiff.
What's your spring rate (and rider weight) and do you think it's too stiff?
Old 11-06-2013, 04:18 PM   #2307
GoonerYoda
Hot Dickens Cider
GoonerYoda's Avatar
Oddometer: 753
Mine came with Progressive 412 HD shocks that the previous 280lbs owner put on.. I weigh 190lbs and there is about a 0.5" of movement when I sit down.
Old 11-06-2013, 05:41 PM   #2308
DaBinChe
Oddometer: 1,072
My Hagons from Dave Quinn is just right...if I can recall I wanted them firmer/sportier. He'll ask you about passenger weight and percentage of time solo vs w/passenger.
DaBinChe is offline   Reply With Quote
Old 11-07-2013, 04:49 PM   #2309
The Jerk OP
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,616
I'm OK with the recommended spring rate on mine. They are a hair stiff when I'm solo but two-up they are right on.
From a style recommendation, I would suggest you not opt for the spring shrouds. They squeak.
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 11-07-2013, 04:57 PM   #2310
orsurf76
engine braker
orsurf76's Avatar
Oddometer: 137
Hagon Shocks
Thanks guys, I'll just make sure I talk over my intended use with Dave Quinn.
My two-up riding is mainly for short jaunts around town--going out to eat or dropping the missus off at work (Mrs. orsurf76 has her Ducati for real rides).
Even my touring setup, with soft bags, doesn't add that much weight--just don't want to end up too stiff.
Times are GMT -7.   It's 08:02 AM.
