Old 03-03-2014, 11:27 AM   #2491
The Jerk OP
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,652
On another note, a project I want to tackle this year is to figure out why the clutch on my W doesn't engage until the lever is almost fully released from the handlebar. This makes slow riding more challenging than it needs to be. Other W's I've ridden do not exhibit this behavior, with the clutch beginning to engage much closer to the bar as the lever is released.
The clutch free play is correctly adjusted. The bike only has around 15,000 miles so I wouldn't expect the clutch to be worn out, but maybe the previous owner just didn't know how to operate a clutch properly.
Is anyone aware of any way that the clutch engagement point can be adjusted through manipulation of the adjustment at either end of the clutch cable? Something that I'm missing? And if not, does that mean that my clutch is approaching the end of its service life? How many miles are you guys getting out of your clutches?
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 03-03-2014, 11:32 AM   #2492
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 313
Same on mine.
45000 k when I got it, 10000 kms later it hasn't changed. Or worsened. A mechanic checked the clutch, it's fine. Couldn't figure out the long release (except that I had a long cable and a short, low handlebar...)
______________________
99 Clubman W650
78 R100/7
BravoFox is offline   Reply With Quote
Old 03-03-2014, 11:39 AM   #2493
The Jerk OP
The Jerk's Avatar
Oddometer: 2,652
Originally Posted by BravoFox View Post
Same on mine.
I do have the Euro low bar kit but when I installed it I also installed the shorter clutch cable that came with the kit. The long release was the same before and after the low bar install.
2000 Kawasaki W650
Old 03-03-2014, 12:21 PM   #2494
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,887
I see...
Could you circumvent the system by say, register your bike in Florida with a "fake" address, or in a friend's name, then bring it to NJ or whatever state you actually live in and just change the reg ?
Just being curious...
Nope, NJ would catch you.
Vince @ SWFL or WNC
2015 Ural cT 2001 Kawasaki W650 for sale
Bar None is online now   Reply With Quote
Old 03-03-2014, 12:36 PM   #2495
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,887
Found this on the net regarding your clutch issue. I'll check my clutch to see where it engages.
"My W650 clutch has engaged near the end of the clutch lever travel for most of its 47000 miles. It has a multi-plate, wet clutch, similar to the Bonneville's. The cable adjustments were correct. No clutch slippage. But I panicked and replaced the clutch pack at 33000 miles, assuming it had to be wearing out. Once removed, I measured the old clutch and friction plate thickness with a micrometer, and found they showed practically no wear. But now, with new plates, it felt really nice, just like new. Take-up was soft, not abrupt. That lasted for about 1000 miles. Then it gradually began engaging just like the clutch I'd replaced.
I think it's the nature of the beast. The new plates feel nice, and have wonderful take-up until they're used a bit, but after several miles, they tend to take up nearer the end of the lever movement.
Now I simply make sure the clutch cable is adjusted properly, and don't worry about the clutch engaging near the end of lever travel."
Vince @ SWFL or WNC
Old 03-03-2014, 12:51 PM   #2496
BravoFox
Twin With a Kick
BravoFox's Avatar
Oddometer: 313
Thre ya go! Good news... Nothing to worry about then !
99 Clubman W650
78 R100/7
Old 03-03-2014, 05:41 PM   #2497
Desce
Finished Pig
Oddometer: 244
Mine engages late in the release also. Never any problems 25 k .
Desce is offline   Reply With Quote
Old 03-03-2014, 07:59 PM   #2498
The Jerk OP
The Jerk's Avatar
Oddometer: 2,652
That's the easy answer but I'm not sure it's the right one.
I rode another W with around 10K on the clock and the clutch engaged right where you'd want it to. I want mine to be like that!
2000 Kawasaki W650
Old 03-03-2014, 08:20 PM   #2499
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,844
All interesting. I've got enough barrel exposed at the clutch lever to move the friction zone point about anywhere I want. Four finger grip, two finger with gloves, closer to the bar for a daughter with small hands, etc.
Manual says 2-3 mm free play at the lever, and shows the adjustment at the engine end of the cable. If the cable is the right length (in relation to the housing), it seems one should be able to get the right angle on the lower release lever and still be able to dial the handlebar lever to where ever you want it, within reason.
Wonder if the cable is a bit too long compared to the cable housing?
Old . . . and . . . Slow
ORexpat is offline   Reply With Quote
Old 03-04-2014, 04:29 AM   #2500
The Jerk OP
The Jerk's Avatar
Oddometer: 2,652
Hmm so it sounds like it is possible...
It sounds like I need to play with it a bit. Maybe I'll start on the engine end and try to set it up so that the cable is as short as possible, then make final adjustment on the lever end.
I mean I could certainly as it is now adjust it at the lever so I have way too much freeplay there which would probably have the intended effect but would also keep the clutch from fully disengaging. I'm trying to see if there's a way I can get the engagement point closer to the bar while still maintaining close to proper freeplay at the lever.
2000 Kawasaki W650
Old 03-07-2014, 03:01 PM   #2501
Speedo66
Transient
Oddometer: 6,834
'01 W650 on Ebay with 860 miles on it. Hasn't hit the reserve yet at $5100.
http://www.ebay.com/itm/Kawasaki-Oth...US_motorcycles
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 03-07-2014, 04:46 PM   #2502
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,844
I'm amazed at how much money people think a Dubya is worth, and how much some folks will pay for them.
Of course, compared with the new 500cc Hondas, it is a nice motorsickle!
Old 03-07-2014, 05:38 PM   #2503
The Jerk OP
The Jerk's Avatar
Oddometer: 2,652
For $5100 it needs to include the damn toolkit. Hell, you can still get the kit as a replacement part from Kawasaki for a measly $82.54 (p/n 56007-1422). How hard is that?
Also those tires are gonna need to be replaced. I don't care how few miles are on it, riding on 13-year-old tires is like asking for death.
2000 Kawasaki W650
Old 03-07-2014, 06:15 PM   #2504
ORexpat
Oregon Expatriate
ORexpat's Avatar
Oddometer: 2,844
Whatchawannabet the seller doesn't give a rip about 13 year old hard-as-a-rock tires?
Old 03-08-2014, 12:19 AM   #2505
Pigford
British
Pigford's Avatar
Oddometer: 970
Original tyres are sh*te anyhow Tyres (tires) are consumables so whats the problem I've fitted K81 (TT100's) to my 650 and they've transformed the bike! No more wanderings and tracking rain grooves, etc.
Pigford is offline   Reply With Quote
Times are GMT -7.   It's 11:44 AM.
