07-18-2012, 05:41 PM
#1111 | |
Oddometer: 115
Tires
Regardless, thanks for re-posting your experiences with the Distanzia's. I had good luck with Distanzia's on my Tiger, and I'd like to run them on the W too. Cheers, Scott |
07-19-2012, 11:04 AM
#1112 | |
acap650
Oddometer: 353
The pipes in the photo above are OEM double wall. |
07-21-2012, 09:10 PM
#1113 |
Oddometer: 115
Captain Jake?
Anyone know what happened to www.captainjake.com? The site appears to be down.
07-22-2012, 04:43 AM
#1114 |
Oregon Expatriate
Oddometer: 2,329
He's active on the Yahoo group; you could check with him there . . .
07-22-2012, 06:49 AM
#1115 |
Oddometer: 2,403
Several W650 riders over on the Yahoo W650 group are planning a get together meeting at Mini Mike's (http://www.mcminnmarketplace.com/mar...le-outfitters/) in Tellico Plains TN in late July or early August. Assuming it is not raining...
Maybe a ride around the http://www.tailofthedragonmaps.com/m...tlet_loop.html after lunch and some bench racing.
Vince @ SWFL or WNC 2001 Kawasaki W650 2012 Ural Yamal |
07-22-2012, 10:47 AM
#1116 |
Oddometer: 115
Captian Jake
So I read through some of the postings on the Yahoo W650 group. Looks like Captain Jake is aware of his website being down now. Hopefully it will be up and running again.
Gonad |
07-22-2012, 01:09 PM
#1117 | |
Oddometer: 2,403
"Whoa! What the hell?! Thanks for the heads-up. NOBODY go to my website! I just tried to go and my browser warned me that it has some nasty malware on it. I will investigate this and see what the hell is going on. Jake"
07-22-2012, 02:44 PM
#1118 |
Oddometer: 4,596
Yeah, I saw the warning and backed off. His needle shim thread has been gone for a while, the mixture screw thread was still up until recently..
'01 Kawasaki W650 '05 Yamaha XT225 |
07-22-2012, 07:59 PM
#1119 | |
Oddometer: 115
Nomad |
07-22-2012, 09:44 PM
#1120 |
Oddometer: 2,403
Nomad,
I just turned the mixture screws out three turns (no shims) and it took care of the lean issue. Some are running their's out more turns but it hurt my MPG. BTW, If you look at the files and database sections at the Yahoo W650 group you will find about everything that you can do to a W650.
07-23-2012, 04:23 AM
#1121 |
Oddometer: 4,596
I haven't seen the Yahoo threads on those carb mods, but what was nice about the Capt. Jake threads were his many, many pictures detailing each step which gave even a person like me, who normally wouldn't touch a carb, confidence to proceed with it and do it properly.
He started with the point of view that you knew nothing, sort of like the "Idiots Guide to the W650 Carburetor", which I appreciated. He also detailed what had to be removed first just to get to the carb, which was nice, too.
07-23-2012, 05:04 AM
#1122 |
Oddometer: 2,403
I just saying that about all that can be done or ever has been done to a W650 is documented in the files and database section of the Yahoo W650 forum.
For example http://groups.yahoo.com/group/W650ri...Jetting%20%20/ Worth taking a look there along with Captain Jake's web site.
07-23-2012, 05:35 AM
#1123 |
Oddometer: 80
Around how much does the carb screw adjustment effect your mileage?
07-23-2012, 07:42 AM
#1124 |
Oddometer: 2,403
zwish,
I'm at 3 turns out and am at about the same 60 MPG average that I had before the mod. When I was at 3.5 turns out I lost about 5 MPG. These are approximate conclusions. Maybe others will chime in with their experience. I know some people have lost a large amount of MPG with jetting changes and mods but are willing to take the hit because of perceived improved performance. Some are at 3.75 or more turns out and have mentioned that they don't have to use the choke anymore on a cold engine but I say you are running way too rich then, Anyway the mod is worth doing and doesn't cost anything and can be easily reversed so why not.
07-23-2012, 08:58 AM
#1125 |
Oddometer: 80
