Old 10-12-2009, 03:47 PM   #1
bthebird OP
Knight in muddy armor
Oddometer: 237
Question Superenduro Oil leak?
At the left side of the bike, at a lower position than the oil inspection window, there is a rubber hose going into a triangular shaped thing, which is fastened to the engine case with a few bolts. There's oil sweating/leaking there into my bashplate. What is that thing anyway? I can't seem to find it in the parts manual? Do I tighten the bolts? Is there a seal which can be replaced?
Please help a noob out here...
bthebird is offline   Reply With Quote
Old 10-12-2009, 04:29 PM   #2
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 9,680
Off the cuff, I'd suspect a cracked engine case near one of the bolts that holds the side stand on. Very common problem. Pull your (stock?) skidplate, get a flashlight and some braxke cleaner. You will probably see the crack at the base of the little circular build out that is threaded to hold a kickstand bolt. Hope it's just a loose screw and not the aforementioned.
Egotism anaesthetises the egotist's stupidity.
unaweep is online now   Reply With Quote
Old 10-12-2009, 05:36 PM   #3
jonz
Miles are my mantra
jonz's Avatar
Oddometer: 1,710
Oil screen cover?
There is a diamond shaped cover held in place by 2 bolts. The large line contains a check valve for oil flow and there is a screen inside the motor that is supposed to cleaned at an oil change. The HOW oil change thread has some photos part way down of an ADV showing that piece. Here's the url:
http://www.ktm950.info/how/Oil%20Cha...il_change.html
JONZ
KTM 950 SE, KTM640 ADV ( Hibachi, risen from the ashes)
KTM520EXC (broken), KTM 400XC (the replacement)
Honda ST1300 ABS (newest addition to the stable)
STOC #326 IBA #217
jonz is online now   Reply With Quote
Old 10-12-2009, 06:47 PM   #4
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,753
Send a message via Yahoo to veetwo _tls Send a message via Skype™ to veetwo _tls
DIRECT LINK NO FICH: http://www.bikebandit.com/ktm-motorc...-2007/o/m15745
your referring to
11: SUCTION PIPE 05
19: GASKET FOR OIL FILTER HNBR 03
18: OIL SCREEN FINISHED 03
CLIC ON PIC FOR BIG:
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 10-12-2009 at 06:54 PM
veetwo _tls is offline   Reply With Quote
Old 10-13-2009, 02:29 AM   #5
bthebird OP
Oddometer: 237
It's not a cracked engine case, that's for sure! You almost created some paranoia there Unaweep
Thanks for the info guys, at least now I know what these parts are and I guess it's very common that oil can get past the diamond shaped plate. I'm going to inspect those bolts one of these days.
Times are GMT -7.   It's 12:41 PM.
