Old 10-16-2009, 01:50 PM   #1
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
KTM 690 R Mystery Plug
What's this red plug that isn't connected? On that note, anyone have a repair manual that is more in depth than the owners manual?
Scott
Officially motor free
9 cycles with pedals
fire_strom is offline   Reply With Quote
Old 10-16-2009, 01:54 PM   #2
stege
Wonderer
stege's Avatar
Oddometer: 288
Got one on the new tenere. same thing, dont know whats it for.
the older I get the faster I was
stege is offline   Reply With Quote
Old 10-16-2009, 02:09 PM   #3
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 429
Scott
I don't know if that's it, but there are two pre-wired accessory power supplies behind the headlight. One switched and one not. In the big threadfest they say they're fuses 8 and 9.
HTH, Jeff
FriedDuck is offline   Reply With Quote
Old 10-16-2009, 02:11 PM   #4
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
I have those two accounted for, they are down in the bottom of the pic, getting wired for GPS, Powerlet and heated grips.
Old 10-16-2009, 04:40 PM   #5
emmodg
emmodg's Avatar
Oddometer: 152
Scott
What are you using to bolt your turn signals on without the stock light surround?
Nuova Strada
2000 R1150GS
2007 KTM 450 EXC
2003 KTM 525 EXC (SOLD)
2008 KTM 690 Enduro (SOLD)
emmodg is offline   Reply With Quote
Old 10-16-2009, 05:58 PM   #6
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
Stock bracket mounts to the top triple and holds the blinkers and the little dashboard/idiot lights. Does the headlight shroud hold them on yours?
Scott
Old 10-16-2009, 07:46 PM   #7
LowOnFuel
In the crapper
LowOnFuel's Avatar
Oddometer: 292
I believe the red plug is for an optional remote set of buttons mounted on the handlebars to control the speedo/trip computer.
LowOnFuel is offline   Reply With Quote
Old 10-16-2009, 08:46 PM   #8
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,839
wiring schematic???
wrk2surf is offline   Reply With Quote
Old 10-17-2009, 03:29 AM   #9
greengoose
boondocker
greengoose's Avatar
Oddometer: 3
Originally Posted by wrk2surf
wiring schematic???
http://www.cs.trinity.edu/~jhowland/...m-complete.pdf
Dennis
09 450 exc
07 wee strom
greengoose is offline   Reply With Quote
Old 10-17-2009, 05:21 AM   #10
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
Thanks GGoose. The wiring diagram was one of the main goals. I'll try and trace the plug at some point soon.
Scott
Old 10-17-2009, 06:20 AM   #11
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,339
Laugh
I looked at the schematic, best I could come up with was a diagnostic connector, but the wires don't all match.
2nd choice would be plug in connector for accessories...
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 10-17-2009, 10:25 AM   #12
lightfighter
where does this go?
Oddometer: 2,289
where are you putting your powerlett?
lightfighter is offline   Reply With Quote
Old 10-17-2009, 12:17 PM   #13
greengoose
boondocker
greengoose's Avatar
Oddometer: 3
cant really see what color all the wires in your pic are but it looks like theres a blue one, the blue wires all seem to go to sensors of some sort. Could be one of the throttle position sensors
Dennis
09 450 exc
07 wee strom
Old 10-17-2009, 12:20 PM   #14
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
I'm at work, but from memory the wires were white, white/red, brown, and blue/red. I'll double check tomorrow.
I am doing a write up here> http://www.advrider.com/forums/showthread.php?t=516471
I think I'll put it on the radiator shroud near where it meets the seat.
Scott
Old 10-17-2009, 02:49 PM   #15
emmodg
emmodg's Avatar
Oddometer: 152
Scott
Yeah, when I took off my headlight/surround for the Trailtech the blinkers were attached to it!
Nuova Strada
2000 R1150GS
2007 KTM 450 EXC
Times are GMT -7.   It's 02:47 PM.
