Old 10-16-2009, 08:22 PM   #1
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
KTM 690 R gets Wired
For navigation and for heat.
Like I do with all bikes I wanted to be able to power a GPS, a vest and heated grips.
There's nothing earth shatteringly complicated about doing any of these things but I haven't seen much on the subject specifically relating to the 690's.
So to start with I ordered some stuff from Powerlet and Symtec heated grips from CalSportTouring.
I went with Symtec for the heaters for two reasons, one, the choice of switches and two, they have two circuits for high and low instead of some versions that use resistors to change from high to low (waste of power and pain to wire cleanly).
I went with the metal toggle because I've preferred it in the past. In this application, with this location I might have opted for the little plastic one. Once I get the little rubber boot I'll be happier with this one.
I had gone to the geek store (Radio Shack) and picked up a relay so I could avoid the inevitable dead battery from hot grips while parked scenario. Well once I got into the project I realized the nice engineers at KTM had given me ACC1 and ACC2 leads to work with under the headlight. One is always hot the other is switched with the ignition. I used the switched one and didn't bother using the relay. The ACC1&2 are both rated at 10A so my 3A grip heaters shouldn't tax them at all.
Here's a picture.
You can see the two red wires joined and connected to the brown wire in the center. They are the ground wires from the grips going to the ground from ACC2. The BLK/RED wire to the right of them is the hot (switched) going to the grip heater switch. I routed the wires along the path of the clutch hose.
Officially motor free
9 cycles with pedals
fire_strom screwed with this post 10-18-2009 at 07:32 AM
fire_strom is offline   Reply With Quote
Old 10-16-2009, 08:32 PM   #2
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
I put the switch next to the ignition. It is mostly out of the way there and I think it will not interfere with the tank bag that usually goes there. There's a steering damper in my future and I am not sure if this location will work with the mounting of the tower but I'll update if it doesn't.
You can see the wires following the path of the clutch hose in the left of the picture.
Next up will be the GPS and Powerlet (BMW) socket wiring.
fire_strom screwed with this post 10-16-2009 at 08:38 PM
Old 10-16-2009, 09:26 PM   #3
.chris
690 Advenduro
.chris's Avatar
Oddometer: 93
Nice job, I am about to do similar, but attaching a cigarette power adapter to my 690e.
Just picked up a mates volt meter so I at least have a chance getting it right.
I am interested in the future, because it's where I am going to live
.chris is offline   Reply With Quote
Old 10-17-2009, 04:39 PM   #4
.chris
690 Advenduro
.chris's Avatar
Oddometer: 93
Had a play with the volt meter, and found this connector on the left side.
http://picasaweb.google.com/lh/photo...eat=directlink
It reports as being 12v, and is switched on the ingition,
Any idea what type of connector that is? Would be nice to buy a connector for that, and wire it up to the cigarette power thingey, I really do not want to splice any wires or touch the bike any more than nessessary.
Any advise/help appreciated.
Old 10-17-2009, 05:18 PM   #5
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 908
Hey Firestrom
Let me know when you get all that running at the same time and tell me if your stator keeps up. Thats exactly what I want to do. I have already removed the candle in the front and replaced it with a Baja 8" HID. The only other draw I have is the Garmin 60csx. I hope it will run the grips and the jacket too. Nice job BTW
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 10-17-2009, 06:17 PM   #6
Biped
NooB Again
Biped's Avatar
Oddometer: 325
Looks like RIGHT side, connector to the solenoid valve used on the US bikes evap canister for emissions control. It is probably switched by the ECU so would not be on all the time while riding.
Biped is offline   Reply With Quote
Old 10-17-2009, 06:34 PM   #7
.chris
690 Advenduro
.chris's Avatar
Oddometer: 93
yeah sorry you are right, that is the right side.
That would make sense being for the evap conister, as that connector seems rather convenient.
I found the other 12v options up the front, so I guess I just run with that, seemed to be 4 of them, 2 of them were always on, the other 2 were switched. Just need the right connectors and away I go.
Guess I run with that. Off to jaycar (downunder budget version of radioshack) when the weather is not so horrid outside.
Shall document my setup once done, could be handy for other electrically challenged people who try similar.
Old 10-17-2009, 09:03 PM   #8
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
Yup, that one does look like the evap deal.
Hey .chris, I only saw two ACC leads (2 pairs of wires two + two -), where did you find the others?
As for load on the bike, I figure the output should be ok to handle all of them. I read somewhere they put out 225w but I don't know if that’s true or not.
the grips are 36w
the vest is 45w
the GPS is 7w
the headlight 35w (but I want to be able to burn 70w)
Tail light & parking light around 5w think.
That totals 163w w/ the 70w headlight.
That leaves 62w to charge the battery, run the computer stuff and the power the pump and what ever else it needs.
I guess I don't really know what it needs for its critical processes. If that’s too close I can disable the parking light, and put an LED in the tail light for a few watt savings.
Anyone know for sure what these are putting out?
Scott
Old 10-17-2009, 10:36 PM   #9
.chris
690 Advenduro
.chris's Avatar
Oddometer: 93
Sorry, my bad terminology causing confusion, there were only 4 wires total, so 2 sets of 12v
Old 10-18-2009, 12:03 AM   #10
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,469
There are newer controllers for the heated grips that pulse a digital signal and do not draw the entire 45 watts. You might get one of those and cut your consumption down a little. As a rule of thumb I usually try to leave 100 watts to run the bike. With this bike you have the fuel pump, injector, computer, electronic ignition etc...62 watts may be undercutting the bike....meaning it may run for a long time but the charging system may not be covering the load...thus the battery will draw down over time. What we need are some specs on the current draw from the running systems of the bike. Also if you are drawing the full amount you are also cutting into your engine power and fuel mileage.
Seth S
Seth S is online now   Reply With Quote
Old 10-18-2009, 07:36 AM   #11
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
Both the real stator output and the real minimum requirements of the bike would be very helpful to know. For now I have a good buffer because the light is still the 35w stock one.
Scott
Old 10-18-2009, 10:34 AM   #12
LowOnFuel
In the crapper
LowOnFuel's Avatar
Oddometer: 288
The OM says 224 W for stator output.
LowOnFuel is offline   Reply With Quote
Old 10-18-2009, 08:26 PM   #13
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
Next up is the Powerlet plug. It went smoothly. I Doubled up on the ACC so I could also wire the GPS to this one.
I used the Low profile socket.
I bought an extra connector that I didn't need as the kit comes with the other half of the modex type deal shown in the bottom left of the picture.
It was a tight fit and there's a bit of interference with the seat (Renazco) but not much. Over all I'm happy with the placement.
I ran the wires along the right side of the head tube and while doing so re-routed the wires from the grip heaters to that side too. Its cleaner this way and leaves the clutch hose plenty of room.
I'll get to the GPS next and add more on this later.
Scott
Old 10-20-2009, 05:28 AM   #14
unlawfulsm
Bearded Hooligan
unlawfulsm's Avatar
Oddometer: 556
Grips
Nice write up about the grips The directions that came with the grips are bit difficult to read as mine are blurry from the copying. The two blue wires go to the switch and plug into the high and the white together go to the low? Then you just ran the power and the ground to the acc plug on the front, the plug I saw has two white wires, brown and a red with blue stripe. Is this the plug you used? Thanks
Get a discount at Smugmug
Use Code- iFRLhicsrl4no
Great Deals on Gear
unlawfulsm is offline   Reply With Quote
Old 10-20-2009, 07:46 AM   #15
fire_strom OP
fire_strom's Avatar
Oddometer: 1,256
No, that plug is the mystery one I asked about in this thread>
http://www.advrider.com/forums/showthread.php?t=516364
The leads I used are the ones at the bottom (690 R) marked ACC. There are two sets one always hot (ACC1) and one set that is only on when the key is on (ACC2). They are marked ACCx 10A so if you dig around in there you should find them.
Scott
Times are GMT -7.   It's 05:07 AM.
