Old 12-13-2011, 07:35 PM   #1
kubiak OP
Oddometer: 4,829
supertrapp packing blowing out
hi, i have a supertrapp superlight muffler on my 02 bmw dakar 650, its the internal disc baffles inside the muffler type and my fiberglass packing keeps blowing out. im talking 100 miles and a third of the packing blows out already. im packing it in there pretty tight and wrapping tape around. i heard the pink strand looking stuff is better? anyone have any good luck with another type of packing? i never had this problem with other mufflers before including the supertrapp with the exposed discs,fmf, pro curcuit, stockers and others.
kubiak is online now   Reply With Quote
Old 12-13-2011, 11:54 PM   #2
mcma111
mcma111's Avatar
Oddometer: 12,095
Kub,
Find the STRING type of packing. It should stay on place.
http://www.motorcycle-superstore.com/2/9/187/4012/ITEM/FMF-Four-Stroke-Silencer-
Packing.aspx?WT.ac=SLIsearch
And buy more than you think you'll need as it packs down pretty good.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 12-14-2011, 08:21 AM   #3
kubiak OP
Oddometer: 4,829
Originally Posted by mcma111 View Post
Kub,
i was looking at the fmf string stuff like you were saying. ok i will try it out. thanks!
Old 12-14-2011, 12:21 PM   #4
The Jester
The Jester's Avatar
Oddometer: 834
I use a length of 3" plastic drain pipe when repacking. Place small amounts of packing into the sleeve, surrounding the core, and use the drain pipe to firm it down after each handfull.
Life is not a rehearsal!
The Jester is offline   Reply With Quote
Old 12-14-2011, 01:55 PM   #5
kubiak OP
Oddometer: 4,829
thats a good idea. i think i know why the supertrapp is blowing the packing out so fast. i started out with 14 discs and took out the core to try out 8 discs to quiet it down, it didnt lose any packing with 14 discs that i could see, now with only 8 discs the extra backpressure is routing the flow through the core and poacking and out the space between the baffle and can, its a pretty tight fit but i noticed balls of packing stuck inbetween the space. so im going with the strand packing and back to 14 discs so the flow is out the discs not trying to get out of the cracks and spaces.i always used masking tape around the packing and wondering if a thin wire wrapped around would work better?
Old 12-14-2011, 02:04 PM   #6
The Jester
The Jester's Avatar
Oddometer: 834
Sounds reasonable. A fine stainless gauze wired around the core tube helps protect the packing a bit. Stuffing loose packing when the core is already inserted into the sleeve means that there is no need to tape or wire the packing it is easier to pack.
Old 12-15-2011, 08:53 AM   #7
kubiak OP
Oddometer: 4,829
thats another good idea, im going to see how the latest setup works and go from there, hopefully with more discs and the core sealed up the packing will stay in there longer.
Times are GMT -7.   It's 08:02 PM.
