Old 10-06-2011, 06:31 PM   #2236
Westbrook
Oddometer: 108
Originally Posted by Rob Farmer View Post
Does anyone know what is going on in the area that used to be the airbox? Is that some sort of custom fabricated cover or...?
Westbrook is offline   Reply With Quote
Old 10-06-2011, 07:12 PM   #2237
richarddacat
abnormal character
richarddacat's Avatar
Oddometer: 3,418
Beautifully built airheads
Info too please if possible. I would like to know the rim/wheel set up on this slick RS. Looks like a late model front end too.
* 05FJR/88K75c/97M3 *
Mid-TN Tag Riders
richarddacat is offline   Reply With Quote
Old 10-06-2011, 07:20 PM   #2238
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,735
I'm curious, how the kickstart works with the shifter linkage set back like that? Both beautiful bikes, like the reverse (monolever era) forks on the RS.....
Black Shadow of Vincent, falls on a Triumph line
I've got my motorcycle jacket but I'm walking all the time...
Zodiac is offline   Reply With Quote
Old 10-06-2011, 07:46 PM   #2239
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 833
Being a later model engine mated to a /2 gearbox I assume that it has a starter motor making the kick starter redundant. Clearly you could not use it as set up. In an emergency you may be able to remove the shifter rod but I suspect that it would be near impossible to kick start a later model High Compression motor using a /2 gearbox kick starter.
Bulldust is offline   Reply With Quote
Old 10-06-2011, 08:18 PM   #2240
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,735
Well I did assume he had a starter motor too - but would like to know if he could use it in an emergency.
Old 10-07-2011, 03:56 AM   #2241
igormortis
igormortis's Avatar
Oddometer: 1,368
Most probably R100R/R80R/Mystic forks. Different internals I believe, but the lower castings look the same. You can tell for sure by the fork oil drain plug - facing the front means they’ve been reversed!
igormortis is offline   Reply With Quote
Old 10-07-2011, 06:32 AM   #2242
red bud
alky w/motorcycle problem
red bud's Avatar
Oddometer: 5,664
"if your not outta gas, your not lost" BDXMPL
"red bud has anyone ever told u you're bit of an ass" bmwblake
http://www.advrider.com/forums/showthread.php?t=706516
red bud is offline   Reply With Quote
Old 10-07-2011, 08:23 AM   #2243
vernon dent
vernon dent's Avatar
Oddometer: 702
74, 8100 mile original. i'm the third owner.
new tires, steering stem bearings, carb rebuild, master cylinder rebuild, odyssey battery,fluids changed, valves adjusted, plus more i can't remember right now. been doing a little more detailing since these pics.
I only ride 'em. I don't know what makes 'em work.
Oddball
vernon dent is offline   Reply With Quote
Old 10-08-2011, 05:29 AM   #2244
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,675
Originally Posted by mykill View Post
But you can take credit for the execution!
I guess so. She sure does look purdy. Typically the bad weathers just hit so I'm riding in the wind and wet but what the hell?
Love the engine. She really does go well.
Rob Farmer is offline   Reply With Quote
Old 10-08-2011, 06:48 AM   #2245
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,513
Originally Posted by red bud View Post
"Discover the Excellence?" Couldn't they think of anything better to say?
"Welcome to Oklahoma, the ______ state."
"Welcome to Oklahoma, home of the _____."
"Discover the Excellence" sounds like generic corporate motivational propaganda, the kind of BS that motivational speakers wearing little headset microphones spew out in airport motel convention rooms. Oklahoma is one of 3 states I haven't been to and it looks like it might stay that way for a while longer now.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 10-08-2011, 08:30 AM   #2246
fishkens
Further...
Oddometer: 5,148
Pfft. You engineers have so much to learn about masterful marketing.
Having read that I'm packing my bags for OK right now.
fishkens is offline   Reply With Quote
Old 10-08-2011, 09:33 AM   #2247
Airhead Wrangler
Adios Mexico
Oddometer: 6,513
You're right. They really should add a good stock photo to complete that sign:
OKLAHOMA
Airhead Wrangler screwed with this post 10-08-2011 at 07:34 PM
Old 10-09-2011, 08:11 PM   #2248
lucky6600
lucky6600's Avatar
Oddometer: 617
80' r100rt
Took on 10/09/2011
lucky6600 is offline   Reply With Quote
Old 10-10-2011, 11:36 AM   #2249
MIOB
MIOB's Avatar
Oddometer: 992
Nice photo, VERY nice bike!
MIOB is offline   Reply With Quote
Old 10-10-2011, 11:47 AM   #2250
allroadtoine
Oddometer: 61
Somewhere in Argentina
allroadtoine is online now   Reply With Quote
Times are GMT -7.   It's 10:57 PM.
