Old 12-21-2012, 02:42 PM   #3241
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,943
Originally Posted by JonnyCash View Post
They also have an "R" and "L" cast in to them, right next to the spark plug. I think that if you have them on the wrong side, they might end up on the bottom where you wouldn't see them.
I have the later issue valve covers on my 1975 R90/6 because when I needed yet another set of valve covers because the wind keeps blowing my bike over or I run into these Hot Rod Latino Red Necks who are turning left in front of me and in trying to find a not too bad looking Peanut covers I discovered that the value of these, used, is something ridiculous. I then found an unpainted set of the side specific covers for a price I could afford.
The unpainted ones BTW are 1977 only. They should even be more durable than the peanut covers because they are thicker. The extra thickness also explains why they are a little quieter.
I thought the R and the L were on the inside. I'll have to look next time I have them off. But I also think that they work on the side indicated and will work with either side up as long as they are on the correct side. The lines being out of order indicates merely they are on the wrong side of the bike. Yes/No?
---Albert Einstein
disston screwed with this post 12-21-2012 at 02:52 PM
Old 12-21-2012, 02:50 PM   #3242
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
Originally Posted by Lornce View Post
Wow. Nearly two hours and nobody's said anything yet...
Good looking bike.
But you know that valve cover's on the wrong side, don't you. You were testing us, weren't you.
Well spotted that man
Yep. They were on upside down because one of them leaked if they were on the right way round. They did eventually get swapped for decent, non leaking, rocker boxes. You missed the RT brake lines instead of the normal ones
It was an ebay bike that looked like this when I got it
Rob Farmer screwed with this post 12-21-2012 at 02:55 PM
Rob Farmer is offline   Reply With Quote
Old 12-21-2012, 03:02 PM   #3243
NC BMW Rider
Oddometer: 105
Originally Posted by Beater View Post
The lines across the cover should be close to level with the ground ... Having a bit of an up-angle is your sign ... many don't notice it (I don't really) ... but some see it first thing.
Thanks for the education. I'll make sure not to make this mistake.
NC BMW Rider is offline   Reply With Quote
Old 12-22-2012, 02:02 AM   #3244
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,606
Yep, those lines on the cover should run parallel to the header underneath it. If your eye is tuned to things symmetrical and you're an airhead rider, it's probably one of the first things you'll notice once you're aware of it. To further the education, and other than some eagle eye will point it out to you, what are the consequences of the cover being on incorrectly? Anyone?
boxerboy81 is offline   Reply With Quote
Old 12-22-2012, 06:17 AM   #3245
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,943
Originally Posted by boxerboy81 View Post
yep, those lines on the cover should run parallel to the header underneath it. If your eye is tuned to things symmetrical and you're an airhead rider, it's probably one of the first things you'll notice once you're aware of it. To further the education, and other than some eagle eye will point it out to you, what are the consequences of the cover being on incorrectly? Anyone?
0
---Albert Einstein
Old 12-22-2012, 07:22 AM   #3246
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,988
Do tell...
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 12-22-2012, 08:55 AM   #3247
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,522
Originally Posted by disston View Post
0
+1. Absolutely no functional or detrimental mechanical effect ... except it will ferret out the BMW neurotics, and symmetry purists in any spectating crowd.
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 12-22-2012, 09:02 AM   #3248
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,234
Ya know, wrongly installed valve covers is comparable to screeching fingernails on a blackboard.
Doesn't bother me, but it does grab attention!
Old 12-22-2012, 07:00 PM   #3249
channelcat
channelcat's Avatar
Oddometer: 176
Guess I'm an outcast..cant attach pics. Why is everybody always mean to me?
All my stuff is at bmwthrottlesprings.com
channelcat is offline   Reply With Quote
Old 12-23-2012, 06:25 AM   #3250
woodly1069
woodly1069's Avatar
Oddometer: 1,988
Interesting! Earlier airheads had different valve covers and now that I look at mine maybe they are backwards too...
A're they tagged as right and left inside the cover too?
Old 12-23-2012, 07:01 AM   #3251
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,943
The earlier, sometimes called peanut, valve covers will fit properly on either side.
The later style covers, whether painted or not, fit properly on one side or the other but not both sides. The later covers have an R or an L on the inside that tell which side they fit. If the later covers are fitted to the wrong side they will work just fine but the lines, which should be parallel to the ground or the exhaust pipes will instead display an angle.
The later style covers have no up or down side, they fit properly in either mode as long as they are on the correct side of the bike.
Somebody earlier said there are marks on the outside of the covers and the angle is due to flipping the cover. Neither of these features have I noticed. I have later covers on my earlier bike and would take them off later today to verify this but I have currently a problem elsewhere and it is against policy to screw with something not related to the problem I am working on. Maybe if it warms up enough to put the rear end back together I'll have some time later to do this.
The mystery is why it works this way or for that matter why anybody cares.
---Albert Einstein
Old 12-23-2012, 07:08 AM   #3252
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,943
It used to be easier when ADVRider hosted the photos for us but this slowed surfing the site and now you must have a photo account at some other site to post photos or Hot Link to the original photo. Hot Linking sometimes doesn't work and sometimes is considered rude, because it is using a third parties band width for your personal use.
You'll find the tutorial on this page. Option 2 is what s needed;
http://advrider.com/forums/showthread.php?t=919
---Albert Einstein
Old 12-23-2012, 08:04 AM   #3253
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,297
yes.
RECHT = right
LINKS = left
Some late valve covers do not have the L/R on the outside.
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton
"...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater-
Renner is offline   Reply With Quote
Old 12-29-2012, 04:11 PM   #3254
darmahman
"Illogically Deluded"
darmahman's Avatar
Oddometer: 3,090
Found on fleabay
Just received her today... 11,500 miles from new!
ABC# - 4011
“Folks are usually about as happy as they make their minds up to be.” Honest Abe
The last honest politician to come out of Illinois
darmahman is online now   Reply With Quote
Old 12-29-2012, 04:21 PM   #3255
Noswal
Noswal's Avatar
Oddometer: 90
Outstanding!
Noswal is offline   Reply With Quote
Times are GMT -7.   It's 09:24 PM.
