Old 06-28-2013, 03:43 PM   #4051
Droptarotter
Oddometer: 1,275
Originally Posted by Zebedee View Post
Sign me up for some of that ...
One slight problem, anybody got a cute kid I can borrow ...
John
Boy are you going to get flamed with that statement!!!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 06-28-2013, 05:47 PM   #4052
Zebedee
Zebedee's Avatar
Oddometer: 828
Cheers
Obviously part of the language barrier pom (limey) / yank ...
The sole purpose of the cute kid would be to act as a decoy to snare the kindie teacher.
As soon as the snare was sprung the brat would be returned to the parents, regardless of whether they wanted it back or not ... hope that clarifies the comment/situation ...
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 06-28-2013, 06:21 PM   #4053
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
I am guilty of using my daughters as chick magnets ( but hey when you are a 24/7 sole parent you need all the help you can get ) ... It did take me awhile to train my youngest to look for wedding rings ....
BMW R100LT 93 BMW R100RS 91 BMW K1100LT SE 94 76 R90S
R100LT is offline   Reply With Quote
Old 06-29-2013, 06:35 AM   #4054
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
Another beautiful day in the South West
Old 06-29-2013, 07:40 AM   #4055
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 835
My latest project bike was finished today, many thanks to Ray Peake for all his hard work on the bike.
Bulldust
Bulldust screwed with this post 07-02-2013 at 12:30 AM
Bulldust is offline   Reply With Quote
Old 06-29-2013, 09:55 AM   #4056
Plaka
Brevis illi vita est
Oddometer: 4,608
Originally Posted by Bulldust View Post
My latest project bike was finished tday, many thanks to Ray Peake for all his hard work on the bike.
Bulldust
Very pretty indeed!
Might I implore you for a couple closeups of some details? Left front brake, left petcock, left swingarm bearing cap and if you have one, backbone w/ tank off showing wire routing on the dual plug setup.
Thanks!!
PS, if you ever come across some, check out the /5 non-reflector turn signal pods. Also check out the early 100RS wheels w/ the blue pinstripe on the rim.
Consider rotating the rear brake arm a toot or two so the lever is at right angles to the actuating rod with the brake off. Ideally, it is just at 90 Degrees as the brake pads first touch down. I filed the parting lines off my aluminum levers and polished them out---just on the outside where it shows. Rear brake, Shift and Rear brake arm. This took surprisingly little time. <1/2 hr. ea. Then polished on a buff wheel in my grinder. I don't know if I'll be keeping them polished but it sure looks cleaner without the ragged lines. You have the kinda ride that invites people to look close...
Old 06-29-2013, 10:06 AM   #4057
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
Bulldust
Jaw dropping ... Was talking to Ray last week ... he said he had finished up a special project ... I am pretty sure he doesn't have any extra tanks like that sitting around .
Old 06-29-2013, 04:53 PM   #4058
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 835
Originally Posted by Plaka View Post
Very pretty indeed!
Thanks!!
I have an original 1977 Spoke wheel R100RS in my collection I will be restoring the blue pinstripe spoke wheels on this bike in the next few months.
This project bike started life as a 1981 R100/7 T, it is fitted with /6 wheels with new wider rims and Stainless Steel spokes, due to the lack of rear clearance a set of F800 front brakes were fitted over Mono Series brake disks (modified from 4 bolt to 5). A mono series wiring loom is fitted along with new later model switchgear.
Old 06-29-2013, 05:08 PM   #4059
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
So if you went with a Mono harness .. did you up grade all the electrics to a mono ???
Also with dual plugging .. did Ray go with one of these
http://www.ebay.com.au/itm/300724416...84.m1438.l2649
I think you need your own build tread on this beauty .
Old 06-29-2013, 05:23 PM   #4060
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 835
We installed one of my own dual Hall Effect trigger Full Electronic Advance Red Centre Ignition system, a 450 watt alternator, Heavy Duty Diode Board, High Output voltage regulator.and Nippondenso Starter motor.
Yes those are the coils Ray Peake used.
Bulldust screwed with this post 06-29-2013 at 09:28 PM
Old 06-29-2013, 05:29 PM   #4061
R100LT
Chasing 11
R100LT's Avatar
Oddometer: 631
We should talk business soon then
Old 06-29-2013, 05:37 PM   #4062
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 835
http://www.advrider.com/forums/showthread.php?t=823543
Old 06-29-2013, 06:29 PM   #4063
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,507
Here's my airhead before I owned it, my buddy had a little electrical issue on this day. We were pleased to see the it fit in the Element.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 06-30-2013, 04:13 AM   #4064
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,951
As soon as I saw the page come up with that big beautiful blue tank my immediate thought was that this bike was in Australia, then as I glance over to see where the guy is from it hits me that I am correct. Nice to be learning something here as i do waste LOTS of time here, and by the way the bike looks great, beautiful and memorable airhead!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 06-30-2013, 09:38 AM   #4065
airsmith
airhead wrench?
Oddometer: 169
the craziness that took hold a few years back, after around 100k miles in smoke grey decided a little color could be fun... added the homebuilt tail section and solo-seat..
LOUD PAINT SAVES LIVES
airsmith is offline   Reply With Quote
Times are GMT -7.   It's 12:38 PM.
