Old 06-03-2010, 09:41 PM   #1366
east high
east high's Avatar
Oddometer: 943
Originally Posted by slashbike
Hell yeah!
'71 r75/5
east high is offline   Reply With Quote
Old 06-03-2010, 09:43 PM   #1367
slashbike
slashbike's Avatar
Oddometer: 120
Other side.
slashbike is offline   Reply With Quote
Old 06-04-2010, 04:54 AM   #1368
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,675
Originally Posted by Lornce
Para-lever airhead hub, ala r100gs or r100r, uses the same axle as a K-bike.
Yes but that's not a hub from a paralever
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 06-04-2010, 06:50 AM   #1369
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 17,946
So he turned them to fit a set of standard caged rollers and made some spacers to suit.
Pretty straight forward, or did I miss something?
Old 06-04-2010, 07:41 AM   #1370
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,675
I don't think there is enough metal in the hub to allow that approach.
OD on the bearing surface is about 50mm and the ID is around 40mm.
Maybe some trick super thin bearings with a big hole down the middle?
Old 06-04-2010, 08:33 AM   #1371
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,077
How did you determine that?
I can't see the hub in the photo, but it's got the four-bolt discs, which the R100R and GS also used. Even though the hubs come with the BMW cross laced tubeless rims, they've often been mated to normal (tube style) rims.
Why would you think that's not an R100R hub?
Old 06-04-2010, 09:22 AM   #1372
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,675
Do the cross spoked wheels have the ribs in the middle like the conventional hubs do?
I remember them to be chunkier and slightly concave but I may not have been paying attention.
Can you have a look at one of yours wirespokes and let me know please?
Old 06-04-2010, 10:12 AM   #1373
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Here is a shot of the paralever wheel and hub from an R100R.
Same hub as a Mystic and a GS.
Looks like your mates wheel is a customized early wheel.
Kind of scary.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
wirewrkr screwed with this post 12-03-2010 at 11:17 PM
Old 06-04-2010, 04:28 PM   #1374
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,675
Simply scary the way this dude can make four go into three.
Any other ideas on using the large diameter axel on the conventional hub.
I might have mentioned to Lornce once upon a time I was looking at using a larger axel on my G/S. I hadn't considered a cross spoked hub and its a good option but I do like the look of the conventional hub.
Rucksta screwed with this post 06-04-2010 at 05:29 PM
Old 06-04-2010, 05:34 PM   #1375
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 17,946
Hog out the entire centre section of an aulde hub and shrink-fit the inner bit of a para hub? (if there's no room for a conventional single row caged ball?)
It dun't hafta' be rocket surgery!
Old 06-04-2010, 06:01 PM   #1376
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,675
Lornce
I think I'd go for a cross spoked hub before hacking into 2 hubs but I'll take a look at this.
First concern is once the centre section of a conventional hub is gone there's not much meat left on the shell to take the new core.
Of course the new core doesn't have to be from a para hub it could even be custom billet and I'm not committed to 4 bolt discs.
Thanks for an option.
Old 06-04-2010, 11:04 PM   #1377
Just Dan
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,876
Tasty R90s
13' kawasaki W800, Yep the twin
13' Skyteam Ace 125 BIG BORE
81' BMW R100 TIC
Old bikers don't get old by accident.
Just Dan is offline   Reply With Quote
Old 06-05-2010, 12:12 AM   #1378
Wirespokes
Wirespokes's Avatar
Oddometer: 8,077
Originally Posted by McCardigan
Front from a K100
Looks like those are custom discs and carriers too.
Another possibility is using some sort of a modified axle arrangement and leaving the hub unmolested.
Old 06-05-2010, 12:42 AM   #1379
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,675
I don't know about the custom carriers but you have me curious now.
More head scratching required.
It seems the more I look at this bike the more questions I have.
Modified axle.
Are you thinking two piece axel threaded together in the middle to allow thick at the outsides thin in the middle, insert half an axle from each side, screw it together and clamp in forks?
Another posibility might be thin solid (or hollow) axle with a threaded section each end with threaded bosses to take the space between the axle and the fork clamp then lock the assembly together in the conventional manner.
Either option has got to be more elegant than hacking the hub.
Chris thanks for the photos I'm enjoying this an may even end up with a new axle assembly.
Old 06-05-2010, 01:29 AM   #1380
McCardigan
happy Budda
Oddometer: 3,000
Modified axle.
Hey Rucksta
Paul Rooney is just down the road from you. Trades under RJ's M/C service, at Canungra, 07-5543-5962.
BTW, Here is another mates K100 front end conversion on his R90S.
Sorry about the quality of the photo's, but they were taken pre digital days
Keep me searching for a heart of gold, and I'm getting old (Neil Young)
Still homeless, armless and legless,
And proud 7th Day Adventourist
McCardigan is offline   Reply With Quote
Times are GMT -7.   It's 10:20 AM.
