Old 10-27-2009, 01:19 PM   #1
kdscoates OP
kdscoates's Avatar
Oddometer: 3,485
mileage out of the stock suspension???
just wondering what kind of mileage you guys are getting before the rear shock rebuild??
Quote from Pj "if loud pipes save lives imagine what learning to ride that thing would do!!!"
quote from 4runner "but,if you really need a 80/20 , which most of us do and won't admit it,"
kdscoates is offline   Reply With Quote
Old 10-27-2009, 04:43 PM   #2
GA. DUALSPORT WANTAB
GA. DUALSPORT WANTAB's Avatar
Oddometer: 2,291
50,000 on mine and it's never crossed my mine. I do ride it very easy though.
GA. DUALSPORT WANTAB is offline   Reply With Quote
Old 10-27-2009, 05:40 PM   #3
kdscoates OP
kdscoates's Avatar
Oddometer: 3,485
very easy on the rear wheel!!
Old 10-27-2009, 06:15 PM   #4
juniorsktm
juniorsktm's Avatar
Oddometer: 823
I Find
Trailering seems to extend the life!
Whats Up Steve-O!?
RIDE TO RIDE AGAIN
juniorsktm is offline   Reply With Quote
Old 10-27-2009, 07:29 PM   #5
Oddometer: 2,291
Damn never even saw that one coming.
Whats Up Steve-O!?
Old 10-27-2009, 07:43 PM   #6
950TRANSALP
950TRANSALP's Avatar
Oddometer: 794
Cry 30,000 miles an leaking
S speced rear shock with a softer spring rate @ Superplush ( 2 years ago ) lots of loadded tours on and off rd. .
Just started to leak : (
Back to James Sidel this winter ...
"The more you drive the less intelligent you are !"
Repo Man - 1984
950TRANSALP is offline   Reply With Quote
Old 10-28-2009, 04:55 AM   #7
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,132
60.000km's of which 40.000 at least fully loaded, of which 30.000 off paved roads.
No problems, that's when i sold the bike.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 10-30-2009, 11:49 AM   #8
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,987
It's a good idea to have the fluid flushed every 20-30k miles. This is cheap, about $80 at my local shop using the 'good stuff' oil. It will remove the small metal particles and extend the life.
"Son, you can't do both"
Old 10-30-2009, 12:47 PM   #9
HellsAlien
a has-been that never-was
HellsAlien's Avatar
Location: Baja Sur winter. PDX summer (that's like 6 wks!)
Oddometer: 2,348
The other reason to do shock maintenance is to check the lower spherical bearing in the swing arm. It is heavily loaded & a known wear item. It can only be checked by pulling the shock.
Learning how to R & R the shock is fun, as the fit on the lower clevis is tight! Replacing the bearing is fun too! As is pulling the spring off the shock, you will need a decent spring compressor for that, should you choose to do so.
"Hells AL is right."Zuber "Bad roads, good people. Good roads, bad people." Mama Espinoza
“Ride first, tart second. Sorry bro but that’s the way it has to be.” Cbrit, 2008
“You gas it where I brake!” trackday passenger, Thunderhill, 2005 "Especially since he's one of the fastest riders on the planet, on any surface!" Earwig, 2014
HellsAlien is offline   Reply With Quote
Old 05-24-2012, 05:15 AM   #10
950TRANSALP
Oddometer: 794
Finally went this week ...
Slow leak for two years just turned into a big one with no damping now ...
2,000 miles loaded Utah desert trip just finished it off with a pogoing finaley .
Hope the turn around is fast !!!
Repo Man - 1984
Old 05-24-2012, 08:11 AM   #11
dozer
dozer's Avatar
Oddometer: 337
I serviced mine at 25K miles, lower piston rod bushing was worn out and had to be replaced. I'll do it much sonner next time (15K miles)
A freshly serviced shock work so much better.
P.s.
KTM recommends servicing ever 2 years or 15000KM
dozer is offline   Reply With Quote
Times are GMT -7.   It's 12:06 PM.
