Old 10-27-2009, 05:15 PM   #1
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 727
1981 KZ440 LTD cafe/street tracker project
ok so this will probably be a long ongoing post, as i don't always have tons of time to work on it, and money is REALLY tight. but i did get the bike for free, so that helps a ton.
the bike is 81' 440 ltd. the plan is to make it into something a little more appealing. sorry all you ltd lovers. so lets go straight to the pics
first the inspiration
this is where the bike was living for the past five years
something dead was in there
all washed up
the start of the teardown
i got her started!!!!! wahoo! but she didn't run all that great. could only get it to idle. any time i gave it gas, it would die.
i know i need to clean out the carbs and that will help a ton. i just wanted to make sure there wasn't something that i need to do first or something that may be wrong. i am new to the whole twin thing. to help i decided to also include a video, i hope it is loud enough. let me know if there is anything that i should do before i continue the teardown.
2005.5 KTM 950.....it goes.
lamoson is offline   Reply With Quote
Old 10-27-2009, 05:41 PM   #2
CLynn85
Oddometer: 67
Having just picked up an 82 KZ440, I'm definitely tuning into this one. I have the same inspirational photos, but I'm more worried about learning to ride better than customizing at this point.
CLynn85 is offline   Reply With Quote
Old 10-27-2009, 06:30 PM   #3
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,707
Once you take the mouse nest out of the air cleaner/ carbs it should run better
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 10-28-2009, 02:03 PM   #4
comes naturally
renewed hope
comes naturally's Avatar
Oddometer: 1,894
I just picked up a 79 kz400...
comes naturally is offline   Reply With Quote
Old 10-28-2009, 03:08 PM   #5
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 727
changed the oil today and surprisingly it didn't look too bad. no more luck on getting her running better though. i am trying to bring that battery back to life right now, added water and putting a charge on it, but i am doubting it will hold a thing. it is a bummer there is no kicker on this thing. i am debating weather i leave it together and try and get those carbs dialed before the teardown, or if i should just strip the thing to bits and work up from there. what do you think?
Old 10-28-2009, 03:16 PM   #6
kz1
kz1's Avatar
Oddometer: 780
Additional information
For additional information, the KZ owner's website:
www.kzrider.com
kz1 is offline   Reply With Quote
Old 10-28-2009, 04:39 PM   #7
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 727
www.kzrider.com
thanks hadn't found that one yet http://www.armbell.com/forum/ this is a good one too.
Old 10-28-2009, 08:22 PM   #8
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 727
i have been doing some reading on carbs. looks like if i am gonna run these without the stock airbox, and different exhaust, they aren't gonna run so well. should i be looking for different carbs? if so what should i look for and should i go 2-1 with it? wouldn't be too hard to fab up the connections.
Old 10-29-2009, 10:47 PM   #9
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 727
progress! so i fiddled a bit today. i hooked up a jump pack and got it going when i would take off the pack to put the airbox on it would die. so i made a make shift filter with two paper towels. i couldn't believe it, revved right up! i was surprised. here is a vid. so how does is sound?
Old 10-30-2009, 04:05 PM   #10
comes naturally
renewed hope
Oddometer: 1,894
What kind of video camera do you have?
comes naturally screwed with this post 10-31-2009 at 08:14 AM
Old 10-30-2009, 09:48 PM   #11
tenderfoot
PRJ
tenderfoot's Avatar
Oddometer: 1,452
It sounds just as I remember the one my wife had BC. (Before Children)
Believe me, you've got a seriously nice little bike there.
tenderfoot is offline   Reply With Quote
Old 10-31-2009, 05:48 PM   #12
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 727
http://vholdr.com/
well worth the money. i love it. and the new model shoots in 1080p.
as for the bike, planning on trying to ride it around the block tomorrow, just to see if there is anything i need to address before the tear down. i hope the tires last, got some pretty sweet dry rot going on em. i will just keep it slow. maybe i will take some video.
Old 11-01-2009, 09:15 PM   #13
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 727
took it around the block to see how she rides. not bad. the carbs could use some tuning, but everything else seems ok. here is the vid. sorry about the wind
now for the real work!!! time to TEAR DOWN
Old 11-02-2009, 02:58 PM   #14
zap2504
Dave E.
Oddometer: 629
I also have an '81 440 LTD that I've been working on (seems like forever). But mine did not run llike yours. So far I've replaced the rubber intake manifolds (common problem in most bikes this old), removed the front master cylinder (mine was filled with rust and spooge - it's generally regarded as a piece of junk anyway) and am in the process of converting the "buckhorn" bars to more of a standard/superbike bar setup (need to install Yamaha straight-mount MC and different front turn signals). As you have found, the 440 LTD does not like to run without the stock air filter (but you can get away with MAC 2-1 exhaust for appearance sake) nor a fully charged battery (electronic ignition). Since your bike seems to be running quite well now, check the charging system, flush the brake lines, disconnect/clean/lube (with dielectric grease)/reconnect all the wires and keep it running while you decide about a custom appearance. The KZ Twins site has answers to about any question you can come up with.
zap2504 is offline   Reply With Quote
Old 11-02-2009, 03:38 PM   #15
lamoson OP
something catchier
lamoson's Avatar
Oddometer: 727
yea my master cylinder is shot too. so nasty. i started to really tear it down last night. i am going to tear down to everything but the motor. then i will chop and weld, do lights, bars, new switches, seat, fork boots.
i will re-assemble when that is taken care of, maybe address the carb issue then. still not sure if i can make those work with pod filters or not, haven't found a clear answer. if not, i will need to decide what to do with the carbs, still go two or make it a 2 to 1. anybody recommend any carbs. cheap is preferable.
Times are GMT -7.   It's 07:42 PM.
