Old 11-02-2009, 10:32 AM   #1
unrealtrip OP
Flirting with oblivion
unrealtrip's Avatar
Oddometer: 130
Send a message via Yahoo to unrealtrip
Ulysses vibration under hard acceleration?
You'll have to forgive my new Uly owner lack of experience as I'm just coming up on the 1000 mile mark, but this weekend during some two up riding, I noticed when under harder acceleration I would get a strumming vibration under the seat and in the bike in general. This morning on my way to work I noticed that same vibe (turned rear susp back down) when under hard acceleration as well. I don't recall it being there before, but it could also be that I'm just riding it harder than I was and or the engine/etc is starting to break/settle in as I approach 1k.
Thoughts? Or am I just being a paranoid new owner.
My 1985 XT600 rebuild thread
Everyone dies, not everyone lives.
'08 Buell XB12XT - "The Bomber"
'02 Yamaha XT225, '99 Suzuki RM125
'85 Yamaha XT600
"Aut viam inveniam aut faciam" - I will find a way or I will make one.
XT600riders.com
unrealtrip is offline   Reply With Quote
Old 11-02-2009, 10:45 AM   #2
ricohman
Marinoni man
ricohman's Avatar
Oddometer: 1,858
I found this same thing as I used to ride multi cyl sport bikes. It only seems to occur at lower revs.
Nature of the beast I guess.
ricohman is offline   Reply With Quote
Old 11-02-2009, 10:57 AM   #3
unrealtrip OP
unrealtrip's Avatar
Oddometer: 130
I get the paint shaker thing at lower speeds, kinda like a while bike vibe thing, but this is more around ~4500-5500rpm when I'm on it, its like a strumming vibe I can feel in the seat and footpegs. More of a vibration than a shaking, if that makes sense.
'85 Yamaha XT600
XT600riders.com
Old 11-02-2009, 11:04 AM   #4
Ironrdr
Pay No Attention...
Ironrdr's Avatar
Oddometer: 524
That's to let you know in about a second you'll be bouncing off the rev limiter and it'll be time to shift.
I believe my Uly vibrates somewhere in that rev range too. Always has, hope it always will.
-darrell
It's a tough life, if you don't know how to live it.
2011 Ride West Ride Report
Ironrdr is offline   Reply With Quote
Old 11-02-2009, 11:12 AM   #5
snowscum
World Owner
snowscum's Avatar
Oddometer: 1,136
Send a message via Yahoo to snowscum
Is it an 09? Sounds like somethings not right.
I want to leave this planet the way I entered it, being held upside down naked and spanked by a nurse.
snowscum is offline   Reply With Quote
Old 11-02-2009, 11:25 AM   #6
unrealtrip OP
unrealtrip's Avatar
Oddometer: 130
It's an 08'. I made sure everything was right, oil, belt seems normal etc. Was kinda hoping to figure it out before I bring it in for the 1k, I hate dropping off a bike with no idea what is wrong ya know :)
'85 Yamaha XT600
XT600riders.com
Old 11-02-2009, 11:26 AM   #7
unrealtrip OP
unrealtrip's Avatar
Oddometer: 130
-darrell
Shouldn't that be a closer to 7k than 4500 though?
'85 Yamaha XT600
XT600riders.com
Old 11-02-2009, 01:06 PM   #8
snowscum
World Owner
snowscum's Avatar
Oddometer: 1,136
So in neutral when you rev it can you tell if its as bad? Or just in gear?
Old 11-02-2009, 01:14 PM   #9
unrealtrip OP
unrealtrip's Avatar
Oddometer: 130
I had to go check once you mentioned that. Rolled it to an empty corner of our parking lot (at work) fired it up and revved, the underseat vibe started up pretty much exactly at 4500rpm when in neutral. Rode it around a little and pretty much the same story under load. I searched on badweb and found a thread about a bad front isolator, but I have a hair under 1k, is a possible that could fail already? It does appear to have some stretch like or wear marks in the webbing.
'85 Yamaha XT600
XT600riders.com
Old 11-02-2009, 01:34 PM   #10
Hughlysses
Hughlysses's Avatar
Oddometer: 2,644
Other possible cause of a (relatively) high RPM vibration like that is a loose primary chain. They should check the adjustment on that as part of the 1k service.
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Old 11-02-2009, 10:00 PM   #11
Ironrdr
Pay No Attention...
Ironrdr's Avatar
Oddometer: 524
I can only speak for what my Uly does. And somewhere between 4200-5500 (been a few weeks since I've ridden it, damn broken wrist) it definetly has a spot where the vibes are increased.
From 5500 on though, it smooths right back out all the way to red-line.
But, thats just what I've experienced on my '06. 23,000 miles.
-darrell
Old 11-03-2009, 02:27 AM   #12
RedUly
Esse Quam Videri
RedUly's Avatar
Oddometer: 5,530
It is hard to answer your question with out sitting on your bike and comparing it to other Ulys.
You asked about the front isolator. It is possible it's bad but I would be surprised.
It's time for your first service. The primary chain gets adjusted then, which will cause vibrations if it's out of spec.
Check the straps that hold the muffler on and make sure all 3 of them are still there.
My guess is nothing is wrong. Got someone you can swap Ulys with for 15 minutes?
The point is that one doesn't have to dismiss their sense of decency and diplomacy to make a point. - Luap
I think people who are that bad at lying are probably too stupid to be taken seriously. - #18
You're a slut. But you're cute, so it's ok. - MayQueen
RedUly is offline   Reply With Quote
Old 11-03-2009, 05:42 AM   #13
gepr
gepr's Avatar
Oddometer: 1
Send a message via AIM to gepr
4500 rpm
Mine does exactly that at from 4500 - 4700 rpm. I can't say it's HARD vibration; but it's definitely more than at any other rpm. My old Honda shadow did the same thing, but at a different frequency. I just chalk it up to the way the engine's made. Perhaps a harmonic? After about 11k miles, my Uly calmed down quite a bit. The shadow had it the whole time I owned her.
But if it's really a HARD vibration, then it's quite possible something's very wrong.
=><= Hail Eris!
gepr is offline   Reply With Quote
Old 11-03-2009, 06:05 AM   #14
PrtclMn001
Custom User Title
PrtclMn001's Avatar
Oddometer: 927
My SV had a similar issue a few k back - turned out to be out-of-synch throttle bodies. I synched 'em and haven't had a problem since.
Not sure if that applies to the Uly or not but figured I'd throw it out there...
PrtclMn001 is offline   Reply With Quote
Old 11-06-2009, 08:32 AM   #15
PSO
Oddometer: 196
I have had maybe the same thing for several years, no better no worse over time or miles. It is not a real vibration as much as a strange almost minor grinding feeling. Same w/new rear bearings, 3 different types of tires, new belt etc. Originally when I posted several years ago it was suggested that perhaps the seat is somehow picking up some form of vib from the rear cyclinder. I have gotten to the point that I just consider it one of the characteristics of the beast.
PSO is offline   Reply With Quote
Times are GMT -7.   It's 10:56 PM.
