Old 11-12-2009, 09:34 AM   #16
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,215
Just got off the line
with Justin at KTM Hutt. Sounds like the only supply of 58214070150 is in Austria. He may try to get some and post it up but as is looks like it will be to Pep Boys / Depot / Boater's World for improv match. Goody.
Baja Dave - can you speculate approximate dimensions?
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 11-12-2009, 11:39 AM   #17
Sutherngintelmen
around the bend
Oddometer: 1,215
Rubber U Channel
Found this rubber U Channel online and ordered up 4ft of 05-00951 delivered to the door for $5.81 (0.85 / ft +USPS)
http://www.aircraftspruce.com/catalo...s/uchannel.php
We'll see how it fits
Old 11-12-2009, 07:21 PM   #18
BajaDave
Crazy Bastard
BajaDave's Avatar
Oddometer: 268
That looks like it will be a good fit. Post up pics when you get it installed.
Our Baja California Loop GPS Tour is now available and shipping!
GripTwister Dual Sport Tours
BajaDave is offline   Reply With Quote
Old 11-17-2009, 03:45 PM   #19
Albie OP
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,944
Well, took the radiator and fan over to the dealer today. They are going to talk to KTM about doing a good will warranty on it. They felt it was something that shouldn't have happened and that it wasn't my fault. Now just have to wait and see what KTM NA has to say.
Old 11-18-2009, 04:26 AM   #20
moon48
690e
moon48's Avatar
Oddometer: 0
Guys, have you got a link to a post in which it is shown how to dismantle the bike, how to get to the radiator to fix it?
(I know, stupid question, I'm just a really poor mechanic living 200km away from a KTM dealership...)
Thanks in advance!
Jacek
Children are smarter than any of us. Know how I know that? I don't know one child with a full time job and children.
Bill Hicks
moon48 is offline   Reply With Quote
Old 11-18-2009, 07:57 AM   #21
DirtJack
DirtJack's Avatar
Oddometer: 1,606
Thanks in advance!
Jacek
Jacek makes a good point. There still isn't a service manual available for this bike. Anyone at KTM listening?
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 11-18-2009, 11:26 AM   #22
Albie OP
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,944
Well, I don't have any pics but it is fairly straight forward taking the rad off.
You can see here on the microfiche and exploded view http://www.ktm-parts.com/pdf/KTM2008/2008_690END.pdf
First remove the front fender.
Take out the two bolts that hold the radiator protector #24 off.
Take out the bolts on the two lower brackets.
Just loosen the bolts in the two upper brackets
You should be able to swing the radiator forward enough to get to the fan housing.
Take out the bolt that is on the top of the fan housing #33
pull up and then back on the fan assembly and you should be able to see any damage.
Old 11-20-2009, 03:25 AM   #23
moon48
690e
moon48's Avatar
Oddometer: 0
Thank you Albie! Will try to work it this weekend.
By the way, I read about some sensor grinding into the back of the radiator that might need fixing. Does it ring a bell? Can this be verified during same operation?
Cheers!
Jacek
Bill Hicks
Old 11-20-2009, 03:35 AM   #24
B.V.
B.V.'s Avatar
Oddometer: 6
I cut the fan housing away a bit and bended the top bracket away. Will see what the efect is this weekend on the ride.
B.V. is offline   Reply With Quote
Old 11-20-2009, 07:56 AM   #25
Lumpyboy
Oddometer: 35
Thanks for the tips guys. I took a piece of carb vent hose, cut a slit down the middle, and super glued it to the fan housing. Basically, same fix that BajaDave made, except I used carb tubing.
Current bikes: '10 KTM 200 XCW, '10 KTM 690 Duke, '08 KTM 690E, '07 WR450 supermoto and dirt trims (street legal)
Recent bikes: '09 KTM 400 XCW, '08 YZ450 supermoto, '05 CR500AF, '05 BMW F650 Dakar (wife's), '05 KTM 200 EXC, '05 KTM 400 EXC, '06 RM250, etc.
Lumpyboy is offline   Reply With Quote
Old 11-22-2009, 11:05 AM   #26
Sutherngintelmen
around the bend
Oddometer: 1,215
Just finished checking mine. 2008 690e is new to me but PO put 1800 miles on it.
Pulled fan back from radiator and absolutely no sign of rubbing. Decided to leave well enough alone and move to the next thing. Will be checking periodically.
Old 11-22-2009, 12:48 PM   #27
The Deanster
Oddometer: 0
I used some RC car fuel line I had around:
http://www.advrider.com/forums/showp...ostcount=10036
The Deanster is offline   Reply With Quote
Old 11-22-2009, 05:37 PM   #28
Windrat
just a poser
Windrat's Avatar
Oddometer: 1,980
Hey guy's
Just checked and fixed mine.. dumm ass's at ktm
I think that letting anything rub on the radiator is a poor fix
the radiator is made of soft metal's that will not hold up to rubbing
the best fix is to remove about and 1/8" of plastic where it's rubbing
and space the top bolt out about 1/8".
I'm going to talk to my ktm guy about warranty on the radiator
my has about 3000 miles and the wear is pretty bad
If you or some you know owns a 690 this issue has to be fixed or
it will leak at somepoint
Windrat is offline   Reply With Quote
Old 11-22-2009, 08:25 PM   #29
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,047
For whatever reason, the listed price for the approximately 24 inch piece of protector in KTM's USA database is about $115, but that is a known glitch in the system
Bad KTM the O rings for the 990 fuel pump are $53 and the pinchy
filters are $150
It 's easy to split some fuel line of the right size and use it.
MAX
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 11-22-2009, 08:27 PM   #30
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 433
Mine had minor rubbing after 6k miles. It looks like I got lucky. Until I can find some weatherstripping for a permanent fix I added a flat washer between the rad and the fan at the upper mount for the fan. This moves it away from the radiator enough that there's no contact.
Remove the left-hand side plastic and the fan's visible. I removed the two lower rad mounts so that I could swing the radiator forward a bit for more room to inspect it. Then using a 10mm wrench you can remove the top screw for the fan. Getting the washer in there and the screw reinstalled was a puzzle. I used long, thin needle nose pliers to drop the washer in from the top (a 1/4" flat washer), and then pressed the fan against the rad to hold it in place. I used the needle nose again to hold the screw until I could get it started.
Start to finish you should be able to get it done in 15mins or so. It's better than nothing & I didn't want to chance it getting worse.
FriedDuck is offline   Reply With Quote
Times are GMT -7.   It's 05:25 AM.
