Old 11-22-2009, 11:29 PM   #31
yağmur
Oddometer: 16
I see some lime on the hose connectios.. Clean with some lime cleaner and add %50 antifreeze to your coolant..
yağmur is offline   Reply With Quote
Old 11-23-2009, 06:02 AM   #32
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,196
Might try this stuff instead of KTM protector:
Originally Posted by Sutherngintelmen
Found this rubber U Channel online and ordered up 4ft of 05-00951 delivered to the door for $5.81 (0.85 / ft +USPS)
http://www.aircraftspruce.com/catalo...s/uchannel.php
We'll see how it fits
It's quality rubber and seems to be properly sized. I did not install on my bike as inspection yesterday showed no sign of rubbing. Bike has 1800 miles on it but new to me.
FriedDuck - these guys are in ATL, I got mine day after ordered shipped USPS.
Originally Posted by MAXVERT
For whatever reason, the listed price for the approximately 24 inch piece of protector in KTM's USA database is about $115, but that is a known glitch in the system
Bad KTM the O rings for the 990 fuel pump are $53 and the pinchy
filters are $150
It 's easy to split some fuel line of the right size and use it.
MAX
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 11-24-2009, 08:19 AM   #33
Albie OP
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,345
Got the news from my dealer and he said KTM is going to good will warranty the fan shroud and radiator. Kudos to RPM Cycles in Dallas. They have been super helpful on both my gauge cluster and this radiator fiasco. Not to mention they keep my SXV 550 running!
Old 11-24-2009, 10:08 AM   #34
DirtJack
DirtJack's Avatar
Oddometer: 1,454
Albie, that is good news. I had a brain malfunction Saturday http://www.advrider.com/forums/showt...5#post11464095 which provided reason for me to check out my radiator for the fan problem. My bike has been down numerous times before bending my radiator mounts (but no leaks till Saturday) which prompted me to install radiator guards. My fan was not touching the surface of the radiator in spite of my abuse.
It looks like, given how easy it is to bend the mounts, that maybe the upper fan mounting bracket is getting bent on some bikes pushing the fan into the radiator.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 11-24-2009, 09:46 PM   #35
Windrat
just a poser
Windrat's Avatar
Oddometer: 1,980
It's the shroud rubbing the radaitor not the fan.
I have fixed mine by removing plastic from the shroud.
690e owner's need to get it fixed or risk getting stranded
mine is and 08 e with only 3500 miles
I'm just trying to help
Windrat is offline   Reply With Quote
Old 11-25-2009, 06:24 AM   #36
DirtJack
DirtJack's Avatar
Oddometer: 1,454
Yes, of course. When I referred to the fan, I was talking about the whole fan/shroud assembly. On my bike, the fan/shroud assembly does not touch the radiator. It comes close, particularly at the bottom, but does not touch. What can I say; I'm not usually lucky in situations like this as my bump-gate experience shows.
2008 KTM 690 Enduro
Old 11-25-2009, 02:34 PM   #37
Windrat
just a poser
Windrat's Avatar
Oddometer: 1,980
The two bottom pins where very worn on mine
I have Trailtrick's old bike and we ride together a bit
the bike has and is being riden hard in the ca desert and mtn's
Not a good place to be stranded I'm going to bump this thread
every few day's
Old 11-26-2009, 09:26 AM   #38
scruffy
Oddometer: 222
every few day's
Think I'm going to put some Hi temp silicone sealant around the bottom pins to
keep them from moving. Hope this will keep them from loosening up.
scruffy is offline   Reply With Quote
Old 11-27-2009, 12:57 PM   #39
Albie OP
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,345
Really gave mine a good look. The shroud is not warped at all, so heating up and warping isn't the issue. It appears that the two pins that mount to the bottom of the rad is where the problem is. They have worn down significantly from the vibration I'm assuming which has allowed the shroud to move closer to the rad. The most wear is from the bottom of the shroud to about halfway up.
Old 11-27-2009, 10:12 PM   #40
Windrat
just a poser
Windrat's Avatar
Oddometer: 1,980
At some point the pins will break Ktm needs to sent out new shrouds
with a new mounting design. I'm thinking of fabing a mount would replace
the plastic pins with metal studs and bolt's It's a lot of work I should
bill KTM more cool-aid please
Old 11-27-2009, 10:36 PM   #41
B.V.
B.V.'s Avatar
Oddometer: 6
Did the 15min idle test on my bike this morning. When the fan kicked in the wind was sucked through the radiator completely. As I cut away some 2mm cowling on the fan I checked but there seems to leak almost no air trough the sides.
B.V. is offline   Reply With Quote
Times are GMT -7.   It's 08:52 PM.
